What did you do to your WJ today? - Page 1429 - JeepForum.com
 998Likes
post #21421 of 45537 Old 05-26-2013, 05:29 PM
BrugsBunny
Originally Posted by rdkendrick
Happy 180, Leroy!
That reminds me, I have had my WJ's up to about 110 MPH, has anyone ever figured out the top speed of them?
Sent from my iPad using Forum Runner
I've gotten 115 as well...but every time I drive fast it makes me miss my Beamer, which I got up to 155 at 5400 or so one time.
BrugsBunny is offline
post #21422 of 45537 Old 05-26-2013, 06:26 PM
pinky2252s
Check engine light popped on yesterday going to work. I pulled over and did the key dance and it showed me P 0700. I was actually happy it was a tranny issue and not an engine issue.
So, based on how it was acting and some diagnosis I replaced the input speed sensor. I would have just went a gotten it scanned with a DRB3 but its sunday, and all the shops are closed tomorrow so I just decided to throw the 20 bucks at it hoping it takes the sacrifice. Have any of you guys replaced the input speed sensor? Who the hell designed the shift cable to go right over the connector? That was annoying. But it only took a total of 10 minutes replacing it and now the problem is gone.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #21423 of 45537 Old 05-26-2013, 06:47 PM
ialatham4
I replaced my radiator and thermostat and new coolant. But when I drive the temp goes up really fast any one know what the problem could be?
ialatham4 is offline
post #21424 of 45537 Old 05-26-2013, 06:49 PM
STORM_JK
Finished this
'13 JK 6-spd | 3.5" RK | 35" MTR/K | Lots Of Welding
STORM_JK is offline
post #21425 of 45537 Old 05-26-2013, 06:57 PM
pinky2252s
Did you get the air out of the system? Im on my phone so I cant see if you have the 4.7 or the 4.0. The 4.7 has a bleeder screw, but for either engine you can unscrew the radiator cap and let it idle with the heat on full blast. You should see bubbles come out of the radiator cap. Let it idle untill it stops bubbling out. Then all the air should be gone.
Is it broken?
post #21426 of 45537 Old 05-26-2013, 07:04 PM
ialatham4
Yeah I did I have the 4.7 and bled it from the bleeder screw to start and then closed that and finished bleeding out of the radiator cap
post #21427 of 45537 Old 05-26-2013, 07:49 PM
gcsmorgan
Got her all shined up and loaded my GT Palomar to take to the trails. Beautiful weather today.
2002 Jeep Grand Cherokee Laredo Sport | 4.0L I6 | 2WD | 225-75-R16 BFG Radial Long Trail T/A
gcsmorgan is offline
post #21428 of 45537 Old 05-26-2013, 09:16 PM
RIPNBST
Installed my IRO 3" lift with bilsteins and adj track bar and everything went smoothly except their tap job on the female portion of the adj track bar was complete and utter ****. Had to run all over town to find a tap that big in a store open on sunday. Running 265/70/17 GY Wrangler Authority with no trim anywhere. It can be done for mall crawling but it needs a good trimming. Will get around to it next weekend probably. Flexed it in a buddy's drainage ditch and it rubbed in the rear BAD.
RIPNBST is offline
post #21429 of 45537 Old 05-26-2013, 09:25 PM
BigAl63
Looks nice!
2" BB, 1.25" wheel spacers
BigAl63 is offline
post #21430 of 45537 Old 05-26-2013, 09:27 PM
go-big
Keep a close eye on the lock nut on your track bar the tend to back off pore design
go-big is offline
post #21431 of 45537 Old 05-26-2013, 09:35 PM
lance-tek
Very True!!! Happened to mine too. Now i just keep an eye on it
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline
post #21432 of 45537 Old 05-26-2013, 09:56 PM
go-big
I am just going to weld a nut to the track bar and get a new one to lock it down the treads in the pipe are not deep enuff I don't think
go-big is offline
post #21433 of 45537 Old 05-26-2013, 10:52 PM
Justin_WJ
Wheelin at Potts mountain
2000 WJ Limited, 4inch RC X, 242 T-case swap, 33x12.50 STT's, 15x8 D window wheels with 3.75 BS, JKS ADJ. Tracbar, T-case armor, Custom front winch bumper, Smittybilt XRC 8, 4.56's Extended Rola Rack w/Harbor Freight 6" lights, and always muddy :)
Justin_WJ is offline
post #21434 of 45537 Old 05-26-2013, 10:58 PM
dillonjm
2013 WK
Looks like fun. Haven't been wheeling in a few months, getting the itch.
I'm going to miss the ability I had in AZ to hop in my rig and be climbing desert rock in 20 min.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #21435 of 45537 Old 05-27-2013, 03:24 AM
CrazyWalnut13
Happy 180, Leroy!
Mine has a governor at 114 or 115. Hit it both stock and after the 3" lift and 32"s. I was REALLY dumb when I was a little younger.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
wj
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
UtahBlues
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
