What did you do to your WJ today? - Page 164 - JeepForum.com
 1107Likes
post #2446 of 45751 Old 04-08-2011, 09:21 PM
volvite
Yes, who makes that bumper and where did you get it?
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #2447 of 45751 Old 04-08-2011, 09:50 PM
scarrskey
It looks like a Custom 4X4 Fabrication Bumper
http://custom4x4fabrication.com/front_wj.htm
scarrskey is offline
post #2448 of 45751 Old 04-08-2011, 10:16 PM
240impala
2003 WJ
It is a Custom 4x4 bumper it does stick out not as bad as some I have seen. Very easy install, well made only had to tweek the the skid plate to mount up no big deal. Cant wait for a Winch to mount on it
"Don't Do It"
IRO 6.5" lift, IRO Front long arms, rear iro adj upper a arm and adj rear lower, custom 4x4 fab front bumper, rough country winch, 15" crager soft 8's, procomp 35-12.50 tire, fenders trimmed KOR light bar, malone roof rack
240impala is offline
post #2449 of 45751 Old 04-09-2011, 09:45 AM
WJGERRY
Changed my T-case fluid yesterday.. super eazy and was due for it...
Changing my transmission fluid next. I got the two filters from the dealership.
I know it takes ATF +4.
Does anyone swear by one brand ATF+4 over another????
WJGERRY is offline
post #2450 of 45751 Old 04-09-2011, 11:12 AM
dustinova
Got my 265/75-16 tires mounted. Waiting to do the brakes before I install the wheel spacers.
2001 WJ Laredo - 4.0 - Zone 4" Lift, IRO Adjustable Front Upper Control Arms, Spidertrax Wheel Spacers, Hella 700ff's
dustinova is offline
post #2451 of 45751 Old 04-09-2011, 11:18 AM
Thomahawk
2006 XK Commander
Cruise'n it in the Nice spring sun. 
Buildthread
Thomahawk is offline
post #2452 of 45751 Old 04-09-2011, 11:32 AM
240impala
2003 WJ
Looking good!!
"Don't Do It"
post #2453 of 45751 Old 04-09-2011, 01:11 PM
fiercePierce
Beauty! love the Zone lift man. and i cant wait till u slap those spacer in!
fiercePierce is offline
post #2454 of 45751 Old 04-09-2011, 01:38 PM
Phoenix1120
Just filled her up and rinsed the 1/2" of pollen off. It's silver again!! I hate pine trees!
Phoenix1120 is offline
post #2455 of 45751 Old 04-09-2011, 03:45 PM
dmextreme77
Washed, waxed, detailed the interior, and trimmed the front bumper! A fabulous day! Its 84 in Iowa! WooHoo!
ForumRunner_20110409_164135.jpg   ForumRunner_20110409_164300.jpg   ForumRunner_20110409_164441.jpg
2001 Grand Cherokee 4L
-4"RC
-265/70 Treadwright's on JK Moabs
-Bunch of misc crap
dmextreme77 is offline
post #2456 of 45751 Old 04-09-2011, 05:35 PM
dmextreme77
Then took her to the Dam.
-4"RC
-Bunch of misc crap
post #2457 of 45751 Old 04-09-2011, 06:13 PM
02MallCrawler
Let's see lastnight I had fan relay failure as I put an alternator in my friends truck, in the rain, the dub over heated broke the radiator and possibly blew the head gasket. Going to do a compression test tomorrow morning....hoping for the best planning for the worst. Lesson learned don't leave dub idling with no mechanical fan and me not sitting in seat to watch temp gauge.
4" teraflex springs, A-arm spacer, Skyjacker nitro shocks, custom rear extended sway bar end links, spot lights on hood,...more to come
02MallCrawler is offline
post #2458 of 45751 Old 04-09-2011, 06:16 PM
dmextreme77
I gave up after 2 relays in 2 days. I did a switch in the cab. Something with the wiring i presume. I am not digging into that electrical mess.
So when i get out of the WJ, i just hit the switch. Saves the headache and worry.
-4"RC
-Bunch of misc crap
post #2459 of 45751 Old 04-09-2011, 07:59 PM
compcrasher86
For people with relay issues advise heading over to summit and picking up a T-fitting for the radiator hose and an adjustable temp control unit with proper relays for the cooling fan. Problem solved and no having to remember to hit the switch when it gets hot.
Today I spent 30 minutes dissassembling and cleaning my entire throttle body and 5 hours figuring out what I screwed up when I put it all back together. After it was back together my Jeep was idling horribly (1200rpm) and wouldnt slow down when you let your foot off the gas. Weird feeling but it was cool to cruise doing 30 for 2 miles and not touch the pedal at all. After 5 hours of taking everything apart, using OBD interfaces to read sensor data, adjusting the idle set screw, and re-seating all 3 sensors, I finally found that I had put the "Z" shaped IAC housing gasket on upside down. To think I was about to go out and buy a new IAC too. Nice Derp moment there. Now it drives beautifully, the idle is great, and throttle response improved drastically, the TB was carboned up pretty bad
Matt
compcrasher86 is offline
post #2460 of 45751 Old 04-09-2011, 08:03 PM
dmextreme77
If i could or knew how to do the relay deal, i would. Relays are not my specialty. One of the few things i have not learned to do. But that sounds like a great way to fix it. If you can tell me how to do it, id be most happy!
As for the throttle body, i second that. With the fuel filter and throttle body cleaning, i could tell a difference immediately.
-4"RC
-Bunch of misc crap
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
