What did you do to your WJ today? - Page 1445 - JeepForum.com
 565Likes
post #21661 of 43614 Old 06-01-2013, 02:46 PM
doorjamm
Originally Posted by wschilawski
Installed lowers. Still working on the dreaded upper axle mounted bushing...
For the long arms, those huge washers both go on one side. Noticed you put one on each side. May be different for the short arms and adjustable short arms, but just looking out for you!
doorjamm is offline
post #21662 of 43614 Old 06-01-2013, 03:02 PM
wschilawski
Jks calls out one on each side. Didn't know if that would be the same for IRO? I'll give them a call this week to see if they can verify the spacer locations. Thanks!
Current Build | 08 JKU Sahara
Previous Build | 02 WJ | 2" BDS Lift
wschilawski is offline
post #21663 of 43614 Old 06-01-2013, 04:11 PM
PHAL23
Replaced Radiator and Thermostat..that was fun..
PHAL23 is offline
post #21664 of 43614 Old 06-01-2013, 06:35 PM
rdkendrick
2003 WJ
Originally Posted by ZB_WJ View Post
Took the Jeep to a flooded area
(I can upload pics!!!)
I got one of those little mirrors right in the same spot. I live on the Ohio River and we are getting your weather, now. I don't think it will flood, though, the river might come up some.
Sent from my iPad using Forum Runner
rdkendrick is offline
post #21665 of 43614 Old 06-01-2013, 06:45 PM
cykaaro
I'm hating my jeep lately. Wired up an override switch/relay for the fan so I'm good until I get the connector fixed, and will leave it there in case it's ever needed again. Also my rear pinion is now leaking. how much I don't know. Leaking axle seal and bearing were fixed, and the ujoint on the rear of the rear driveshaft had to be changed. Now it's losing oil out of the pinion. WTF?. This is on top of my tranny losing fluid still. Think I should check the transfer case while I'm thinking of it to make sure it's not leaking either. FML! Got my lower control arms ordered today at least.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #21666 of 43614 Old 06-01-2013, 08:12 PM
thisguyhasadd2
Just joined up with Jackson Hole Jeep Club. Going on a first outing tomorrow with the group and tonight alone
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #21667 of 43614 Old 06-01-2013, 09:19 PM
zephyr80
I ordered a new ss today.
Sent from your back seat!!!
zephyr80 is offline
post #21668 of 43614 Old 06-01-2013, 09:43 PM
Meta4
2010 WK
Did some more work under the hood today. Cruise control was still a bit finicky so I double-checked the work I did on the vacuum hoses yesterday. I found another cracked hose and fixed it. Cruise control works great now and holds steady for the first time since I bought my WJ in 2008. I ended up replacing/repairing a total of four different spots.
I also did my very first SeaFoam treatment today. With 165,000 miles on the clock, that thing smoked like a bandit. I put about 1/2 a can in the brake booster line, and 1/2 a can in the crank case (1.5oz per quart of oil). I put 1/2 of a second can in the fuel tank. I'm planning on changing my oil tomorrow after I find an excuse to drive 50-100 miles, should be interesting to see what the old oil looks like.
I also cleaned the IAC. I should have taken a picture. It was absolutely disgusting. My Jeep had been revving all over the place at idle (~600 RPM up to 2,200 RPM) and now it idles at a steady 650 RPM. This is the first time I've ever heard it so steady!
2004 Jeep Grand Cherokee Overland
Meta4 is offline
post #21669 of 43614 Old 06-01-2013, 09:54 PM
2ndhandWJman
After reading some of the maintenance threads on here, I've cleaned the TB ( off of the engine) along with the IAC valve, both were nasty. I'm still getting the occasional stumble/ almost stalling out while in gear so I decided to replace the fuel filter before diving too deep into possible causes. After getting a much needed gasoline shower ( good to know that 87 octane still tastes the same...) I got the new one on, started the jeep and had no leaks
I decided to cut open the one I took off.... - pretty sure it was the original one from the factory, circa 2003! I don't know how any gas could have flowed through it. Thinking I've 'fixed' my problem I take the jeep for a drive to Chili's for lunch. On the way back to the hut, at a red light, it stumbled again!
2ndhandWJman is offline
post #21670 of 43614 Old 06-02-2013, 08:51 AM
fsjmechanic
On my girlfriend's recently purchased '01 WJ.....
Yesterday:
- Changed oil with Mobil 1 filter and synthetic 10-W30
- Replaced headlights with Eagle One housings
- Replaced all front parking and turn signal bulbs
- Installed Philips 9011 HIR's for low/high and fog lights
- Replaced burned out license plate bulb
Today's Agenda:
- Drop xmission pan and use Wix #58843 (spin-on and flat filters, rubber gasket)
- Refill with Valvoline ATF+4
- Weld a drain plug bung in to the stock pan
- Replace rear upper/lower control arm bushings and ball joint (my D44 balljoint press tool and impact gun will work perfectly for the bushings)
- Replace POS Rancho shocks the PO put on with Monroe Reflex
fsjmechanic is offline
post #21671 of 43614 Old 06-02-2013, 09:15 AM
Jeep01AH
In the last few days:
-TJ fuel bezel mod
-nightshade on the taillights
-started to reprint the wheels the right way, that plasti dip wouldn't stop peeling!
| 2001 WJ - 4" Lift - Locked - 33s | My Build Thread:
| ΜΟΛΩΝ ΛΑΒΕ |
4 Wheel To Heal - Serving our wounded and disabled veterans -
- 4W2H
Jeep01AH is offline
post #21672 of 43614 Old 06-02-2013, 09:34 AM
4X4COWBOY
Yesterday was a busy day. Put on my ARB 5/8" shackles which I painted orange, put on my JCR stage 2 sliders painted silver, and the JCR window sticker (thinking its a little too "D-baggy" but like the look of it) Also got to do some mild offroading.
2001 WJ 4.7L V8, 6.5" IRO Critical Path Long Arms, 255/75/17 Firestone Destination M/T's, 17" JK Moabs, Flowmaster Super 40, SpiderTrax 1.25" Spacers, Hunter Bull Bar w/ Fawkes Fab Relocation Brackets, 5/8" ARB Shackles, JCR Stage 2 Sliders
4X4COWBOY is offline
post #21673 of 43614 Old 06-02-2013, 10:06 AM
madmax
madmax's Avatar
Last week I replaced radiator, thermostat, hoses and clamps. While the radiator is out of my Jeep, I washed the condenser with high-pressure garden water hose (from inside), I can't believe when I saw so much debris came off from the condenser - pebbles, grass, bugs, etc. Now, the engine runs cooler (approx 205 degrees, used to be 210-212) and the A/C runs more colder.
2000 WJ 4.0L, drop-in K&N filter, Addco rear antisway bar, Bridgestone Revos, Overhead DVD monitor w/ wireless headsets.
2007 BMW 335i, Montego Blue with Lemon seats, premium & sport package.
2004 TJ Sport 4.0L - SOLD :(
madmax is offline
post #21674 of 43614 Old 06-02-2013, 10:36 AM
wschilawski
Well, managed to replace upper/lower control arm up front along with the bushings except for one. I'll have them replace that one during the much needed alignment. The WJ drives a lot smoother now, not as much sway on the road.
Also tried fixing the creak in my steering by tightening the track bar frame bolt-ended up shearing that one.
One step closer to getting all the creaks and thumps taken care of. If its not one thing, it's five other things...
post #21675 of 43614 Old 06-02-2013, 11:29 AM
go-big
Yep that's jeep ( just empty every pocket ) lol
go-big is offline
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
ADennis , Ravenbar
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
