What did you do to your WJ today? - Page 1430 - JeepForum.com
 596Likes
post #21436 of 43799 Old 05-27-2013, 06:24 AM
platinum5.9
2003 WJ
Originally Posted by RIPNBST View Post
Installed my IRO 3" lift with bilsteins and adj track bar and everything went smoothly except their tap job on the female portion of the adj track bar was complete and utter ****. Had to run all over town to find a tap that big in a store open on sunday. Running 265/70/17 GY Wrangler Authority with no trim anywhere. It can be done for mall crawling but it needs a good trimming. Will get around to it next weekend probably. Flexed it in a buddy's drainage ditch and it rubbed in the rear BAD.
Congrats on the lift. Was the problem with the IRO track bar or JKS?
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #21437 of 43799 Old 05-27-2013, 07:07 AM
scross1220
2012 WK
Under carraige lighting.
______ooooo
/__l_l_,\____\,___
l_---l_l__l---[o]llllll[o]
_.(o)_)__(o)_)--o-)_)
If you're not fixing it, you're not driving a Jeep.
scross1220 is offline
post #21438 of 43799 Old 05-27-2013, 07:27 AM
alfaitalia
Originally Posted by rdkendrick View Post
Happy 180, Leroy!
That reminds me, I have had my WJ's up to about 110 MPH, has anyone ever figured out the top speed of them?
Sent from my iPad using Forum Runner
Top speeds varies depending on if yours is fitted with the guvnor or not.
4.0 118mpg w/o guvnor....105 with
4.7 124 w/o ....118 with
4.7HO 128 w/o....118 with
2.7CRD 118...NA with
3.1 td 108 w/o....NA with
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #21439 of 43799 Old 05-27-2013, 08:23 AM
ZB_WJ
I will never drive my WJ top speed. **** is scary enough at 80 lol
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #21440 of 43799 Old 05-27-2013, 09:00 AM
alfaitalia
Had mine flat out once....just to say i did you know (just over 120 on the clock)!....... it was rock solid but its only lifted a couple of inches....dont think think I would want to do the same thing on a 6 inch lifted one with winch bumpers etc!
post #21441 of 43799 Old 05-27-2013, 09:05 AM
SKI_VT
You also have to watch out for the top speed of your tires!
Mine I believe are up to 110
Don't exactly feel comfortable going near that number haha
"You people make it sound like Claytons are made from gold and unicorn bones while everyone else uses PVC and spaghetti noodles."
"The Great Turtle Race! -> Iceland vs. Bushwhacker! -> Place your bets!"
SKI_VT is offline
post #21442 of 43799 Old 05-27-2013, 09:11 AM
RIPNBST
It was the IRO bar.
RIPNBST is offline
post #21443 of 43799 Old 05-27-2013, 09:14 AM
danjones711
Wj New aftermarket rear sway bar
Hellwig 7/8" rear sway bar
Stiffer, but better ride
danjones711 is offline
post #21444 of 43799 Old 05-27-2013, 09:36 AM
alfaitalia
Load rating needs to be watched as well if you are going to go fast. I have H rated tyres...so thats 130 mph and the extra load version so thats 1000 kg (2200lb) per corner (8800lb total load). So im not worried about them folding at a "mere" 118mph with "only" 4700lb (2135kg)in weight!
Any way back on topic!!
post #21445 of 43799 Old 05-27-2013, 09:49 AM
BrugsBunny
Originally Posted by ialatham4
I replaced my radiator and thermostat and new coolant. But when I drive the temp goes up really fast any one know what the problem could be?
I am having literally the same problem, only difference is that the temp is fine if I'm moving, if I'm not moving and am sitting at an idle it rises...replaced the thermostat, still having the same problem, and notice that my fan doesn't kick when my radiator gets too hot...so my guess is a fan relay or worse a dead fan motor and my garage is closed today so I have no diagnosis yet...check your fan and see if the same thing is happening, maybe that's both our problem haha
BrugsBunny is offline
post #21446 of 43799 Old 05-27-2013, 09:52 AM
zephyr80
I went to the dealer recently and they told me about a fan relay recall. Could be your issue
Sent from your back seat!!!
zephyr80 is offline
post #21447 of 43799 Old 05-27-2013, 10:18 AM
ZB_WJ
Cleaned it out
ZB_WJ is offline
post #21448 of 43799 Old 05-27-2013, 10:25 AM
rickcricket
I crawled under it last night to diagnose a clunk in the rear. I found out that I am missing a couple hitch bolts anyone know the right size bolt and thread size?
rickcricket is offline
post #21449 of 43799 Old 05-27-2013, 10:30 AM
WJ4x4LIFE
To the Frame = M12x1.75x45
Crossmember to Frame = M10x1.50x35
A side note, I also fixed my rear clunking noise, turned out to be a loose upper shock bolt.
WJ4x4LIFE is offline
post #21450 of 43799 Old 05-27-2013, 10:47 AM
ZB_WJ
The INFAMOUS loose upper shock bolt!!!!
ZB_WJ is offline
Ravenbar
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 11 02-09-2017 05:03 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
