What did you do to your WJ today? - Page 1623 - JeepForum.com
 925Likes
post #24331 of 45352 Old 09-11-2013, 08:40 PM
HookEm
Originally Posted by rdkendrick View Post
Well, I certainly hope you took off your wheels and everything else you wanted before they came to pick it up. Can't believe they totaled it with no airbag deployment. Looks to be only a new fender, bumper fascia, headlight, and alignment.
Sent from my iPad using my fingers
I won't sign the title off until Friday, but I'll be removing all the stuff I've put on it tomorrow. That front bracket was crushed along with unibody damage behind the fascia and the pinch weld right at the fender was bent in somewhat too.
I'm fine with the outcome, though. Getting a better WJ and some extra cash for it.
HookEm is offline
post #24332 of 45352 Old 09-11-2013, 08:53 PM
wjidaho
I did the same when they totaled my limited, it was the best day of my life, I kept my system roof rack brush guard, best part when they paid me off I was able to find a better one and was able to buy my lift, tires and kc lights on it :-D love full coverage
My build thread
wjidaho is offline
post #24333 of 45352 Old 09-11-2013, 09:33 PM
aralph30
2003 WJ
Plasti dipped my door handles
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #24334 of 45352 Old 09-11-2013, 09:34 PM
aralph30
2003 WJ
2ndpic
aralph30 is offline
post #24335 of 45352 Old 09-11-2013, 09:34 PM
aralph30
2003 WJ
Also blacked out the gas door
aralph30 is offline
post #24336 of 45352 Old 09-11-2013, 10:31 PM
kodiakwj
2003 WJ
Did you mask off everything but the handle or did you just leave a square around the handle? I need to do mine along with my grill and rear hatch plastics.
kodiakwj is offline
post #24337 of 45352 Old 09-11-2013, 10:43 PM
wjidaho
I hear so much about plasti dipping, how long do it last will it with stand a pressure washer? I want to make some of my plastic look better. Just not sure witch way to go
My build thread
wjidaho is offline
post #24338 of 45352 Old 09-11-2013, 11:12 PM
DavisI
Itll hold up to pressure washing if its applied correctly. It may or may not hold up to being grabbed and pulled on the door handle though. I guess we'll find out
2002 WJ 4.7
4.5"/3.5" with 32"x10"
DavisI is offline
post #24339 of 45352 Old 09-12-2013, 01:29 AM
silentbob21
passed California smog with flying colors!!
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #24340 of 45352 Old 09-12-2013, 04:17 AM
HiPERnx
Did the rear wheel bearings, new parking brake and new discs + pads. Everything went well except for my calipers decided to give in. So needed new calipers. Now everything is back together and looking perfect!
Gustaf Nilstadius,
Jeep WG -99 v8, see ^ for full info
HiPERnx is offline
post #24341 of 45352 Old 09-12-2013, 04:41 AM
Thomahawk
You should paint Those calipers, would look NIIIICEEEEE.
Buildthread
Thomahawk is offline
post #24342 of 45352 Old 09-12-2013, 04:45 AM
4xTroy
4xTroy's Avatar
Changed the plugs @ 205k. They were worn to about 0.10! #6 was a little annoying, #8 was a PITA!
It might be my imagination, but I swear my subs (pair of 10's driven by a 400w amp) are hitting much harder since doing the plugs.
4xTroy is offline
post #24343 of 45352 Old 09-12-2013, 05:06 AM
Ravie
I suppose that is possible since the plugs would have been pulling the maximum amount of power from the coils to fire..
Today I put on the spacer brackets I made to complement my lift. HUGE PITA.
Time for work!
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #24344 of 45352 Old 09-12-2013, 06:12 AM
HiPERnx
The new calipers have some sort of coating, but the anchors need some 2 component caliper paint
Thinking of silver, that would look clean and stock.
Gustaf Nilstadius,
HiPERnx is offline
post #24345 of 45352 Old 09-12-2013, 09:27 AM
rickcricket
Searched the term "WJ" on eBay.....found a bunch of banana hammocks. Just FYI, don't search for just that!
rickcricket is offline
wj
alfaitalia , mak_v8
