What did you do to your WJ today? - Page 1448 - JeepForum.com
 993Likes
post #21706 of 45530 Old 06-03-2013, 07:46 PM
dcampbell4
These showed up today!!
Adjustable uppers and lowers up front And lowers in the rear. And finally some quick discos!
dcampbell4 is offline
post #21707 of 45530 Old 06-03-2013, 08:35 PM
99Limited
Glad they got there! Enjoy man!
99Limited is offline
post #21708 of 45530 Old 06-03-2013, 08:45 PM
dcampbell4
I was just about to message you. They all look great. Bushings are in excellent shape.
And kudos on the packing job.
Thanks again!
post #21709 of 45530 Old 06-03-2013, 09:01 PM
lvngtheJEEPlife
Originally Posted by adavis39 View Post
doors off posing and some wheeling:
Woah hey now, i think i see a bend in the unibody, too much flexin without the doors Looks great
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #21710 of 45530 Old 06-03-2013, 09:27 PM
99Limited
Thanks again!
That was literally half of a roll of duck tape and a whole roll of paper towels. Ha here's what replaced the dub!
It's bitter sweet...but I'll have another Jeep!
BOT: Put the dub up for sale here locally. Will put on the classifieds section here soon!
post #21711 of 45530 Old 06-03-2013, 09:44 PM
aralph30
2003 WJ
Originally Posted by dillonjm
I used to tow around my trail rigs in this fashion (different vehicle, but same idea). Then I got a Cummins (on my 2nd one now). Life is much better.
And to stay on point with the thread, here is what I did today:
Whats the name of the grill u have in that picture of ur car on the jack lift
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #21712 of 45530 Old 06-03-2013, 09:53 PM
aralph30
2003 WJ
Blacked my grill out
aralph30 is offline
post #21713 of 45530 Old 06-04-2013, 12:24 AM
Teflon916
Went to pick n pull and got some extra gauges and started experimenting. I cut the edges out so light shines through. Didn't come out like I thought. So I just put it back the way it was. Also tried to sand the blue off so I can have white numbers but it doesn't come off.
Sent from the top of my VISA card
Teflon916 is offline
post #21714 of 45530 Old 06-04-2013, 01:29 AM
ADragg
2003 WJ
Cleaned throttle body and IAC motor/valve and started installing new Champion Copper plugs. I haven't gotten to the difficult ones yet, but I believe these are the original spark plugs and I'm almost at 100k miles now. For being original, they tell me the engine is running great. However, they did need to be changed. The center metal conductor things were a little corroded down to where they didn't stick up out of the porcelain insulator very much, so the gap was almost twice what it should be. But the plugs in general looked to be in great shape. No rust, and mostly white (slightly browned) insulators, etc.
I'm still finishing up the project, but considering my 4.7 Power Tech has ran great and idles fairly smooth, with only slight "sputter/hiccup/glitchiness" if you pay close attention, I don't know if I'll see much improvement. If anything it should just run flawless and idle completely perfect. And as good as the plugs looked for never being changed, they had the equivalent of a super big gap on them, so I don't know what improvement I'll see after changing them. But I expect the fairly carbon deposited IAC and throttle body which are now nice and clean, should make the idle perfect. It already ran smooth but maybe I will get a slight MPG boost or slight boost in power with the new plugs? Doubtful, but it's possible.
I need to post picture of the other stuff I've done lately, which include a D-ring shackle mounted in my factory hitch, a new Pioneer head unit, and some Plasti-dip fun!
EDIT: BY THE WAY, following the instructions on WJJEEPS.COM, the spark plugs take 20 ft. lb.'s of torque OR you can just tighten it an extra quarter turn after it's snug. When I get the plugs seated hand-tight, it takes a half turn to reach 20 ft. lb.'s and it feels tighter than I normally thought spark plugs should be. Does this sound right, or is my Pittsburg torque wrench way off? It doesn't seem excessively tight, but it's definitely passed "a quarter turn passed snug" (I think, since it's at least a half turn passed hand-snugged) and it's a bit tighter than I've ever installed plugs into a car when I've done it by "feel" in the passed (knowing you need to be careful not to over-tighten plugs).
ADragg is offline
post #21715 of 45530 Old 06-04-2013, 07:42 AM
powell3wj
Primed and then clear coated my wheels with my center caps gold n also debadged her
powell3wj is offline
post #21716 of 45530 Old 06-04-2013, 09:18 AM
adavis39
yep...they will never go on again
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #21717 of 45530 Old 06-04-2013, 10:11 AM
lvngtheJEEPlife
Might as well take the back ones off. Don't go over 30 though cause the torque will pretzel the whole truck. Hahaha
post #21718 of 45530 Old 06-04-2013, 11:13 AM
wschilawski
Originally Posted by doorjamm View Post
For the long arms, those huge washers both go on one side. Noticed you put one on each side. May be different for the short arms and adjustable short arms, but just looking out for you!
You are correct - IRO said they both go on the outside to center the control arm to avoid any rubbing. Good catch!
wschilawski is offline
post #21719 of 45530 Old 06-04-2013, 11:29 AM
jpat30
"Primed and then clear coated my wheels with my center caps gold n also debadged her "- That looks really nice and matches the cladding pretty well. Never would of thought of that.
-Carpe Diem Phil 1:20
jpat30 is offline
post #21720 of 45530 Old 06-04-2013, 04:02 PM
ZB_WJ
Read an article
Where Chrysler tells the government NO they will not recall 2.3 million Jeep Grand Cherokees and Libertys.
Yes, WJs are included in this recall the government is demanding.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
wj
Redjeepwj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
