What did you do to your WJ today? - Page 1567 - JeepForum.com
 561Likes
post #23491 of 43610 Old 08-10-2013, 11:30 PM
rdkendrick
2003 WJ
Originally Posted by Woliwi View Post
Went for Woliwi's first post lift test drive up my local hill....Otay Mountain.
Is that where Buckwheat was from :-D
Sent from my iPad using my fingers
rdkendrick is offline
post #23492 of 43610 Old 08-11-2013, 01:49 AM
99WJ539918
Originally Posted by Jer-Bear View Post
Well, once you get one rebuilt, its nearly two grand. It makes sense to me to buy a low mileage one at a fraction of the price.. Idk, I'm cheap, but I expect mine I just put in to last another 150k. And actually the other day on EBay I saw a brand new Mopar 45RFE. Said it was brand spanking new. So maybe they're our there, maybe not.
Unless that transmission has been on a shelf for years it's not new. No one makes the housing anymore so there can be no "new" transmissions, only ones that have been rebuilt with new parts on the inside - commonly referred to as "new" (I referred to a new trans in my first post about this) even though they're not "new."
I agree with you, I'm cheap, too. I would get a low mileage used trans or rebuild my own if my trans ever went. Having the 42RE I guess I should say "when" and not "if."
**Edit - I just saw you that you were talking about the 545RFE. Since they might still use that setup in other vehicles Chrysler would still make them new, unlike the 42RE.
Build Thread
99WJ539918 is offline
post #23493 of 43610 Old 08-11-2013, 01:51 AM
99WJ539918
Your sig should say "Sent from 1955" after that comment.
Build Thread
post #23494 of 43610 Old 08-11-2013, 04:04 AM
Trixie369
Originally Posted by scross1220
Very easy to do. Go to the ebay link below to get them.
http://www.ebay.com/itm/New-Cool-Whi...item4854dce3c0
Tap into the courtesy lighting such as the light under the dash and you are set to go.
Thank U
" Jeep, Nothing above - Only below"
Trixie369 is offline
post #23495 of 43610 Old 08-11-2013, 05:09 AM
Sarjam
2003 WJ
Where did you buy your LED bulbs from? Did you have to use any resistors?
I got all mine from superbrightleds.com, they have a bulb finder on the site that tells you exactly what is needed etc. I did not need any resistors, all were pretty much plug and play. I did all the overhead lights in cool white and the gauges in blue. It made a HUGE difference.
I Just
Sarjam is offline
post #23496 of 43610 Old 08-11-2013, 06:29 AM
Thomahawk
Sold the Girly Jeep's old stock Winter shoes for a great amount of $, to fund more wheels'n tires and other upgrades
Also put out an ad for my nearly new winter wheels, 18's Sahara's with 255/60/18 Nokian Hakkapelitta R SUV tires, hopefully i can Get back most of my money.
And put them towards full size 31" Winter tires, so its aint looking funny and stupid in Winter.
I will deff Go for Hakka's again, but this time in size 255/70/17, also need to start looking for some new 17's wheels.
Buildthread
Thomahawk is offline
post #23497 of 43610 Old 08-11-2013, 07:09 AM
scross1220
2012 WK
So, I am assuming the reddish dots are copper, and you just solder the wires to them?
Yes and cut and peel the clear stuff off the contacts
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline
post #23498 of 43610 Old 08-11-2013, 07:31 AM
SierraRipper
Originally Posted by scross1220 View Post
A Craftsman socket would not do that. You need better "Control" Ha Ha Ha
They're all craftsman haha except the top middle one. Thats a duralast,
SierraRipper is offline
post #23499 of 43610 Old 08-11-2013, 08:59 AM
cykaaro
I had to redo my under carrage lighting. The lift crushed some of my LED's. Move them to the under frame to avoid damage next time. These light only come on when I unlock or open the doors. I love them so much I had to do an encore posting. I am doing a strip of Hi-temperature in the front grill tonight.
Looks good. Always doing lighting on mine. Installed a strip in the back, already have them in the grill. Havent' dealt with underneath as of yet, although Ive done the front doors.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #23500 of 43610 Old 08-11-2013, 09:31 AM
scross1220
2012 WK
Do you have a pic of what you have in the grill? I want to do the same thing I just do not want to melt them.
______ooooo
/__l_l_,\____\,___
post #23501 of 43610 Old 08-11-2013, 09:52 AM
cykaaro
I've used amber. They're in just behind the grill in front of the rad. One top side, one on the bottom. No issues with them melting at all. Harder part is having them stay in place.
Did this this past weekend. Tons of light for seeing in the back now.
5050SMD. They're not waterproof, but then again, don't really need to be.
Got my front LCA's that will go in tomorrow as well as an oil change. Got new stickers for my lift gate window so they'll be going on today. Back to normal. It looks naked right now.
Hit the wreckers and was a free parts day. $50 all you can carry. Picked up various engine parts that were virtually new off of one, coil pack, another grill, seals that I need to replace, and other small odds and ends. Another rear tailgate glass, just in case, and a cooler from a V8.
Cooler was attached to the fan/steering box. I'm thinking of using it as a tranny cooler. How best though to flush it out properly and use it as a tranny cooler though? Don't want the steering fluid to screw my tranny.
cykaaro is offline
post #23502 of 43610 Old 08-11-2013, 10:37 AM
scross1220
2012 WK
Very nice indeed. Did the cooler some months ago and a fluid change. As for the LED's I used crazy glue on the back side. When you have a chance take a photo of your grill. I like to see it. I like the back LED's you did. I may do the same to give off some more light. I Changed all my lights to LED's but now I have a very slight glow when driving since they are a low draw. I will fix it by adding a load resistor to the circuit.
______ooooo
/__l_l_,\____\,___
post #23503 of 43610 Old 08-11-2013, 11:50 AM
jeepinjeepin
Originally Posted by PHAL23
I have a 25 as well...hopefully they'll have like a 5 and that'll work or something around that size
25' isn't overly long. Look for a 1/2" diameter hose in whatever length you need. Another trick I've pulled before is using a second tank with a T fitting as a surge tank between the main tank and the tool. That way you have the compressor and tank, long hose to get to work area, tank, and short hose to tool.
jeepinjeepin is offline
post #23504 of 43610 Old 08-11-2013, 02:34 PM
Merc1973
Geesh... The highest quote I got for an install was $600, and I got a low mileage tranny for $150.
Originally Posted by 99WJ539918 View Post
His was new and not used like yours. $600 for trans install seems like a decent price. I can't find a low mileage trans anywhere for $150. Was that for your 2WD?
Cost of the re-manufactured tranny was $1990. Install (labor) was $540. The warrant was pretty decent. One of the largetst transmission shops wanted over $3k with a 24k mile/2 year warranty. I feel i got a good deal.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #23505 of 43610 Old 08-11-2013, 02:37 PM
11B-33T
Grumpy Vet
11B-33T's Avatar
Plasti-dipped the front grill outer bezel...
My girls said it reminds them of a panda bear so I've named the Jeep 'Po' after Kung Fu Panda...the Panda Jeep LOL..
11B-33T
- 2005 Ford Escape XLT AWD
- 2004 WJ Grand Cherokee SE
- 2003.5 Mazdaspeed Protege
11B-33T is offline
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
