What did you do to your WJ today? - Page 1604 - JeepForum.com
 828Likes
post #24046 of 45036 Old 09-03-2013, 09:29 PM
cykaaro
Rear fog lights are not very common here at all. (they're pretty common in some European countries, and there are laws that govern them). I've seen a few audi's with them stock. They're basically a rear facing light that is red. Some vehicles have one. The audi's I've seen have two mounted where the license plate is, so they're entirely seperate from the brake lights so they won't be mistaken for brake lights.
Basicaly in bad fog, they are put on, and as bright as brake lights so that a vehicle can see you easier and hopefully not rear end you. I ill have them on their own switch separate from the stock fogs.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #24047 of 45036 Old 09-03-2013, 09:41 PM
cr8zynelly
Video Link: http://www.youtube.com/watch?v=jINrFUW7MKk
Like the SRT-8 Jeep conversion a lot of people do.
cr8zynelly is offline
post #24048 of 45036 Old 09-03-2013, 10:19 PM
cykaaro
Have never seen a jeep with rear fogs before.
cykaaro is offline
post #24049 of 45036 Old 09-03-2013, 10:35 PM
aralph30
2003 WJ
I have never seen that before !!
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #24050 of 45036 Old 09-03-2013, 10:54 PM
cykaaro
Great for bad fog, or winter blizzards
cykaaro is offline
post #24051 of 45036 Old 09-03-2013, 11:11 PM
aralph30
2003 WJ
Okay I got a problem. U guys saw the rims I put on correct ? We'll my old rims used to have something in them that would tell me the tire pressure in my tires. I guess they didn't swap them over with the new rims and I went to check my tire pressure before and their where no readings for any of them
aralph30 is offline
post #24052 of 45036 Old 09-03-2013, 11:16 PM
gcjeeping
gcjeeping's Avatar
I just did a quad tail light mod about 8 years ago.
_____________
gcjeeping is offline
post #24053 of 45036 Old 09-03-2013, 11:42 PM
cr8zynelly
Like this?
post #24054 of 45036 Old 09-04-2013, 12:07 AM
wjidaho
Originally Posted by cr8zynelly
Like this?
Man I am not sure if I like that looks like a tuner to me but idk :-$
My build thread
wjidaho is offline
post #24055 of 45036 Old 09-04-2013, 02:07 AM
alfaitalia
Fitted new left side front window regulator................ 20 mins from door open to door closed.........mind you I have had quite a bit of practice taking those poorly engineered pieces of crap out!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #24056 of 45036 Old 09-04-2013, 04:03 AM
cykaaro
Originally Posted by cr8zynelly View Post
Like this?
Can't tell if they're part of the brake lights or their fogs with the brakes on (see edit below), but yes, kinda the idea, but I'm not about to cut up my bumper. Have a couple ideas. Might use the hatch by the license plates, or may use underneath the bumper tying into the trailer hitch.
They do exist for the WK2 as a kit though http://www.quadratec.com/products/97047_1004.htm
Last edited by cykaaro; 09-04-2013 at 04:10 AM. Reason: make that I found a conversion for them so yep, they have them. Neat.
cykaaro is offline
post #24057 of 45036 Old 09-04-2013, 06:32 AM
cr8zynelly
That's the part that usually fails. I just drilled a small hole through the plate very near the broken block and hammered the cable end nipple through it. since the pull on the cable is sideways it won't go anywhere.
So you pulled the regulator out to do this?
I replaced my entire front passenger regulator because the plastic clip broke and I got one off eBay for cheap.
Now my drivers side rear window will not roll all the way up. It goes down fine but rolls up slow and stops 2" before closing?? I cant even help pull it up the rest of the way. I pulled door panel and speaker and can't see anything broken but at the same time there is very limited viewing thru the available holes in the door.
Also, has anyone replaced the plastic door lining? Mine was so dry rotted that it just crumbled and now the door rattles when shutting.
post #24058 of 45036 Old 09-04-2013, 06:36 AM
chargold98
Bought it!
chargold98 is offline
post #24059 of 45036 Old 09-04-2013, 07:41 AM
rdkendrick
2003 WJ
Originally Posted by 03azwj View Post
Took it to the store today and saw this in the parking lot. Mobile Pepto Bismol ad possibly??
That is Barbie's Jeep. She was probably inside, shopping :-)
Sent from my iPad using my fingers
rdkendrick is offline
post #24060 of 45036 Old 09-04-2013, 07:44 AM
Ravie
Did some trimming on my front bumper last night. I wish I could just relocate the facotry fogs instead of having to eventually cut them out. I don't have big tires yet so they're staying in until I can afford some LED's!
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
wj
alferro
