What did you do to your WJ today? - Page 1557 - JeepForum.com
 827Likes
post #23341 of 45017 Old 08-07-2013, 03:17 PM
rcwj04
Originally Posted by lord-steezus
Ive got 2 pans, the front pan has a drain plug, the pan further back beneath the bell housing does not, but says oil pan on it. The oil pan is definitely the front one, does that mean the trans pan is the one behind it.
...look at it this way, transmissions aren't in front of the engine. The oil pan in the front is under the engine and the oil pan in the back has a transmission above it.
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #23342 of 45017 Old 08-07-2013, 03:37 PM
cr8zynelly
Saw this while driving to work. . .laughed out loud and took a pic.
cr8zynelly is offline
post #23343 of 45017 Old 08-07-2013, 04:19 PM
brouwmat
Poor thing.. Look at it. Completely humiliated. Someone needs to save it or put it out of its misery.
brouwmat is offline
post #23344 of 45017 Old 08-07-2013, 04:21 PM
brouwmat
You sure? LOL.
brouwmat is offline
post #23345 of 45017 Old 08-07-2013, 05:04 PM
Jer-Bear
Are you trolling? Lol
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #23346 of 45017 Old 08-07-2013, 05:35 PM
scross1220
2012 WK
Originally Posted by wjidaho View Post
Which kit did you use I used the turtle wax one and it looks worse then before thinking about wet sanding this weekend
I used the 3M headlight restore kit and followed up with Meguires plastic scratch remover. The two works best and they look like new. It take patience but you will get there.
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline
post #23347 of 45017 Old 08-07-2013, 05:40 PM
wjidaho
Thanks added to list to try before I bite the bullet and order new lights ;-)
My build thread
wjidaho is offline
post #23348 of 45017 Old 08-07-2013, 06:00 PM
scross1220
2012 WK
You will be happy with the results as I was.
______ooooo
/__l_l_,\____\,___
post #23349 of 45017 Old 08-07-2013, 06:58 PM
pyre24
i finally got my back up cam wired up. turned out the wire i put on head unit to splice into back up wire was bad. then i saw this on face book.
pyre24 is offline
post #23350 of 45017 Old 08-07-2013, 07:26 PM
99WJ539918
^ Nice, love a good Jeep meme.
I've been really busy the last couple of days. I haven't done anything with my grill guard, and now my airbag light goes on and off thirty times while driving to work. A new clockspring is in my WJ's near future. Where's the cheapest place to buy? Thanks, Jeepers.
Build Thread
99WJ539918 is offline
post #23351 of 45017 Old 08-07-2013, 07:34 PM
go-big
It works well but you have to wet sand the clear off the lights some times there is cracks in the glass but you can only see the cracks and specks with the lights on so it that bothers you you should not wast your time and just get new ones that's what I'm doing lol I used the kit and my lights look new but there is specks I think due to the heat of the bulbs
go-big is offline
post #23352 of 45017 Old 08-07-2013, 07:35 PM
go-big
That's the best Hahaha
go-big is offline
post #23353 of 45017 Old 08-07-2013, 08:02 PM
scross1220
2012 WK
I wet sanded using the 3M kit using 500 grit 800 1000 and 3000. Next I used the compound that came with it and finished it with Meguires pastic scratch remover. The tiny cracks you are refering is in the top surface layer and I was able to remove them without any issues. They make a version of the kit with a drill attachment which make the job go faster. The are a lot of after market headlight assemblies out there that seem to fade quickly within two years so its not worth the $100 or $200 to get them. A little elbow grease goes a long way.
______ooooo
/__l_l_,\____\,___
post #23354 of 45017 Old 08-07-2013, 08:13 PM
rdkendrick
2003 WJ
Does your cruise and the radio buttons buttons work ok? May not be the clock-spring. I replaced my clock-spring for nothing, but the experience. My problem was the ACM.
Sent from my iPad using my fingers
rdkendrick is offline
post #23355 of 45017 Old 08-07-2013, 08:21 PM
jeepinjeepin
Go ahead and plan on spraying a clear coat on them after you are done. That's what you are removing at first with the sanding discs. Without the clear coat they haze back over fairly quickly. Speaking from experience.
jeepinjeepin is offline
wj
alferro , wjmegan
