What did you do to your WJ today? - Page 1537 - JeepForum.com
 827Likes
post #23041 of 45008 Old 07-25-2013, 10:28 PM
Timbo24
Originally Posted by sinbad85
Jeep is looking sweet, Hope to see it in person some day!!
Thanks man I appreciate it. Once I finish it up we should wheel some time.
Timbo24 is offline
post #23042 of 45008 Old 07-25-2013, 10:33 PM
Timbo24
Originally Posted by wjidaho
Looking good Tim :-)
Thanks we all need a boise dub trip here soon
Timbo24 is offline
post #23043 of 45008 Old 07-25-2013, 11:57 PM
wjidaho
I got to fix my front end first started to hear clunking when it's locked in 4wheel, but yeah for sure :-)
My build thread
wjidaho is offline
post #23044 of 45008 Old 07-26-2013, 07:01 AM
Jaketit
Originally Posted by rdkendrick View Post
I'm using ForumRunner on an iPad and once I choose Jeep Forum, it stays on there the next time I open Forum Runner. In your Forum Runner settings, Push Notification settings, just turn on the "visit last forum" setting.
Sent from my iPad using my fingers
Well that's a little better thanks. 😃
Jaketit is offline
post #23045 of 45008 Old 07-26-2013, 07:19 AM
JerzeyBoyWJ
2003 WJ
9/16th grade 8 trac bar bolt upgrade
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #23046 of 45008 Old 07-26-2013, 08:08 AM
PeteYJTJ
Finally got it lifted, and got the new rubber on. 3" IRO + 10mm OME spacers all around, Bilsteins, new isolators, and 265-75-16 Goodyear Wranglers.
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #23047 of 45008 Old 07-26-2013, 08:22 AM
mudtrackerinc
mudtrackerinc's Avatar
Finally got my new lift installed.
02WJ Rough Country 4" Long Arm,3/4 spacers added to front,265x70x17C BFG All-Terrain T/A KO 31.8x10.7,super 44 flowmaster,K&N air filter,JKS adj track bar,JKS HD tie rod,JKS HD draglink,RCX dual stabilzer,Mickey Thompson Sidebiter wheels 17x9 4.5"BS,Saguaro4x D-Ring Mounts
06tj RC 4" X-series ,RC Dual Steering Stabilizer, 32x11.50x15 BFG All-Terrain T/A KO, 15x8 Ultra Motorsports Rogue
Model:175 Wheels, K&N CAI & Filter,super 44 flowmaster
mudtrackerinc is offline
post #23048 of 45008 Old 07-26-2013, 08:33 AM
Zacedward
Pete
Man your ride looks good I have a 2inch bb lift on mine but going to save up for the 3" looks way good how is the ride quality
UJC #181 2004 jeep Grand Cherokee 4.7L v8, 2"bb, kolak 3 " exhaust flowmaster 50 SUV , Rola roof basket, k&n cai,245/75 /16 A/T
Zacedward is offline
post #23049 of 45008 Old 07-26-2013, 08:49 AM
PeteYJTJ
Thanks. I've only had it on less than a week, but the ride quality is great. I can see the draw for the adco rear sway bar - she sways a bit. Probably just take some getting used to. I'm hesitant to put on the adco due to the tearing out of the rear frame/unibody mounts I've seen. I'll drive it like this for a while and see if it bugs me enough to do anything. Pete
PeteYJTJ is offline
post #23050 of 45008 Old 07-26-2013, 09:03 AM
Zacedward
Sweet can't wait to get my 3" did you install yourself
post #23051 of 45008 Old 07-26-2013, 12:10 PM
PeteYJTJ
Yes, installed it all myself, in the driveway. It came apart pretty easily for a New England Jeep at 9 years old. The drag link didn't want to turn, to adjust to center the wheel, when I was done, but an overnight soaking in penetrating oil and a pipe wrench got it to free up.
The driver-side uppper shock bolt under the hood is fun -- there's no access room for a wrench, and the shaft of the shock wants to spin when you turn the nut....
I did use a spring compressor to get the new springs in. Maybe if the Jeep were jacked up higher it would have worked without one, but with what jacks I had to work with I did what I could.
Took me all day to get it installed. Also did a Moog Trail Boss steering stabilizer.
Good luck
Pete
PeteYJTJ is offline
post #23052 of 45008 Old 07-26-2013, 12:25 PM
Jaketit
Pete
Looking good man. What do you think of the rola?
Jaketit is offline
post #23053 of 45008 Old 07-26-2013, 12:44 PM
PeteYJTJ
Thanks. I like the Rola a lot. It's a nice rugged rack. I was not a fan of the Rola mounting hardware, though, or the stock crossbars with their plastic ends. I replaced the crossbars with unistrut, and the Rack is so much more secure now. I can grab the rack and shake the Jeep back and forth.
Info on that is in my build thread.
http://www.jeepforum.com/forum/f197/...build-1473764/
Soon I'll be putting the tire up top, and making an air compressor / tool storage area out of the tire well.
PeteYJTJ is offline
post #23054 of 45008 Old 07-26-2013, 12:59 PM
Jaketit
Thanks man for your build thread. I was looking for a better way to fix that rack to my roof. I'm not feeling their mounting hardware either. Enjoy the new lift.
Jaketit is offline
post #23055 of 45008 Old 07-26-2013, 01:00 PM
Jeeples
Jeeples's Avatar
Extended rear sway bar links and Moog urethane frame/axle bushings will cure 99% of that feeling.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
wj
