What did you do to your WJ today? - Page 1493 - JeepForum.com
 1012Likes
post #22381 of 45556 Old 06-29-2013, 01:06 PM
SKI_VT
Got death wobble on the highway while crossing a bridge ...
Great.
"You people make it sound like Claytons are made from gold and unicorn bones while everyone else uses PVC and spaghetti noodles."
"The Great Turtle Race! -> Iceland vs. Bushwhacker! -> Place your bets!"
SKI_VT is offline
post #22382 of 45556 Old 06-29-2013, 01:27 PM
rdkendrick
2003 WJ
Originally Posted by wjidaho View Post
Nice I have to do that, just scared that the airbag will go off, like the guy at the dealership said
Just make sure you disconnect both terminals from the battery and don't work on it for at least 20 minutes. Use a two jaw puller (I bought a three jaw that converted to a two jaw from AutoZone). I had the correct socket. It was actually pretty easy. I printed the directions and I could probably do it without instructions, now. Too bad it didn't make my air bag light go off. I read someone's post that said a TSB mentions changing the Airbag Control Module to a 2004 model. If so, what is the number of the TSB?
Sent from my iPad using Forum Runner
rdkendrick is offline
post #22383 of 45556 Old 06-29-2013, 01:30 PM
bigredhawkeye
Originally Posted by fuzzy88 View Post
I made it. My seat covers have that on them. I couldn't find that logo anywhere so I made my own :-)
You should think about making some more of those! I'm sure there would be quite a few of us who would gladly buy them from you.
bigredhawkeye is offline
post #22384 of 45556 Old 06-29-2013, 01:34 PM
rdkendrick
2003 WJ
Originally Posted by jeepinjeepin View Post
Any idea which vehicles might share the same towing package harness as the WJ? The harness that runs from driver rear corner.
A couple of pages back, GCJEEPING mentions that the hitch plug is the same as that on a dodge truck. You might ask him. I couldn't tell you about the hitch, but I do know that the Chrysler cars and Dodge trucks have the same EVICS and head units.
post #22385 of 45556 Old 06-29-2013, 02:19 PM
derekmac
Took the ole girl through some mud, lots of mud! Don't really have any pics of me though :-(
Here's a vid I made of the trip though.
2005 TJ Rubicon
derekmac is offline
post #22386 of 45556 Old 06-29-2013, 03:03 PM
Meta4
2010 WK
Keep in mind the nut that holds the steering wheel onto the shaft is a one-time-use Nylock nut. When you remove it, you need to replace it with a new one.
2004 Jeep Grand Cherokee Overland
Meta4 is offline
post #22387 of 45556 Old 06-29-2013, 03:35 PM
mrowaan
Oil changed with Mobil One full synthetic. Greased it. My new front skid plate does make it a pain to get to the filter, oh well.
Flexing my WJ http://www.youtube.com/watch?v=KWFDAaQyMlM
mrowaan is offline
post #22388 of 45556 Old 06-29-2013, 04:35 PM
11B-33T
Installed today:
wiring harness install & routing was a breeze. The hardest part was removing the d@*n plastic fascia rivets which I ended up just cutting and using replacement universal trim/panel retainers.
I also tried to save a whole $8.00 by ordering the bezel on-line vs. the dealership. Ordered last Saturday and currents status is awaiting pickup at the vendor by UPS. Said screw waiting, cut the bumper and installed anyway.
11B-33T
- 2005 Ford Escape XLT AWD
- 2004 WJ Grand Cherokee SE
- 2003.5 Mazdaspeed Protege
11B-33T is offline
post #22389 of 45556 Old 06-29-2013, 05:42 PM
jeepinjeepin
Originally Posted by 11B-33T
Installed today:
Did you have to install the whole harness from the left rear corner down? If so, did you go with the dealership, online, or junk yard?
jeepinjeepin is offline
post #22390 of 45556 Old 06-29-2013, 09:14 PM
11B-33T
The hitch was from a local JY and included the wiring harness. I followed the instructions and wired into the OEM plug already installed in the L/R corner of the Jeep.
11B-33T
11B-33T is offline
post #22391 of 45556 Old 06-29-2013, 09:48 PM
JRobes
flushed the coolant, easier than I thought it'd be.
2004 WJ Overland, 4.7HO, Quadradrive, 3" OME HD/Bilstein lift
1999 Honda Magna VF750C
JRobes is offline
post #22392 of 45556 Old 06-29-2013, 10:01 PM
buger561
2003 WJ
Originally Posted by 11B-33T View Post
Installed today:=
I'm losing patience as well. Anyone know if the bezel from a laredo will fit a limited flush? I've heard otherwise, but may just have to go back to the JY and pick one up.
Also, is that a class IV hitch? The one I grabbed does not have the extra bracket on the bottom.
buger561 is offline
post #22393 of 45556 Old 06-29-2013, 10:27 PM
lance-tek
the one I got at the JY and installed didn't have that bracket either. I don't recall seeing anything about it in the install instructions either... what is it?
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline
post #22394 of 45556 Old 06-29-2013, 11:09 PM
cykaaro
Mine looked basically like that, but had both brackets on, not just the one.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #22395 of 45556 Old 06-30-2013, 12:10 AM
alfaitalia
Originally Posted by Meta4 View Post
Keep in mind the nut that holds the steering wheel onto the shaft is a one-time-use Nylock nut. When you remove it, you ne to replace it with a new one.
Never had mine off.....but surely its either Nylock OR a "one use" nut as Nylock nuts/bolts are designed to be used many times.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
wj
HarryH3
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
