What did you do to your WJ today? - Page 1540 - JeepForum.com
 1091Likes
post #23086 of 45726 Old 07-28-2013, 11:43 AM
Thomahawk
Tried to QuickFix my leaking front diff cover by retighten the bolts, some i could turn a notch.
Cleaned down the mess and top it off, got about .1-.2 qts in there was not much leaked out
Also retightened the rear diff cover bolts, i have no leak, but still bolts can be tightens up, i guess the humpy mountain roads on the westcoast trip made them came loose a little.
Will keep an eye on the front, hopefully i dont have to pull the cover and RTV it again.
And remounted the front swaybar splash guard plastic thinghy, which have been around my Garage after the lift was mounted.
No Wonder why the mechanic did not put it back on, bolts and/or threads Are solid F up and rusted away, with all the patiance in my toolbox and huge amount of WD40 i got 1 broken, 2 in perfect, and 1 i had to give up out of 4 bolts, atleast its back on, phu
Found my fogs not working, broken wire one side, bad bulb on the other, found the OEM conectors full of corosion, might have to soldier and heat shrink Those conections to make them hold up against waterand salt.
Will look into fixing this soon.
Buildthread
Thomahawk is offline
post #23087 of 45726 Old 07-28-2013, 12:05 PM
cykaaro
Originally Posted by 99WJ539918 View Post
Took the crap driving lights off and then started to use my right angle die grinder on my new to me brush guard. It took the paint off, but not the rust. I'm going to have to step up and use a metal wheel now. I guess I'll be going to the hardware store tomorrow, at least it'll give me something to do tomorrow afternoon. Should look good once I paint it and then the cladding and front and rear bumper covers at the same time with the spray on bedliner. I'll post pictures once I get everything done.
I've heard a bunch of people say many different things about the difficulty level of removing the door cladding. Is it really that hard or bothersome to do? Should I just use newspaper and tape the upper part of the doors off? I'm worried about the paint running if I did that, though. Thanks for the heads up, fellas.
Cladding isn't hard to remove, but you have to be careful doing it. I did mine (since mine were bad and replaced it) starting from the bottom, and unattaching the foam tape used, and go up from there and carefull take them off. I painted mine off, but either way can work. Just do several light coats and you'll not have issues with it running. Just if doing on the vehicle have to be careful of overspray and tape it off well.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #23088 of 45726 Old 07-28-2013, 12:22 PM
rdkendrick
2003 WJ
Originally Posted by 4x4Jeep View Post
yes...brakes today
wheeled too hard i guess...stabilizer not sure when that broke, but the radiator support and tire happened when i hit this hole...
Did someone hide a big rock in there?
Sent from my iPad using my fingers
rdkendrick is offline
post #23089 of 45726 Old 07-28-2013, 12:33 PM
rcwj04
Originally Posted by 04dubjay
got my front ds from carolina in ! 4x4...finally
How long did it take to get yours? I ordered mine Monday and got it Thursday.
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #23090 of 45726 Old 07-28-2013, 02:42 PM
SierraRipper
+1 cladding is easy, like cykaaro said just start from bottom up. If you decide not to take it off and accidentally get paint on the jeep, just spray some wd 40 on a rag and it will come right off!
SierraRipper is offline
post #23091 of 45726 Old 07-28-2013, 04:28 PM
turrillas
Bull Bar
Originally Posted by bowhunter69 View Post
how much did you pay for the bull bar? and where did you get it?
I will pay $350, the guy where I take my WJ for the suspension sold it to me, I got a deal and will pay in 2 months. I know hims so He gave me the credit. He got it from 4 wheel parts.
turrillas is offline
post #23092 of 45726 Old 07-28-2013, 04:59 PM
4x4Jeep
center was hard, rest of it was soupy so it sank.
just got finished with doing my front pads...got rained out and getting dark so i'll have to do the rears tomorrow.
Build -
SOLD
4x4Jeep is offline
post #23093 of 45726 Old 07-28-2013, 05:15 PM
pinky2252s
It gets dark at 7 over there? Doesn't get dark till around 9 here.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #23094 of 45726 Old 07-28-2013, 05:28 PM
FlyRLo
How I spent my day.. yay me!
FlyRLo is offline
post #23095 of 45726 Old 07-28-2013, 06:07 PM
jeepinjeepin
I swapped the cheapie antenna mount for a heavy duty mount. SWR is good but could be better. I need to lengthen the antenna. That's a bit tricky with a fiberglass antenna with no tuning provision. A spring would help if I had the clearance for it.
jeepinjeepin is offline
post #23096 of 45726 Old 07-28-2013, 06:19 PM
1999wjlimited
Just go ahead and get a 102" steel whip antenna lol
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #23097 of 45726 Old 07-28-2013, 06:24 PM
jeepinjeepin
It's in that ballpark but glass.
post #23098 of 45726 Old 07-28-2013, 06:30 PM
dillonjm
2013 WK
You guys really wheel with those?
If you have any trees where you wheel that's an accident waiting to happen..
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #23099 of 45726 Old 07-28-2013, 06:48 PM
jeepinjeepin
No, I sold the TJ. The WJ is a road beater and beach rig.
post #23100 of 45726 Old 07-28-2013, 07:19 PM
1999wjlimited
No I have a 3' firestik to use then but I use the whip for normal driving because It picks up further away and I can still park in my garage with it pulled down which I can't do with the firestik.
wj
gcjeeping
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
