What did you do to your WJ today? - Page 1530 - JeepForum.com
 912Likes
post #22936 of 45332 Old 07-23-2013, 09:55 AM
R0CKKR4WL3R
Radiator removal
Originally Posted by pinky2252s View Post
For the people who say that you can't replace the radiator on the 4.7 (hydro fan) without removing the AC condensor/Dis-connecting the AC lines-
Attachment 648107
Ran regular Non-hoat coolant for 12 years and the water pump looks good as new.
Attachment 648108
Also, a big bug I found between the radiator and the condensor.
Attachment 648109
Yeah I learned this too after installing 6 radiators in a month and a half!
Removing the header bar gives you an extra 2-3 inches of play. Just enough to get the radiator in and out.
R0CKKR4WL3R is offline
post #22937 of 45332 Old 07-23-2013, 10:57 AM
madslynge87
Originally Posted by wxmanWJ
Removed the dang factory front skid plate. Mine was the one with access holes in it but aside from an oil change, how is anyone supposed to get anything done with that thing on?? I can actually see what's going on in the front end now when I roll under it
Have it too, and anoys me like **** ! Might take it off as well
madslynge87 is offline
post #22938 of 45332 Old 07-23-2013, 11:13 AM
rickcricket
Bought a steering wheel cover from AZ. Got sick of crusty leather coming off in my hands.
rickcricket is offline
post #22939 of 45332 Old 07-23-2013, 12:47 PM
go-big
My new fog light mod all the crome faded off the stock so I modified my stock with led's
go-big is offline
post #22940 of 45332 Old 07-23-2013, 01:20 PM
go-big
go-big is offline
post #22941 of 45332 Old 07-23-2013, 02:46 PM
pinky2252s
I just kept reading about how people took off their bumpers and headlights and disconnected their AC lines. That's way more work then you need to be doing. I thought I would show people that it really is possible and not hard to do it with out removing all that stuff.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #22942 of 45332 Old 07-23-2013, 03:37 PM
runninbad
After a long and arduous (one week) search for a leak in the AC system, finally fixed the culprit. Loose valve stem on the low side. Probably should have checked that first. Keep it simple stupid.
runninbad is offline
post #22943 of 45332 Old 07-23-2013, 03:47 PM
pinky2252s
Thats good! I'm lucky enough to have a friend who bought one of those sniffer things. If I ever have a leak I should be able to find it quickly.
Is it broken?
post #22944 of 45332 Old 07-23-2013, 04:13 PM
tigerfan2
Well thinking I might have some bad news. After looking through other threads it seems my 4.7 HO might have a blown head gasket.
tigerfan2 is offline
post #22945 of 45332 Old 07-23-2013, 04:35 PM
pinky2252s
Oil in coolant or coolant in oil? White smoke out of the tail pipe? Loosing coolant and you dont know where?
Is it broken?
post #22946 of 45332 Old 07-23-2013, 05:06 PM
wjidaho
Found a loud clanking noise when in 4wheel, checked the front diff fluid full, down to front drive shaft of cv axles
Roads ? what are roads???
My build thread
wjidaho is offline
post #22947 of 45332 Old 07-23-2013, 05:48 PM
tigerfan2
Well that's my problem. It doesn't look like there is any coolant in the oil and if there is white smoke it isn't much but I'm loosing coolant and have a cylinder 1 misfire when I first crank it up and then that goes away.
post #22948 of 45332 Old 07-23-2013, 06:41 PM
PHAL23
Got my 2in BB...then went to install and it started pouring so that'll have to wait til tomorrow...trying to find the right tires now
PHAL23 is offline
post #22949 of 45332 Old 07-23-2013, 07:18 PM
Stimmel
Installed the correct cd changer cord to get my factory changer to work with my recently installed RB1! Also continued prepping my recently acquired overland rock rails for some fresh paint
Stimmel is offline
post #22950 of 45332 Old 07-23-2013, 08:28 PM
JerzeyBoyWJ
2003 WJ
Flexing them 35s
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
wj
