What did you do to your WJ today? - Page 1578 - JeepForum.com
 908Likes
post #23656 of 45328 Old 08-19-2013, 04:06 PM
wjidaho
Originally Posted by Highschool_WJ
Drove down to the shop to schedule an appointment to have the CSP sensor changed (don't have time to do it myself with college starting) and never made it out of the parking lot, it stalled out while pulling onto the street so we pulled it back into the lot and left her :/
I did the same at the start of the summer I hate the CSP lol
My build thread
wjidaho is offline
post #23657 of 45328 Old 08-19-2013, 05:45 PM
tkcarp01
Was in (b)Lowe's today grabbing some quick hardware stuff, and thought hey.. I'll get a valet key made in case I lock my one and only sentry key in the dub. Nope. Guy at the counter says be won't do it, because if I open my door with it I'll "fry my computer". After a quick lecture on why he was an idiot I excused myself and left.
tkcarp01 is offline
post #23658 of 45328 Old 08-19-2013, 06:07 PM
go-big
Lmao that's the best hahaha
go-big is offline
post #23659 of 45328 Old 08-19-2013, 06:23 PM
cykaaro
LMAO!! love how people think the strangest things. Have one with my house keys just in case I lock my keys in.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #23660 of 45328 Old 08-19-2013, 06:23 PM
CrazyWalnut13
Took measurements for longer bumpstops and tried to find out places to shove some limiting straps in the front end. Don't want anymore of this:
or this:
Thinking about using some paracord for the straps, and some self tapping screws and some sort of bracket/loop on the top (frame side) strap mount. And since I have IRO's long arms, the passenger side strap can use the (now un-used) right upper control arm mount on the axle. I'll have to get creative the the axle side mount on the driver's side. I'm thinking of either drilling into the caster adjustment bracket on the upper CA, or maybe just adding a bracket onto one of the bolts on that bracket.
I think the hardest part of the straps will be avoiding the exhaust. But maybe some strategic heat wrap around some pipes will help to extend the life of the paracord. It'll be a learning experience for sure. I'll definitely take lots of notes and pictures and then do a write-up on the limiting straps. There is almost no info online about limiting straps for our WJs, so I'm hoping I can start a revolution.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #23661 of 45328 Old 08-19-2013, 07:01 PM
sinbad85
or this:
Get some IRO upper retainers and lower retainers and it will keep the springs on, When I went out the first time with my Bilstiens I dropped a coil as well, I ended up welding a 3" piece of exhaust pipe to the top perch instead of buying some, lets the coil come unseated but it guides it back in.
2001 WJ 4.7L-selec-trac/4.5" Teraflex springs\IRO Long arms\Iro adj rear LCA/Bilstien 5100 series shocks/ IRO steering Equalizer/|265/75/16 Goodyear Dura-Tracs on Stock rims\Rear Tube Bumper with carrier|sliders|mopar skids.
sinbad85 is offline
post #23662 of 45328 Old 08-19-2013, 07:15 PM
CrazyWalnut13
I messed up the IRO mounting holes when installing the lift. One of them, I tried eyeballing the tap size and got it wrong, went too big (and metric). The other side went in (after I read the instructions), but then fell out after about 2 miles of gravel road. So I've been without spring retainers.
Zak
post #23663 of 45328 Old 08-19-2013, 08:05 PM
gcjeeping
gcjeeping's Avatar
Drove it around this weekend and the temp stayed a little above 210 most of the day. It usually stays below 210. So I swapped the thermostat out (Original) and got around to installing the the aux fans I got from the JY a couple years ago.
They are of a 4L Land rover. They push a lot of air and turn the stock fan when they are on.
Wired them up to come onto with the stock fan and or by themselves with the switch on my Whelen controller.
Drove it around today in 100+ temps and didnt go over 210.
_____________
gcjeeping is online now
post #23664 of 45328 Old 08-19-2013, 08:28 PM
JerzeyBoyWJ
2003 WJ
Affordable supercharger for the 4.0 emailed the guy and said it would fit a wj
http://rickrimmer.com
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #23665 of 45328 Old 08-19-2013, 08:45 PM
cykaaro
Now that would be fun to add on!!!! Wonder if it'll work with stock internals, or you would have to upgrade at all.
cykaaro is offline
post #23666 of 45328 Old 08-19-2013, 09:01 PM
evilcairn
I do the same thing @ my last Week end .. after the mud hole, my coil bump out ..
Up and Down retainer ... yeah yeah ... need ^^
WJ 2001 V8 , 6.5" lift IRO , 35" BF , Front DS TomWoods mutilCV, Fender Iceland, TrueTrac Eaton Front, Gears 4:56 , Custom Front bumper, custom rock slidder ....
evilcairn is offline
post #23667 of 45328 Old 08-19-2013, 09:28 PM
Islanders22
Got a 2" bb lift and some 31" at tires. Love it,
Islanders22 is offline
post #23668 of 45328 Old 08-19-2013, 09:59 PM
1999wjlimited
Finally got my bumper and winch put on. It took longer than I wanted to but it's finally on.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #23669 of 45328 Old 08-19-2013, 10:11 PM
wjidaho
I know right, sure got me thinking too ;-)
My build thread
wjidaho is offline
post #23670 of 45328 Old 08-19-2013, 10:14 PM
99WJ539918
That's pretty cool. If I can run stock internals it'll be cheaper, but less powerful, than going for a stroker build. I wonder why it doesn't say anything about fitting a WJ, though.
Build Thread
99WJ539918 is offline
wj
