What did you do to your WJ today? - Page 1527 - JeepForum.com
 1173Likes
post #22891 of 45902 Old 07-19-2013, 04:29 PM
tkcarp01
Originally Posted by derekmac
I wanted to show that I do care about the environment, so I got this sticker to show Prius drivers that I recycle more than they do.
Love it!
tkcarp01 is offline
post #22892 of 45902 Old 07-19-2013, 05:24 PM
4x4Jeep
drove her home today, first time in 2 weeks.
Build -
SOLD
4x4Jeep is offline
post #22893 of 45902 Old 07-19-2013, 09:43 PM
rdkendrick
2003 WJ
Originally Posted by KDR83 View Post
Stopped by Lowes to get a Grade 8 bolt and nut for the one I snapped on my sway bar endlink and parked next to this
Holy shnikes, batman! You could walk under that and work on it!
Sent from my iPad using Forum Runner
rdkendrick is offline
post #22894 of 45902 Old 07-19-2013, 10:15 PM
lance-tek
Cleaned the intake with Seafoam drove it like a crazy teen to get it all cleaned out. Then I got a p0306 code
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline
post #22895 of 45902 Old 07-20-2013, 02:08 AM
ADragg
2003 WJ
I got my 04 grill installed, and now all I have left for the 04 front end conversion/chrome delete process is the 04 front bumper. Will probably go with a Limited style 04 bumper, but I have considered the Laredo 04 bumper. It would probably be a pain to get smooth enough to paint white and not show the texture underneath, but I wonder how it would look. I kind of like the different shape it has with the two bulges on either side. Either way, I want I'm not sure if I want to keep with grill center silver to match my silver JK wheels, in which case I'd probably paint the metal lower trim piece (that 04 Limiteds and Overlands have) silver to match (or see if there's a "brushed" bare metal one as opposed to the chrome?) - OR - I could paint the lower trim piece black (so it would look similar to my current bumper) as well as the grill and then either paint the JK wheels black too, or leave them silver.
Basically, I'm not sure if I want the mostly black and white look (with the black emblems, tail lights, black 04 Laredo headlights, dark tint, etc.) with the silver accents (wheels, grill, lower bumper piece) or if I just want to go FULL-ON "PANDA". Full-on black and white always looks good, but I think the silver accents thrown in are also kind of nice and more unique.
Let me know what you guys think I should do. I "photochopped" a pic below to show what it would look like with an all black grill, if it helps.
Currently:
How it COULD BE with black grill:
Oh, and I also did this. It's not done, as I want to add a lock, add some rigidity to the "drawer" (which obviously used to be the cup holder), and some black foam that's cut to shape, but I think this is a cool mod.
3.5" lifted '03 Limited Quadra Drive WJ - OME HD coils, Bilstein 5100 shocks, JKS track bar, IRO extended links, OME 10mm spacers, Moog SS, JK Moab wheels w/ 265/70/17 (32") Goodyear Duratracs.
ADragg is offline
post #22896 of 45902 Old 07-20-2013, 03:40 AM
pinky2252s
For the people who say that you can't replace the radiator on the 4.7 (hydro fan) without removing the AC condensor/Dis-connecting the AC lines-
Name:  A:c condensor .jpg
Ran regular Non-hoat coolant for 12 years and the water pump looks good as new.
Also, a big bug I found between the radiator and the condensor.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #22897 of 45902 Old 07-20-2013, 06:45 AM
cykaaro
Finally put on my rack finally. Still have to figure out how I want to do the wiring for it.....
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #22898 of 45902 Old 07-20-2013, 12:08 PM
atinari
Dont know if this guy is a member here but i see his rig all the time. 6.5 inch iro lift and 33s. Probably one of my favorite wj's I've seen.
atinari is offline
post #22899 of 45902 Old 07-20-2013, 01:09 PM
pinky2252s
Im pretty sure he is. I remember seeing him post here that he painted the metal bumper that way.
Is it broken?
post #22900 of 45902 Old 07-20-2013, 02:12 PM
oaklyjeep10
That's to far of a reach,
Not today but this week:
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq
oaklyjeep10 is offline
post #22901 of 45902 Old 07-20-2013, 02:42 PM
Jaspah
The rims that were on my WJ when I bought her had quite a bit of corrosion, especially on the front wheels. Heard good things about Plastidip so I decided to give it a shot. I think it looks great!
Also sacrificed my CD changer for a 3.5mm auxiliary input for my phone. Sounds MUCH better than the tape adapter I was using. Had some really bad electrical noise from my alternator when my car charger and the auxiliary input were plugged into my phone at the same time so I picked up a ground loop isolator that fixed the problem without any noticeable loss in audio fidelity. Sounds like a common problem for adding an auxiliary input to a system that wasn't originally designed for it.
Jaspah is offline
post #22902 of 45902 Old 07-20-2013, 04:10 PM
bigredhawkeye
Finally got around to installing my new 2.5" tweeters. Definitely a huge improvement, so here is to hoping that they don't blow right away.
bigredhawkeye is offline
post #22903 of 45902 Old 07-20-2013, 09:06 PM
Butterbuddha
2010 JK Wrangler
Replaced burnt out blinker bulb, and Superchipped. I wanted to correct the speedo now that I have stock Rubi wheels and tires on there. Bummed out about TPMS Anyways, tossed on the 87 tune and now when I start it up it revs like I floored it. (Just once, just when it first starts) No ill effects other than that. Normal?
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #22904 of 45902 Old 07-20-2013, 09:10 PM
oaklyjeep10
Not normal. I'd call Superchips. Their customer service is pretty good.
post #22905 of 45902 Old 07-20-2013, 09:14 PM
Butterbuddha
2010 JK Wrangler
Gah. I'll probably just remove the tune. I never noticed a difference anyways. (Though coming from my mouse 3.8L, driving the Mrs' V8 is a pleasure either way lol)
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 09:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 02:58 PM
Died today... jimbo141 WJ Grand Cherokee Forum 29 03-26-2017 11:41 AM
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 11 02-09-2017 05:03 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
