What did you do to your WJ today? - Page 1529 - JeepForum.com
 1001Likes
post #22921 of 45539 Old 07-22-2013, 03:21 PM
dsodko
Wj mirror and door clips
Replaced damaged driver's side mirror (Rock Auto) and some panel clips both doors. Replace both T25 screws with slotted screws.
Both noise canceling sheets were damaged by PO, next project.
dsodko is offline
post #22922 of 45539 Old 07-22-2013, 03:27 PM
Jeeples
Jeeples's Avatar
Ordered up a set of adjustable upper and lower CA's from a local that makes 'em. I have a feeling next to the Bilstein shocks, this will be some of the best money we've spent on the wife's WJ. Cheap too at only $260.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #22923 of 45539 Old 07-22-2013, 03:37 PM
dsodko
Wj Replaced missing ground
Replaced a missing ground strap on the intake manifold. Thanks PO !
dsodko is offline
post #22924 of 45539 Old 07-22-2013, 04:59 PM
pinky2252s
Took the SE to a stealership to get a cheap oil change. For $12.95 i'll let them do it. I cant even get the oil and filter for that little, and I don't have to do it.
Get this, the SE has had a small coolant leak that is burning off somewhere. I asked them if they could maybe find it. He comes back saying that the thermostat housing is leaking, and that it will be $220 to replace the thermostat. HAHAHAA WHAT? Over 200 hundred dollars in labor for a 5 dollar part? Ooooookay. The dealership never ceases to surprise me.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #22925 of 45539 Old 07-22-2013, 05:04 PM
dillonjm
2013 WK
That's why they charge 12 bucks for an oil change. Lets them find repairs to recommend to customers.
But, in their defense, its the thermostat and gasket (+) $50+ of expensive *** HOAT coolant (+) at least an hour labor.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #22926 of 45539 Old 07-22-2013, 05:32 PM
pinky2252s
Trust me, they aren't using HOAT coolant. They topped it off with non HOAT.
Even if they were to charge me an hour labor (for 15 minutes worth of work) it still leaves like 70 dollars out of no where. And plus, not that much coolant comes out of the 4.0 when the thermostat is replaced. On the 4.7 its much lower on the engine and it actually drops a lot of coolant. Also, why wouldn't they just re use the coolant that came out... ? Its kind of the exact amount that it needs.
ANYWAYS. I only go there for the cheap oil changes for the 4.0. My 4.7 I do everything myself. I don't really like people working on it at all. Im not really attached to the SE as I am my Laredo.
Is it broken?
post #22927 of 45539 Old 07-22-2013, 06:27 PM
Timbo24
Is it the guy on Ksl named spence? Has he made wj long arms yet?
Timbo24 is offline
post #22928 of 45539 Old 07-22-2013, 06:34 PM
Jeeples
Jeeples's Avatar
Yeah that's the one. Looks like I'll be picking them tomorrow so I can ask for you if you'd like.
Jeeples is offline
post #22929 of 45539 Old 07-22-2013, 07:43 PM
formeraudi
Decided to go a little different route with my wheel choice. As others have suggested, not going to go the blacked out wheel look and didn't like the idea of heavy steel wheels. So...I'm turning my Silverblades into Bronzeblades. Started with the spare to see how it looked. Like it, so going to finish the other 4 wheels and hopefully get tires soon. Probably 245/75/16 Duratracs.
Just for reference, going on this car. I have since this picture tinted out the tail lights and put on new Laredo headlights with the black housings. Looks a lot more aggressive.
formeraudi is offline
post #22930 of 45539 Old 07-22-2013, 08:34 PM
ZJPunk98
installed a new JVC head unit with blue tooth, HD radio, USB and more as well as Infinity Reference 3032CF dash speakers. The system sounds nice.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #22931 of 45539 Old 07-22-2013, 10:06 PM
lance-tek
Installed some HIDs into my projectors. I must say that the difference is amazing. Since my fog lights are remaining stock I get the best of both worlds
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline
post #22932 of 45539 Old 07-23-2013, 12:39 AM
DavisI
I've been thinking about doing bronze too. Be sure to post a picture when you get it finished and tell us how you did it
2002 WJ 4.7
4.5"/3.5" with 32"x10"
DavisI is offline
post #22933 of 45539 Old 07-23-2013, 01:15 AM
99WJ539918
$50 for thermostat and gasket, $120 for labor, $20 for gallon of coolant, and taxes and shop supplies will bring you around $220. We all know the dealership is expensive. I agree, I wouldn't bring anything that isn't a warranty job to a dealership. People would complain all the time where I used to work. The tech would never reuse coolant. It's an insurance claim nightmare. If something happens you could say they put dirty coolant in your overflow/radiator and it gunked up. It's better to use new stuff so the dealership has no worries.
Build Thread
99WJ539918 is offline
post #22934 of 45539 Old 07-23-2013, 07:34 AM
1999wjlimited
Dropped it off at the shop to have the ac fixed. I couldn't take it any more.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #22935 of 45539 Old 07-23-2013, 08:09 AM
wxmanWJ
Removed the dang factory front skid plate. Mine was the one with access holes in it but aside from an oil change, how is anyone supposed to get anything done with that thing on?? I can actually see what's going on in the front end now when I roll under it
My "stocker" build thread: http://www.jeepforum.com/forum/f310/my-first-jeep-owning-adventure-1532212
wxmanWJ is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
