What did you do to your WJ today? - Page 1620 - JeepForum.com
 874Likes
post #24286 of 45184 Old 09-10-2013, 09:38 AM
aralph30
2003 WJ
Originally Posted by scross1220
post some pics so we can have a look.
2nd
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #24287 of 45184 Old 09-10-2013, 09:45 AM
Locutus
Wj
Originally Posted by aralph30 View Post
2nd
do you have 5 of those? if so, how much?
Locutus is offline
post #24288 of 45184 Old 09-10-2013, 09:49 AM
Thomahawk
Got more parts pulled of the wreck today,
Exhaust, JKS trackbar, front swaybar with JKS QD, AC radiator and radiator, battery tray, coolant expantion tank, cruise control unit, AC compresor, purge solenoid, air intake and filter box, master brake unit, Steering fluid cooler, and disconected all wires/plugs to separated harness from engine,,,,,
Buildthread
Thomahawk is offline
post #24289 of 45184 Old 09-10-2013, 10:00 AM
aralph30
2003 WJ
I have 4 pm me
aralph30 is offline
post #24290 of 45184 Old 09-10-2013, 10:01 AM
brouwmat
Originally Posted by bgohsman
Well, not today but Sunday. My differential is going (gone) bad in the front. So I found a used front axle assembly with a good differential. Spent most of Sunday fighting the ball joints. Those things were IN THERE. Only one came out with the actual ball joint press. I bent my Craftsman breaker bar (using a 4' pipe on it) trying to press out the others. Ended up just taking an angle grinder, cutting them off and grinding the surface flat, perforating what was left with a drill and then beating it up with a cold chisel.
The next step will be to permanently repair the rusted coil spring perches. Turns out that mine don't look any better. Thanks Michigan Winters! Hoping to fabricate and weld up new ones this weekend. Will probably spend a couple of evenings removing rust and prepping the surface for sealing and painting. I have new ball joints, am going to replace the pinion and axle seals and put new coil spring insulators on. I don't want to ever have to do this again. lol
I used DOM tubing and a large washer to reconstruct my spring perches. Otherwise, I noticed that IRO now has new perches for the WJ (they still need to be welded on). They didn't have these back when I needed them.
http://www.ironrockoffroad.com/Merch...egory_Code=PFW
Not too bad for $30. I think I paid $15-20 for the materials alone and this one is half done.. Just cut off the old ones and weld on the new.
brouwmat is offline
post #24291 of 45184 Old 09-10-2013, 01:14 PM
steveandhiswj
Woke up to find a package at the door ended up being the new steering stabilizer still wait for the lift though
steveandhiswj is offline
post #24292 of 45184 Old 09-10-2013, 01:32 PM
alfaitalia
Its amazing what you can find at the bottom of the sea if you look! Thats quite serious "golden body lightener"!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #24293 of 45184 Old 09-10-2013, 02:01 PM
flightmedic238
2003 WJ
Took care of my evap codes cracked lines by the fuel filter. So far no codes.
flightmedic238 is offline
post #24294 of 45184 Old 09-10-2013, 02:23 PM
bgohsman
That's good to know! Thanks!
Brandon Gohsman
bgohsman is offline
post #24295 of 45184 Old 09-10-2013, 02:23 PM
Jaketit
I've checked those lines and took the bumper off so many times I forgot, still to no avail. P04456 P 0044. I've been driving with that light on for awhile now. I figured I'd check the codes again the other day, now I have the clockspring code. Just piling them on.
Jaketit is offline
post #24296 of 45184 Old 09-10-2013, 02:41 PM
bgohsman
O.k., spent several hours removing grease, dirt and crud. There turned out to be a nice looking axle assembly under all of it. Factory paint and stickers were even still there. Took a wire brush attachment on a drill and cleaned off all of the loose rust and crud on the ends. After that, the coil spring perches were the only areas that still looked horrific. De-greased the whole thing and coated it with Eastwood's rust encapsulator. After I weld new perches on, I'll paint the entire thing with Eastwood's chassis black and install the new ball joints. While it's out, I'm also going to change the pinion and axle seals. I have no intention of taking this apart again. lol
Brandon Gohsman
bgohsman is offline
post #24297 of 45184 Old 09-10-2013, 03:04 PM
cr8zynelly
Ordered a Heater core and a EVAP core.
Now I'm just debating how much to do while I have the dash out. The blower quit working and I'm not sure the exact root of the problem. If I purchase a blower motor from rock auto would I also need to purchase the resistor so I don't have the melting plastic connector again or does it come with the blower motor?
I'm also going to do the blend air doors but I want to make sure I'm getting the right kit with with the beefed bits. The pic with the brown doors is from rock auto and the pic with the white doors is from JC Whitney. Both are part number 902307, I believe. So which is the right one?!
#confused.
cr8zynelly is offline
post #24298 of 45184 Old 09-10-2013, 03:39 PM
kodiakwj
2003 WJ
I posted the WJ for sale on Craigslist for $2900. Then I got a bunch of texts from people in Ohio and Minnesota telling me it was a surprise for there dad and to give them all my Paypal info so they could wire me the money. Decided to screw with them a bit. Surprised to find out that 3/4 of them were at sea and could only reply via text. Then they start asking what my profession was and I told them Federal Law Enforcement. No more texts after that.
kodiakwj is offline
post #24299 of 45184 Old 09-10-2013, 05:04 PM
99WJ539918
Looks good.
Build Thread
99WJ539918 is offline
post #24300 of 45184 Old 09-10-2013, 05:38 PM
JeepNowski
Got a new engine code and began trying to figure out the cause and fix it.....Engine code is P1494.
Leak Detection Pump Sw or Mechanical Fault
Incorrect input state detected for the Leak Detection Pump (LDP) pressure switch.
Researching fixes on other tabs as I type this....
JeepNowski is offline
wj
