What did you do to your WJ today? - Page 1524 - JeepForum.com
 925Likes
post #22846 of 45357 Old 07-16-2013, 08:00 PM
1999wjlimited
After getting stuck last night I finally decided to put my new to me double cardan driveshaft in that I've had since December after my reppenza unit bit the dust. Feels good to have 4wd for the first time in almost 8 months.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #22847 of 45357 Old 07-16-2013, 08:15 PM
jeepinjeepin
Is that a bolt in? Do some WJs have reppenza and some have CV?
jeepinjeepin is offline
post #22848 of 45357 Old 07-16-2013, 08:19 PM
1999wjlimited
My old driveshaft was a reppenza reppenza and no it wasn't bolt in I got the transfer case yoke from kolak and the pinion yoke came off a zj a guy I knew bought for the engine. The driveshaft itself came from a junkyard.
Old driveshaft is on the right new one on the left.
post #22849 of 45357 Old 07-16-2013, 08:20 PM
pyre24
Originally Posted by 1999wjlimited View Post
My old driveshaft was a reppenza reppenza and no it wasn't bolt in I got the transfer case yoke from kolak and the pinion yoke came of a zj a guy I knew bought for the engine. The driveshaft itself came from a junkyard.
I need to get mine off. Got the crap one too.
pyre24 is offline
post #22850 of 45357 Old 07-16-2013, 08:22 PM
zephyr80
Did you do that yourself? if so how much fluid did you loose when replacing the seals, if you did.
Bot... Changed my crankshaft position sensor and cam shaft position sensor.
Sent from your back seat!!!
zephyr80 is offline
post #22851 of 45357 Old 07-16-2013, 08:23 PM
rdkendrick
2003 WJ
Originally Posted by pinky2252s View Post
Right, but the Ultra gauge isn't just a scan tool. It has a constant customizable gauge read out for mounting on your windshield.
http://www.ultra-gauge.com/ultragauge/
I just bought the OTC 9450 OBDII Scan Tool, ABS and SRS Code Reader. It is supposed to read and erase SRS and ABS codes. I am going to see if I can diagnose my airbag light with it. If so, I will let you guys know. It was $99 plus shipping.
http://www.amazon.com/OTC-9450-OBDII...TtF.12SB1CC_tt
Sent from my iPad using Forum Runner
rdkendrick is offline
post #22852 of 45357 Old 07-16-2013, 08:29 PM
1999wjlimited
Yes I did it my self but I didn't replace the seals I just zapped it off with an impact gun and put the new yoke on and torqued it to spec. I did have to use a gear puller on the transfer case yoke to get it off because my BFH didn't work on it like it did the pinion yoke.
post #22853 of 45357 Old 07-16-2013, 09:20 PM
jeepinjeepin
So the shaft and axle yoke come from a ZJ and the x-case yoke is from Kolak? Does the x-case yoke from the ZJ not fit?
post #22854 of 45357 Old 07-16-2013, 09:29 PM
1999wjlimited
The shaft came from a wj the only reason I tried the zj axle yoke was because it was free the guy I got the yoke from had already sold the transfer case.
post #22855 of 45357 Old 07-16-2013, 10:00 PM
jeepinjeepin
Ok, thanks. I've been junkyard cruising lately. Something else to add to the list...
post #22856 of 45357 Old 07-16-2013, 10:18 PM
1999wjlimited
No problem
post #22857 of 45357 Old 07-16-2013, 10:21 PM
2ndhandWJman
Originally Posted by doorjamm View Post
I want to do this, but I'm curious how you go about drying the carpet?
The nozzle shoots such a small amount of water behind the vacuum nozzle, 95% of the water gets sucked out immediately. The remainder just air dries in a few hours, the same way a detail shop does it for a LOT more money.
2ndhandWJman is offline
post #22858 of 45357 Old 07-17-2013, 04:25 AM
tkcarp01
Reviews on that one were not friendly at all on Amazon....
tkcarp01 is offline
post #22859 of 45357 Old 07-17-2013, 09:41 AM
rdkendrick
2003 WJ
I saw, but none specific to the Jeep Grand Cherokee. There was one who said it worked perfectly on his Wrangler.
post #22860 of 45357 Old 07-17-2013, 03:43 PM
alfaitalia
Originally Posted by alfaitalia View Post
Did this ! Got fed up with all the scratches in the corners where the PO was not carefull getting stuff in and out of the boot (OK trunk!). Also a small area of paint was lifting so it covered that. Will "black" the rubber bit with something to blend it in a bit better too.
Attachment 644616
And this!, as I alway thought the "diffuser" styled bit should be black and it loses my hitch a bit (visually at least!).
Attachment 644617
Ignore they slightly raggy edges as it was difficult to cut even with a new blade. I have carbon edging pin to finish it but ran out of time as I wanted to take thie pics before the light went.
Will be doing the over rider style bits on the front bumper (Ltd) when I get more time as they seem to have picked up more than there fair share of stone chips. Mocked it on "paint" and I think it will look OK....easy to peel if I dont like it.
Its 3m carbon, exterior grade with the tiny grooves in the back to let the air out so you dont get bubbles even if you apply it dry. Very stretchy so good on the curves.
Today I finished the above like this. Used some edging strip to sharpen up the finish and extended the carbon under the lights to give a more complete look...
...and finished the defuser area the same way...
...then did the front to match.. a cheaper and cooler way (IMO) than a respray (that will never match 10 year old paint anyway) to cover the multitude of stone chips on the "over rider" bits that stick out on a LTD bumper.....
and finished the edges to match the rear.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
wj
GhostJeepWJ
