What did you do to your WJ today? - Page 1601 - JeepForum.com
 554Likes
post #24001 of 43581 Old 09-02-2013, 12:40 PM
ialatham4
Originally Posted by aralph30
Had my angel eyes wired up and fogs installed lmk what u guys think
Where did you get them they look good
ialatham4 is offline
post #24002 of 43581 Old 09-02-2013, 12:42 PM
JeepsOLot
Yesterday, swapped out the 2WD axle beam with the '00 D30 with 3.73 Vari-Lok gears. I swapped the '04 calipers, caliper brackets, and rotors over to the D30, worked like a champ! Everything from the ABS sensors to all control arms, track bar, and drag link hooked right up to the D30, no mods needed. Today, I installed the OEM front skid plate, which I found at a junkyard for $15! Here's a pic of both items:
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #24003 of 43581 Old 09-02-2013, 01:19 PM
doorjamm
Originally Posted by Thomahawk
Tested the 2.7CRD GC not long time ago, seriously lack of torque and power vs the V8, very tractorish feeling, i will deff Go for a V8 again.
The 4BD2T is a 3.9L iirc. The thing is, with minor mods, you can make them ridiculous. I've even read in instances where they increased max rpm to 5k with an output of 500hp and 800+torque.
I think the biggest thing about going diesel is the 30+mpg, the incredible amounts of torque, turbo, and blowing smoke (yes I'm one of those guys). Oh! And manual transmission
doorjamm is offline
post #24004 of 43581 Old 09-02-2013, 02:26 PM
north50
Removed Viper alarm the PO had put in the Jeep. It was nothing but in the way and draining my battery so off with its head.
north50 is offline
post #24005 of 43581 Old 09-02-2013, 02:29 PM
99WJ539918
Originally Posted by cykaaro View Post
Thanks! The drivers side is still a little off and need to straighten, but not by much. THey're amazingly brighter than the stock ones, even with 9005's in them.
Yeah, looks so much better than my stockers with 9005's.
Build Thread
99WJ539918 is offline
post #24006 of 43581 Old 09-02-2013, 02:30 PM
99WJ539918
Jerry
Good job on the install. Did you paint them or were they painted before you got them?
Build Thread
post #24007 of 43581 Old 09-02-2013, 02:31 PM
99WJ539918
Holy crap, that's a lot for an alarm!
Build Thread
post #24008 of 43581 Old 09-02-2013, 02:44 PM
JeepsOLot
Thanks, I did paint them, but, they need another coat as the install did give both pieces some scratch marks. I knew this was going to happen, so, it's all good.
Jerry
post #24009 of 43581 Old 09-02-2013, 03:59 PM
north50
It was unreal the amount of crap they had spliced in and running all over the Jeep. It caused nothing but problems to the ignition and then a constant draw on the battery. The WJ feels more reliable already.
north50 is offline
post #24010 of 43581 Old 09-02-2013, 04:05 PM
alfaitalia
You will be lucky to get 20 to the gallon out of one of those though.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is online now
post #24011 of 43581 Old 09-02-2013, 04:19 PM
Thomahawk
Originally Posted by alfaitalia
You knew I would have to reply to this didnt you?!!
Oyeah, lol
Buildthread
Thomahawk is offline
post #24012 of 43581 Old 09-02-2013, 04:21 PM
doorjamm
Someone on here did it and say the got up to 35 with 3.08s I think
doorjamm is offline
post #24013 of 43581 Old 09-02-2013, 06:00 PM
cykaaro
Much brighter for sure! You just might have to do a retro now! LOL
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #24014 of 43581 Old 09-02-2013, 08:30 PM
WJ_allday04
Just purchased my anti/go-away death wobble kit (all new TRE's , upper and lower ball joints and rear ball joint) from jeep 4x4 center. After install, the WJ is off for another alignment with hopes of eliminating DW.
2004 WJ 4.7 - 7in lift
Rustys Long Arms//Rustys f+r springs//Rustys crossmember
CSL RLCA//Poly D30 bushings//IRO A arm
Skyjacker Nitro's//JKS trackbar//242HD+IRO SYE
WJ_allday04 is offline
post #24015 of 43581 Old 09-02-2013, 08:31 PM
rdkendrick
2003 WJ
Installed LED's in my reading lamps, courtesy lamps, cargo lamp, installed a Jeep sticker on my high-mounted 3rd brake light and put an LED in there as well as my license plate lights. Already had LED brake lights. Found that I ordered the wrong lamps for the EVIC and climate control. I ordered the twist in lamps for the EVIC, but that won't work for the climate control, as they have to be soldered in. What did you all order for those?
Replaced the wife's radio in her 2000 T & C, but I'll have to modify the bezel, as her old radio was square, and the newer one is the rounded type factory radio, with a built-in aux jack.
Today, I started my RB1 install. Got my radio in, but started to get too dark to get my iPod integration kit installed. I'll have to do that later. Where did you guys put your box for the iPod integration kit? I read where one guy found room to put his in sideways, beside the radio, but there's no room. Only place I can see is under the cubby hole/power outlets/seat-heater switches.
Sent from my iPad using my fingers
rdkendrick is offline
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
