What did you do to your WJ today? - Page 1625 - JeepForum.com
 908Likes
post #24361 of 45326 Old 09-12-2013, 05:13 PM
aralph30
2003 WJ
Theirs no hole for mine I ****ed it up than peeled it off
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #24362 of 45326 Old 09-12-2013, 05:27 PM
rdkendrick
2003 WJ
Originally Posted by zephyr80 View Post
I put mine right in front of driver door
Sent from your back seat!!!
That's where I'm going to put mine.
Sent from my iPad using my fingers
rdkendrick is offline
post #24363 of 45326 Old 09-12-2013, 05:32 PM
dadamets
Installed Eagle Eyes Led tail lights, led reverse bulbs, led plate light bulbs and led 3rd brake light bulbs.
dadamets is offline
post #24364 of 45326 Old 09-12-2013, 08:11 PM
shocking1
Turns out it was the radiator. Since last august I've changed:
All the tie rod ends
All ball joints
Upgraded the track bar
1" front and rear sway bars
Changed ALL the fluids
New axle seals
Rebuilt both diffs
New isolators
Bilstein 5100s
Fat bobs 2" springs
3/4" front spacers
Carolina front drive shaft
New u joints in rear drive shaft
Fuel filter
Trans filters
New magnaflow pre cats
Kolak 3" exhaust
Heater core
New rotors and pads
Valve cove gaskets
Rear main seal
All new plugs
All new o2 sensors
New iac
Cam position sensor
Crank position sensor
Throttle position sensor
Alternator
Starter
Battery
New rims and tires
Jy evic
Rb1
New tweeters speakers and amp
Radiator
Thermostat
Why can't she just be good to me for a month or two, I do all the preventative maintenance and I can't get a month without a cel or issue. Guess I'm just bitter and have a had enough. If I don't get a bite on craigslist soon I'll start parting her out on the classifieds
shocking1 is offline
post #24365 of 45326 Old 09-12-2013, 08:19 PM
spud2388
Just ordered all 4 Moog tie rod ends from advance auto. With the coupon code TRT37, got them for $29 a piece. Only 15 cents more a piece than rockauto shipped. I'll take it...
spud2388 is offline
post #24366 of 45326 Old 09-12-2013, 10:02 PM
Trxgedy
Originally Posted by DustinWJ View Post
installed a clayton 6in all around with some kevlar 33/12.5r15. still needs tweeking and a alignment but came out pretty good lots of hard work
Nice now I know what mine will look like with the lift. Shes the same color.
Trxgedy is offline
post #24367 of 45326 Old 09-12-2013, 11:33 PM
doorjamm
Got my motor back from the machine shop. If your in the 916/530 area of California, Moores engine supply is a great little place. Unfortunately, when I put the engine on the stand and went to install the crank, the crank I received from EPW (engine performance warehouse *I think*) had a nice little score on one of the rod journals. Have to get it swapped out for a different crank. Another few days of waiting before I can get it together I guess. Just excited to get everything together again and pull the dub out of the storage facility. And I also found the production date on the block. Just a little cool info for myself
doorjamm is offline
post #24368 of 45326 Old 09-13-2013, 01:00 AM
99WJ539918
All ball joints
New axle seals
Rebuilt both diffs
New isolators
Bilstein 5100s
Fat bobs 2" springs
3/4" front spacers
Fuel filter
Trans filters
Kolak 3" exhaust
Heater core
New rotors and pads
Valve cove gaskets
Rear main seal
All new plugs
All new o2 sensors
New iac
Cam position sensor
Alternator
Starter
Battery
New rims and tires
Jy evic
Rb1
Radiator
Thermostat
Damn, sounds like a real money pit for you. Pretty soon you'll have a whole new WJ. What are you asking?
Build Thread
99WJ539918 is offline
post #24369 of 45326 Old 09-13-2013, 02:39 AM
Thomahawk
All ball joints
New axle seals
Rebuilt both diffs
New isolators
Bilstein 5100s
Fat bobs 2" springs
3/4" front spacers
Fuel filter
Trans filters
Kolak 3" exhaust
Heater core
New rotors and pads
Valve cove gaskets
Rear main seal
All new plugs
All new o2 sensors
New iac
Cam position sensor
Alternator
Starter
Battery
New rims and tires
Jy evic
Rb1
Radiator
Thermostat
Good reason to not give up and Fix the radiator,,
Buildthread
Thomahawk is offline
post #24370 of 45326 Old 09-13-2013, 03:27 AM
vagov
Attachment 671521
Attachment 671513
Attachment 671505
tail lights look great! a fulture mod i plan on doing as well. how do they look at night?
vagov is offline
post #24371 of 45326 Old 09-13-2013, 03:48 AM
bgohsman
All ball joints
New axle seals
Rebuilt both diffs
New isolators
Bilstein 5100s
Fat bobs 2" springs
3/4" front spacers
Fuel filter
Trans filters
Kolak 3" exhaust
Heater core
New rotors and pads
Valve cove gaskets
Rear main seal
All new plugs
All new o2 sensors
New iac
Cam position sensor
Alternator
Starter
Battery
New rims and tires
Jy evic
Rb1
Radiator
Thermostat
See, now that you've done all of that work, selling it is kind of giving someone a gift. Lol. While it's frustrating to look back on a long list of new parts, don't forget to look forward at the increasingly short list of old ones.
Brandon Gohsman
bgohsman is offline
post #24372 of 45326 Old 09-13-2013, 03:50 AM
Thomahawk
Couldnt Been said better
Buildthread
post #24373 of 45326 Old 09-13-2013, 04:34 AM
cykaaro
Exaxctly. Feel that way about mine some days with all the isseus, but suspension replaced, ball joints, wheel bearins, seals, new engine etc. Better just fixing my steering issue than to seel and get something else and start all over again.
And as for that, alignment done, slight tweaked but issue still there and was done at the dealership. They think it's actually my intermediate shaft giving the issues. If you pull up on it there's play in it. Luckily I have another one that is pretty new (from the wreckers that someone replaced)
Now the question is, what's the best and easiest way to go about changine this out? By removing the steering column? or is there a simpler way I'm not aware of?
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #24374 of 45326 Old 09-13-2013, 05:41 AM
platinum5.9
2003 WJ
I did the same thing.... I would of preferred a regular vinyl sticker.
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #24375 of 45326 Old 09-13-2013, 05:57 AM
zephyr80
No hole for the sticker? There wasn't a place to put mine, i just said that looks good and stuck it to the dub.
zephyr80 is offline
wj
buns_1
