What did you do to your WJ today? - Page 156 - JeepForum.com
 827Likes
post #2326 of 45008 Old 04-01-2011, 12:32 AM
Trevino
Hey akro, is that a custom bumper?? Or what brand, its pretty nice man.
Trevino is offline
post #2327 of 45008 Old 04-01-2011, 07:40 AM
Akrobatiks
Thanks bro! Its the Kor stealth rear bumper/tire carrier...
2001 WJ Limited 4.7L Black on Black --- Interior Modifications... Alpine INA-w900 navigation unit, 2 9-inch headrest LCD's, Alpine PDX-F4 125w x 4 Multi-channel Digital amplifier, Alpine Type - X Component Interior Speakers, Alpine PDX-M12 1200w x 1 Digital Mono Sub Amplifier, 2 MTX - 9510's, Custom built subwoofer enclosure, Sirrius Satellite Radio, Backup Camera, Viper 5901 Remote start/alarm, Passport Escort 9500ci Radar Detector/Laser Shifter, Optima Yellow Top Battery, Cobra 29 LTD BT CB Radio --- Exterior Modifications... 6" Clayton Long arms, Bilstein 5100's, Addco Front and Rear Sway bars, IRO extended rear sway bar links, JKS Trackbar, JKS quicker front disconnects, IRO front upper and lower coil retainers, Rough Country Dual Steering Stabilizers, 17" Fuel Hostage Wheels, 285/70 Goodyear Wrangler Duratracs, Westin Safari bar, PIAA 525 dual beam off road lights, CCFL Halo Projector Headlights w/ Super Vision 6000k HID bulb kit, 100w PIAA 4000k halogen high beams, LED 360 Amber LED signal bulbs, LED Tail Lights, Jet Accu-Speed Computer chip, Flashpaq jeep power programmer, AVS rain gaurds, Yakima 4 Snowboard rack, Curt tow strap receiver mount, Hornblasters Shocker 240 Train Horn Kit, Rigid E-Series 40" LED light bar, Mean Green H.O. Alternator, JCR Stage 3 Sliders, Blue Torch d30/d44a diff covers, KOR Steath rear tire carrier/bumper. LSR winch mount front bumper, Warn xd9000, KOR under Belly skid...
Akrobatiks is offline
post #2328 of 45008 Old 04-01-2011, 12:03 PM
EisBlade
EisBlade's Avatar
Wj
Originally Posted by Bmeckman View Post
so is that you way of saying it would not effect the way the rear will behave?
when i took off the part where the stock link was connected to the syawbar and just the portion of the link that was attached was to the unibody was connected the swaybar link would not even pivot, its like the bolt was too tight..would that cause the rear suspension to be more stiff, or would the rear HD OME spring have more of an impact on that? Is this question better suited for a different section of the forum? just trying to get a correct understanding of this. I i design catalogs and such for a living so this is not my expertise
lol...Nothing was meant though I see what you're asking. Sway bars only make a difference when cornering. Think about what happens to your Jeep in a sharp turn. If you are inside the Jeep, your body gets pulled toward the outside of the turn and you'd be up against the door if you didn't have a steering wheel to hang onto, seat bolsters, and even seat belt. Well, the same effect is happening to all the parts of the car suspenion. The part of the Jeep on the outside of the turn gets pushed down toward the road and the part of the car on the inside of the turn rises up. In other words, the body "rolls" toward the outside of the turn. If you take a turn fast enough, the tires on the inside of the turn would actually rise off the road and the car would flip if things continue.
Roll is bad. It tends to put more weight on the outside tires and less weigh on the inside tires, reducing traction. It also messes up steering. What you want is for the body of the car to remain flat through a turn so that the weight of the Jeep stays evenly distributed on all four tires. [insert sway bar] The sway bar (AKA: stabilizer bar) tries to keep the car's body flat by moving force from one side of the body to another. The sway bar; being a long tempered rod of steel with a bend at each end forming 'arms', is a spring. It's center section is attached to the frame and the two arms are attached to each side of your Jeep. All points attached need to flex. Up/Down bumps simply push up both arms at the same time, and the center section of the sway bar pivots up and down.
When you go into a turn, the front suspension member of the outside of the turn gets pushed upward. The arm of the sway bar gets pushed upward, and this applies torsion to the rod. The torsion them moves the arm at the other end of the rod, and this causes the suspension on the other side of the Jeep to compress as well. The Jeep's body tends to stay flatter in the turn than if without a sway bar at all. (Upgrade to Addco or another brand, and the increased rigidity provides even better resistance to the rolling effect)
Without a sway bar you'd have a lot of trouble with body roll in a turn. If you have too much stabilization (ie. mismatched sway bar for your vehicle), you tend to lose independence between the suspension members on both sides of the car. With the latter, when one wheel hits a bump the stabilizer bar transmits the bump to the other side of the car as well, which is not what you want. The ideal is to find a setting that reduces body roll but does not hurt the independence of the tires.
Hope that helps.
Anything worn or, in your case frozen stiff, detracts from things performing as they should. Replacing worn parts always improves something somewhere. And when you bring the butt dyno(meter) into the picture; it seems to always help any of us feel better after having thinned out our wallets.
JT
Facebook: Harley-Davidson Touring Group
EisBlade is offline
post #2329 of 45008 Old 04-01-2011, 12:16 PM
EisBlade
EisBlade's Avatar
Wow, that's a very nice bumper. What's your opinion on the hinges and closure mechanism? Oh, and when driving and looking into the rearview mirror, how much does the tire block from what you can see behind you?
EDIT: Oh, I just saw a better pic of the back window on your build thread. You can't see anything except incoming missiles when looking over the top of the tire. lol
Thanks.
JT
EisBlade is offline
post #2330 of 45008 Old 04-01-2011, 12:48 PM
Akrobatiks
Thanks.
Thanks bro! It's solid and functional mechanically... you can still see out the back window a bit, but it doesn't really bother me since I can just turn on the backup camera if I really need to see back there...
post #2331 of 45008 Old 04-01-2011, 01:17 PM
Son-of-Beast
Used the Meguiar's Headlight restoration kit to remove a fair amount of oxidation and yellowing from the passenger side headlight - sorry no before and after shots but I can report it worked reasonably well, especially for only a $10 kit.
Comes with 4 stages of varying grit sanding pads, a polishing compound, a spray lube for the sanding process, and a cleaner/sealer. Probably took about 35 minutes start-to-finish (2 polish and sanding efforts) and I am very happy with the improved clarity of the lens, beats $120 for a replacement.
'Son-of-Beast' - '02 WJ Limited, 4.7, 545RFE 5-spd Auto, Quadra-Drive, KOR 2.5" BB, Rancho RS5000's, Firestone Destination AT 265/70R17's, Flowmaster DeltaFlow 40, KMA/TAG armor, JK Fuel Door, Spyder CCFL Halo Projectors, LED Taillights, LED Interior Lights - Build Thread:
Son-of-Beast is offline
post #2332 of 45008 Old 04-01-2011, 01:27 PM
Bmeckman
Thank you EisBlade.....good description of the "job" of the swaybar....much appreciated!!
Bmeckman is offline
post #2333 of 45008 Old 04-01-2011, 01:59 PM
Scibbyz99WJ
Eisblade. You should add that to the faq!
'99 stroked 4.5L WJ 2" BDS lift
2008 Fire Red F150 XLT 4X4 3V 5.4LV8
Closed minds should go hand in hand with closed mouths
Scibbyz99WJ is offline
post #2334 of 45008 Old 04-01-2011, 03:55 PM
Phoenix1120
Had a new magnaflow put on. Sounds so much better!!!
Phoenix1120 is offline
post #2335 of 45008 Old 04-01-2011, 04:15 PM
suncrest08
What magnaflow did you put on and are you getting any drone inside the cab.
04 WJ Freedom Edition Silver
4" Zone lift. 3/4" KOR spacers. Addco rear sway bar. KOR Steering Stabilizer.K&N FIPK. Spidertrax 1.5" wheel spacers. 265/70/17 Kelly Safari TSR. Custom 3" exhaust
suncrest08 is offline
post #2336 of 45008 Old 04-01-2011, 05:28 PM
Phoenix1120
I really don't know what one it is. A friend bought two off eBay and I got one from him. No drone sound at all and I can hardly even hear it on the highway. Sounds like flowmaster somewhat minus the drone sound. I am very pleased.
post #2337 of 45008 Old 04-01-2011, 06:15 PM
Steve01WJ
2005 WK
Slid it into the chics jeep thanks to the snow. Tail light to tail light. Thankful for no body damage. Just new lights.
12 JKU, 2.5TF BB, MTR 35s on 15"procomps
05 WK 5.7 Limited QD2
Steve01WJ is offline
post #2338 of 45008 Old 04-01-2011, 09:29 PM
CMac019
2003 WJ
Oil change, All new u joints, new air filter.
2003 WJ
V-8 242HD
CMac019 is offline
post #2339 of 45008 Old 04-01-2011, 11:04 PM
dustinova
Got the rear portion of the lift completed. I'll start on the front tomorrow.
2001 WJ Laredo - 4.0 - Zone 4" Lift, IRO Adjustable Front Upper Control Arms, Spidertrax Wheel Spacers, Hella 700ff's
dustinova is offline
post #2340 of 45008 Old 04-02-2011, 12:44 AM
alwaysHI
2003 WJ
^^^ is that 3" or 4"?
alwaysHI is offline
wj
volvite
