What did you do to your WJ today? - Page 1499 - JeepForum.com
 738Likes
post #22471 of 44511 Old 07-02-2013, 09:34 PM
trevord1
IRO rear long arms and axle swap with aussie locker
966331_10201469646173072_1462288961_o.jpg   1026047_10201469646733086_578625918_o.jpg   1039794_10201469648173122_700170897_o.jpg
2004 wj freedon edition long arm lift on super swampers!
trevord1 is offline
post #22472 of 44511 Old 07-02-2013, 09:44 PM
doorjamm
Originally Posted by mtnmarc
I want your sti doorjamm. I've been looking at 06 and newer wrx's or 2013 civic si.
Unfortunately it isn't mine ive just been borrowing it while the jeep is out of commission. Nothing beats that feeling of boost in my opinion, and I'd buy one if I had the money. You have to be careful though, because imprezas become money pits just like jeeps do.
doorjamm is offline
post #22473 of 44511 Old 07-03-2013, 07:13 AM
Jaketit
Haha I love your jack stands.
Jaketit is online now
post #22474 of 44511 Old 07-03-2013, 07:55 AM
lance-tek
I think this is a poster for determination
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline
post #22475 of 44511 Old 07-03-2013, 09:15 AM
trevord1
hell ya!
trevord1 is offline
post #22476 of 44511 Old 07-03-2013, 11:30 AM
tycal
I added an AUX port to my factory radio using the CD changer control harness. I took an older write up from smunns (grey goose wj) and updated the info a bit. I have a 99 WJ and his write up was for the 02-04 WJ's. The radio/cd connector/wiring is a bit different between the 99-01 and 02-04's. I took his wiring diagram and updated it so the people with a 99-01 would have a quick reference sheet. Works perfectly, I spent $10 and about an hour to complete.
I won't rewrite his article, you can find it here...
http://www.jeepforum.com/forum/f197/...3/#post9992383
You'll need the radio shack stereo adapter... $3
http://www.radioshack.com/product/in...ductId=2103451
and a 3.5mm Male to Female 6'-8' extension. $6
Using his info as a guide, I wired the aux adapter directly to the back of the CD connector harness and plugged in the 8' aux cord extension to it there. It is secured and hidden behind the radio. I ran the aux cord extension under the console up near the seat belt harness, the excess length is wrapped up and tucked behind dash at the front of console. From there, using a standard male/male aux cord I can plug in whenever I want to play my iphone/ipod. My thought was, if a connector or cable goes bad, I would like to be able to replace it easily... I also didn't want to mount the aux adapter permanently to the dash since I'm sure I'll eventually upgrade the radio. Just press CD and voila...music from the phone.
Here's the updated wiring diagram that shows both WJ models...
Testing the connection...
Soldered...(thats just black tape between the connections)
Taped and Secured...
finished... also a good shot of all that fake plastic wood grain I covered up with plasti dip!
Hope it helps someone else... super easy and cheap if your just needing an aux port.
1999 WJ 4.7 w/QD
tycal is offline
post #22477 of 44511 Old 07-03-2013, 12:28 PM
PowderHound
2003 WJ
Is it true that you have to have a working cd changer to make this work?
2003 WJ♦Inferno Red Limited(4.7 H.O., Vari-Lok axles)♦OME HD/BILLY 5100S♦IRO t-case skid, adj. tb, sway links♦Moog SS♦Factory tow package w/harness & tow hooks♦ Amp/12 sub box♦new bad b**ch passenger♦1993 XJ country♦lift/muds/winchbumper-sold♦build thread instead of long A$$ sig soon...
PowderHound is offline
post #22478 of 44511 Old 07-03-2013, 12:29 PM
go-big
Did iro sell you just the long arms ? Or you have to buy a the rear kit ?
go-big is offline
post #22479 of 44511 Old 07-03-2013, 12:30 PM
go-big
Wish you could do this with a CD player
go-big is offline
post #22480 of 44511 Old 07-03-2013, 12:40 PM
Jeeples
Jeeples's Avatar
Originally Posted by madslynge87 View Post
But got under the car and doenst it hang too low??
There is an exhaust mount that integrates into the transmission mount. If he removed that mount to attach the catalytic converter that could explain why it hangs low since the only other mount in the system is the tailpipe mount.
Refer to my write up on installing the Kolak exhaust without welding:
http://www.jeepforum.com/forum/f310/...nstall-477862/
The exhaust mount I am talking about sits about 3 inches or so toward the front of the Jeep. You can also reference how the muffler should look when it is sitting level and installed properly. Even with the Flowmaster Big Block muffler, the body shouldn't hang much lower than the rear control arm mount.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is online now
post #22481 of 44511 Old 07-03-2013, 12:59 PM
PowderHound
2003 WJ
I just read that you DO need a working 10 disc changer to make this work.
post #22482 of 44511 Old 07-03-2013, 01:12 PM
03grndcherokee
2003 WJ
Blacked out my taillights and put springs on my cb antennas.
03 Grand Cherokee Laredo 4.0
Video with pics of my old truck.
03grndcherokee is offline
post #22483 of 44511 Old 07-03-2013, 01:15 PM
tycal
You need a cd changer that "powers on"... if you dont have a CD changer plugged in that powers on when you hit the "CD" button, it wont even switch to it. My CD player doesnt even play most CD's i put in it...so its basically worthless, but necessary for this AUX connection to work with the way I outlined it. You can't simply plug audio left/right into the corresponding pins on the back of the radio where the cd changer plugs in and expect it to work. it has to recognize that the cd changer actually powered itself on when you hit the "CD" button. Odd, but true...
1999 WJ 4.7 w/QD
tycal is offline
post #22484 of 44511 Old 07-03-2013, 01:31 PM
Merc1973
I am currently sitting on the side of the road since my driver side Coral Springs popped out I knew I shoulda put those IRO spring retainers on....
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #22485 of 44511 Old 07-03-2013, 01:33 PM
PowderHound
2003 WJ
CRAP!
Hope everyone is safe and your Jeep isnt damaged...
wj
