What did you do to your WJ today? - Page 1455 - JeepForum.com
 827Likes
post #21811 of 45014 Old 06-06-2013, 08:11 PM
zephyr80
Ok, here is what i did to my wj today
Here is what i did to try and fix it
For now.
has anyone had this happen and how was it fixed. I will also start a new thread.
Sent from your back seat!!!
zephyr80 is offline
post #21812 of 45014 Old 06-06-2013, 08:16 PM
pinky2252s
For now.
Buy a new terminal? They are really easy and cheap to replace..
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #21813 of 45014 Old 06-06-2013, 08:20 PM
brouwmat
Originally Posted by oaklyjeep10 View Post
I mounted a roof rack and painted some things on the front end. Let me know what y'all thing about the grill. I can't decide if I like it or not.
I kinda like the bright red better.. Makes it stand out. But it sounds like I am in the minority here.
brouwmat is offline
post #21814 of 45014 Old 06-06-2013, 08:25 PM
zephyr80
I noticed that there are double cables for each clamp, do you know where i might be able to find these new clamps? everything that i have seen looks like it will only work for one cable.
zephyr80 is offline
post #21815 of 45014 Old 06-06-2013, 08:32 PM
go-big
http://item.mobileweb.ebay.ca/viewit...d=330936036960
Look at these
go-big is offline
post #21816 of 45014 Old 06-06-2013, 09:02 PM
BrugsBunny
Originally Posted by SCAN-MAN
Put on some Rubi wheels also!!
This gives me a chubby
BrugsBunny is offline
post #21817 of 45014 Old 06-06-2013, 09:06 PM
BrugsBunny
Originally Posted by jbruse
Mine runs just under 65 even with oversized tires. Plugged in my Superchips programmer, re calibrated the speedometer and entered the new tire size. Even with the K&N Cold Air intake and throttle body lift it runs great! 15+ mpg.
Shoot I'm lucky to get that without the filter and lift, and I just have BFG Rugged Terrains...that is the one thing that bugs the crap out of me about my jeep
post #21818 of 45014 Old 06-06-2013, 09:12 PM
BrugsBunny
For now.
I replaced both terminal connections on mine about 3 months back, and to do it you're gonna have to do alot of wire moving because it's wired so tightly in there and in order to get the new terminal connectors on there you're gonna need to strip about an inch back on what you have left...but by the looks of it you might just be better off replacing the whole wire and connector all the way to the starter.
post #21819 of 45014 Old 06-06-2013, 09:14 PM
BrugsBunny
Oh and go to pep boys, I got gold plated connectors for like $9 a pop, and they're worth the money, and they make them in an easy to install double wire config.
post #21820 of 45014 Old 06-06-2013, 10:40 PM
fast540
Made a bunch of sevens
fast540 is offline
post #21821 of 45014 Old 06-06-2013, 11:13 PM
gtg413i
2003 WJ
http://www.jeepforum.com/forum/f310/...-swap-1356634/ check here for a write up.
Brian's Black Betty Build:
gtg413i is offline
post #21822 of 45014 Old 06-06-2013, 11:27 PM
BigWheel7
Originally Posted by go-big View Post
The grill would look better the color of truck and the insert black but that's want makes a nice rig people thinking it needs just that one change
Personally I think the grill being color matched would bring too much of the maroon to the front end. Where just the inserts, winch plate, and d-ring would be a nice subtle change.
BigWheel7 is offline
post #21823 of 45014 Old 06-07-2013, 08:50 AM
STORM_JK
Put the most money into it this month. Gassed it up from empty haha 18mpg mixed so not too bad
'13 JK 6-spd | 3.5" RK | 35" MTR/K | Lots Of Welding
STORM_JK is offline
post #21824 of 45014 Old 06-07-2013, 10:12 AM
gordondude24
Changed front brake pads. On the plus side, I found out that somebody already changed out the calipers to akebonos. On the negative side, one of the caliper slide pins was completely frozen. Was a pain in the a$$ to get it broke loose but i got it out, lubed up, and back in.
John
gordondude24 is offline
post #21825 of 45014 Old 06-07-2013, 10:22 AM
Jeep01AH
Was changing the power steering fluid and transfer case fluid when these came in.
Will be putting them in this weekend!
Thanks Kolak!
| 2001 WJ - 4" Lift - Locked - 33s | My Build Thread:
| ΜΟΛΩΝ ΛΑΒΕ |
4 Wheel To Heal - Serving our wounded and disabled veterans -
- 4W2H
Jeep01AH is offline
wj
