What did you do to your WJ today? - Page 1466 - JeepForum.com
 863Likes
post #21976 of 45159 Old 06-13-2013, 12:39 PM
Meta4
2010 WK
Originally Posted by shocking1 View Post
I put a drain plug in when I had mine down
I didn't even think of that. Do you just drill a hole and tap it with the right size of threads? Food for future thought.
Mag-Hytec makes an aftermarket oversized transmission pan for the 545RFE that includes a magnetic drain plug, but I wasn't sure it would be worthwhile to drop $300 on a transmission pan on a stock Overland. I was also concerned about the ground clearance for the larger pan on a non-lifted Jeep.
2004 Jeep Grand Cherokee Overland
Meta4 is offline
post #21977 of 45159 Old 06-13-2013, 01:59 PM
tycal
Finished blacking out the wood grain. Got a $10 radio bezel (black) at the local pull your part. Plasti Dip'd the lower console pieces, trim on dash and all four doors...
1999 WJ 4.7 w/QD
tycal is offline
post #21978 of 45159 Old 06-13-2013, 02:17 PM
shocking1
Originally Posted by Meta4
I didn't even think of that. Do you just drill a hole and tap it with the right size of threads? Food for future thought. Mag-Hytec makes an aftermarket oversized transmission pan for the 545RFE that includes a magnetic drain plug, but I wasn't sure it would be worthwhile to drop $300 on a transmission pan on a stock Overland. I was also concerned about the ground clearance for the larger pan on a non-lifted Jeep.
Yeah I just tapped it out and put a bolt in with some loctite
shocking1 is offline
post #21979 of 45159 Old 06-13-2013, 02:25 PM
Jeeples
Jeeples's Avatar
You can also buy this for about $5 at the local parts store:
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #21980 of 45159 Old 06-13-2013, 02:34 PM
dillonjm
2013 WK
231HD is in the Jeep:
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #21981 of 45159 Old 06-13-2013, 02:44 PM
1999wjlimited
Drove it.
89% humidity.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #21982 of 45159 Old 06-13-2013, 03:13 PM
SierraRipper
Originally Posted by 1999wjlimited View Post
Drove it.
89% humidity.
Mine would've exploded in 5 min of driving there lol
SierraRipper is offline
post #21983 of 45159 Old 06-13-2013, 03:46 PM
MIKEJONES
Drove it.
Attachment 637605
89% humidity.
I feel your pain!
Ordered me some new head lights today and took 5 minutes to put them in. Just the stock limited replacements, but I like them better than any aftermarkets i've seen. Waiting on all my led bulbs to come in now.
MIKEJONES is offline
post #21984 of 45159 Old 06-13-2013, 03:49 PM
ADragg
2003 WJ
Drove it.
89% humidity.
I guess the humidity might make it worse than here, but mine has been displaying 115 and 116 regularly this week.
3.5" lifted '03 Limited Quadra Drive WJ - OME HD coils, Bilstein 5100 shocks, JKS track bar, IRO extended links, OME 10mm spacers, Moog SS, JK Moab wheels w/ 265/70/17 (32") Goodyear Duratracs.
ADragg is offline
post #21985 of 45159 Old 06-13-2013, 03:59 PM
wschilawski
That's SHARP! If I didn't have the brushed aluminum I would definitely consider doing this.
wschilawski is offline
post #21986 of 45159 Old 06-13-2013, 04:04 PM
1999wjlimited
Last summer here in nc it was 108 with 80 something percent humidity.
post #21987 of 45159 Old 06-13-2013, 04:15 PM
99WJ539918
Originally Posted by thisguyhasadd2 View Post
You mean pads n rotors not caliper
No, I mean calipers. The OP said the pads and rotors were fine.
Build Thread
99WJ539918 is offline
post #21988 of 45159 Old 06-13-2013, 04:16 PM
go-big
Yes x2 Woodgrain was a bad idea they Should have use Carbon fiber
go-big is offline
post #21989 of 45159 Old 06-13-2013, 04:17 PM
zephyr80
Originally Posted by 4x4Jeep View Post
what bumper?
I don't get it? Were you able to see the pic? its just a black photo until i clicked on it? or joke maybe? work with me here and spell it out cause I've been working a lot of OT and my brain is fried.
Sent from your back seat!!!
zephyr80 is offline
post #21990 of 45159 Old 06-13-2013, 05:19 PM
cykaaro
I lucked out and got the burl wood instead of that wood grain in mine. Do prefer the brushed metal, but would have doen the same if mine were the same trim. Looks great!
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
wj
