What did you do to your WJ today? - Page 150 - JeepForum.com
 866Likes
post #2236 of 45174 Old 03-24-2011, 04:56 PM
PinePig
1993 XJ Cherokee
Originally Posted by straty1987 View Post
jeep looks good
what problem did you have installing them?
I got the JCR's because they only have 2 kickers (I have a KOR t-case skid so the bracket would get in the way of a middle kicker) and they stick out past the doors for more lateral coverage.
The front kickers were about 3/4" too short. The sliders flex a lot when you support the weight of the Jeep on them. They are stout and built well, they just need more work on the R&D to make them fit better.
2004 WJ Laredo 4.7
1996 ZJ Limited
1993 XJ 2 door 5 speed
1951 CJ3A
PinePig is offline
post #2237 of 45174 Old 03-24-2011, 05:07 PM
straty1987
some people have that problem and it might be the way the the rail was jacked up during the install, there was a tread on it.
i picked up a used set of there stage 2 and just have to finish cleaning and painting it before i can mount it.
straty1987 is offline
post #2238 of 45174 Old 03-24-2011, 05:22 PM
Northwoods18
2005 WK
Finally ponied up and started upgrading. Installed new headunit, alpine amp and speakers last weekend. Ordered Stillen super premium rotors from Kolak... will get some pics up of the progress soon!
2005 WK Hemi -- Deep Beryl Green -- Volant CAI -- Taylor Shorties -- Throttle Body Ground -- Superchips Flashpaq 3875
-- OME HD -- Spidertrax Spacers -- 255/75/17 BFG M/Ts -- Stillen Stoppers
Northwoods18 is offline
post #2239 of 45174 Old 03-24-2011, 05:28 PM
2ndAmend
installed Rusty's 2" BB.
Customer service was great and shipped fast
1hr and a half worth of work, rear coil spacer goes below coil ( sits on top of axle)
hardest part was removing rear coil isolators without damaging them.
2ndAmend is offline
post #2240 of 45174 Old 03-24-2011, 05:30 PM
teckman02
drove it treated the wife to lunch and shopping
teckman02 is offline
post #2241 of 45174 Old 03-24-2011, 05:33 PM
narnwv
narnwv's Avatar
The spacer goes on top of the coil.
I have their spacers as well. All spacers go on TOP of the coils.
~Aaron
narnwv is offline
post #2242 of 45174 Old 03-24-2011, 05:45 PM
PinePig
1993 XJ Cherokee
I had a harder time with passenger side. The piece that bolts to the pinch seam is most of the problem. It was all wonky and bent. The other problem is the thin, weak metal of the Jeep's sub frame does not like the self tapping bolts.
2004 WJ Laredo 4.7
1996 ZJ Limited
1951 CJ3A
PinePig is offline
post #2243 of 45174 Old 03-24-2011, 05:54 PM
jemrey81
I had a lot if issues with mine too - the passenger side was worse than the driver side for me too....... Crazy! I spent a lot of time with them and talking with JCR to get it resolved.
You should post your comments on the sliders here for others:
http://www.jeepforum.com/forum/f310/...ssues-1148819/
jemrey81 is offline
post #2244 of 45174 Old 03-24-2011, 06:24 PM
2ndAmend
That's funny at 9AM this morning I had 2 different people at Rusty's tell me that it goes on the bottom and gave advise on how to remove the lower coil isolator without damaging it. Must have changed the setup since you did yours.
2ndAmend is offline
post #2245 of 45174 Old 03-24-2011, 06:26 PM
narnwv
narnwv's Avatar
Don't ever flex it. If you do, be careful when your rear spring falls out.
~Aaron
narnwv is offline
post #2246 of 45174 Old 03-24-2011, 06:37 PM
GhostKnife
weird, when i have my BB the rears went on the bottom. no biggy i flexed and the only thing that happened was alot of rubbing. Oh i gave mine a well deserved bath to get all the salt off
13 Ram Cummins, PPEI Tuned and Full Carli/Thuren. JK Arctic Edition 2dr Winter Chill
GhostKnife is offline
post #2247 of 45174 Old 03-24-2011, 06:41 PM
narnwv
narnwv's Avatar
What holds the coils on? The bottom spring perch isn't tall enough to go through a 2" spacer and up into the spring....
~Aaron
narnwv is offline
post #2248 of 45174 Old 03-24-2011, 06:54 PM
2ndAmend
I'm not saying anyone is right or wrong, that's just what i was told by Rusty's and Fatbob's is the same. Here's the FB install:
http://www.fatbobsgarage.com/instructions/64200C.pdf
2ndAmend is offline
post #2249 of 45174 Old 03-24-2011, 06:57 PM
narnwv
narnwv's Avatar
I know, and a guy came on here with pictures and the whole thread was "woa you put them on the wrong side, your springs will fall out...."
~Aaron
narnwv is offline
post #2250 of 45174 Old 03-24-2011, 08:56 PM
88yjproject
Mine rear spacers went on top too when I had them.
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline
wj
Currently Active Users Viewing This Thread: 7 (5 members and 2 guests)
chalkboard , GhostJeepWJ , MOTOWN , Ravenbar , Soem0
