What did you do to your WJ today? - Page 1607 - JeepForum.com
 1003Likes
post #24091 of 45543 Old 09-05-2013, 09:51 AM
brouwmat
Originally Posted by Merc1973
What is that?
I installed a new intermediate steering shaft last night. It cleared up about 50% of the steering slop but it's still there and wanders on highways speeds. Contemplating to tighten the steering box even though its new....
Your TRE's fine? The wandering on mine was actually worse when I tightened it. Stock pitman? Is it moving?
brouwmat is offline
post #24092 of 45543 Old 09-05-2013, 10:05 AM
Merc1973
TRE's are 4 years old (Moog), New Pitman arm (OMIX-ADA from Rock auto) was installed new with re-man. RedHead steering gear this year.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #24093 of 45543 Old 09-05-2013, 10:40 AM
brouwmat
Grab onto the sleeve (or the bar between the steering box and the axle) and try to twist it..also, do the same with the bar between the two wheels. Does it move or is it rock solid? If they are good you won't get very much twist at all (maybe slight movement).
brouwmat is offline
post #24094 of 45543 Old 09-05-2013, 10:52 AM
wsar10
2003 WJ
last nite some ****** bag hit the WJ while parked in front of our house,
I could have choked the ****er !
banged up the front fender in the worst possible place........ directly behind the front tire so it binds up the door
He at least had enough class to stop and knock on our door to fess up (even though it was caught on our camera's) so at least that save me from paying a deductible. We just had the rear end fixed a few months ago
front fender, door repair, probably front wheel and something under neath that is causing it to pull slightly....
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #24095 of 45543 Old 09-05-2013, 11:23 AM
Thomahawk
Feel your situation right on there, mine got keyed once, most useless crime ever, ppl Are simply **** heads, no respect for others properties, sad
To stay on topic, put out an ad for part out party for the old wreck, hopefully i can Get some more funds back That Way.
Buildthread
Thomahawk is offline
post #24096 of 45543 Old 09-05-2013, 12:22 PM
tigerfan2
Got the news today that I have to do a full rebuild of my transmission. And to think I only took it in for a service. Just empty every pocket.
tigerfan2 is offline
post #24097 of 45543 Old 09-05-2013, 12:25 PM
Merc1973
Tie rod (knuckle to knuckle) is Very stiff with little play. Drag link (from pitman arm to knuckle) rotates at least twice as much but stiff.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #24098 of 45543 Old 09-05-2013, 01:13 PM
brouwmat
That drag link could be it.. Anyone disagree? Mine is nice and tight and doesn't really move at all.
brouwmat is offline
post #24099 of 45543 Old 09-05-2013, 02:07 PM
doorjamm
Rotational play doesn't determine a worn out TRE, does it? I was under the impression side to side play is what determines that
doorjamm is offline
post #24100 of 45543 Old 09-05-2013, 02:18 PM
wjidaho
Let me guess from Amco? That happened to me on a Toyota a long time ago, they rebuild my tranny four time before I did it my self, never gone back never had a problem since :-D
My build thread
wjidaho is offline
post #24101 of 45543 Old 09-05-2013, 02:27 PM
brouwmat
When mine was shot I couldn't move them side to side.. They only rotated (I don't even know how you would test for that?). They also could've easily damaged them when putting in the new steering box. They aren't much and if they were off recently, they should be easy to replace. OReilly here tells me that they have a lifetime warranty if they are MOOG's.
brouwmat is offline
post #24102 of 45543 Old 09-05-2013, 02:58 PM
jeepinjeepin
Rotational play does not determine that a tie rod end is bad. Play parallel and perpendicular to the shaft does. They are a ball and socket type joint. They must be able to rotate to do their job. That being said, a new rod end will be tougher to rotate than a worn end.
jeepinjeepin is offline
post #24103 of 45543 Old 09-05-2013, 03:28 PM
99WJ539918
That sucks, but you're lucky enough to have had the person knock on your door. They at least gave you the courtesy of doing that, just not watching where they were going.
Build Thread
99WJ539918 is offline
post #24104 of 45543 Old 09-05-2013, 03:40 PM
brouwmat
Originally Posted by jeepinjeepin
Rotational play does not determine that a tie rod end is bad. Play parallel and perpendicular to the shaft does. They are a ball and socket type joint. They must be able to rotate to do their job. That being said, a new rod end will be tougher to rotate and a worn end.
I think we are talking about a different type of rotation.. I know that the joint needs to turn left and right but should he be able to roll them on the pitman and wheel joint?
brouwmat is offline
post #24105 of 45543 Old 09-05-2013, 05:01 PM
tigerfan2
No it's actually a local shop. He is honest and does a good job. Fixes any defects or problems from the factory and had a good warranty too. So I'm not too worried about it. Just sucks that it happened.
wj
Currently Active Users Viewing This Thread: 5 (3 members and 2 guests)
GC2013 , jamesrw30 , MrAnderson83
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
