What did you do to your WJ today? - Page 1408 - JeepForum.com
 874Likes
post #21106 of 45184 Old 05-17-2013, 06:48 PM
wjidaho
Originally Posted by 99WJ539918
If I end up doing it this week I'll let you know how it turns out. I'm sure I'll post about it.
Cool thanks
My build thread
wjidaho is offline
post #21107 of 45184 Old 05-17-2013, 06:52 PM
SuperStew11
Replaced the oh so fun main brake line to the rear today
SuperStew11 is offline
post #21108 of 45184 Old 05-17-2013, 07:04 PM
Wenatchee_Kid
We like to hear about such "fun". Details?
Wenatchee_Kid is offline
post #21109 of 45184 Old 05-17-2013, 07:30 PM
SuperStew11
Well I bought two 5" lengths of line to replace it and first thing I find out is the fitting into the ABS is a totally different style fitting so I had to cut my brand new line and reuse the old one.
After putting on the fitting I start to bend the first half of the line from the front, it's a bit tricky getting it down from the engine kept getting caught on the tranny.
Once it was in place started to put in the back half it was easier because its the most straight part of the line but the real tricky part was that the lines just met up with each with only 1/2 an inch if play and they meet right at the cross member
Should have taken pics but forgot so I could of showed you my "handy" work. Doing an oil change tomorrow will try to take some pics to show
post #21110 of 45184 Old 05-17-2013, 07:32 PM
HavasuRat
Wj
Replaced the radiator, hoses and Thermostat. Snapped the top bolt off cause the @#$#$% rusted. Left just enough of the threads to get the channel locks a good grip...after banging on the bolt with a BFH ever so gently but stern it backed right out. Whew!!!
Next week is the leaking rear output seal on the tranny.
HavasuRat is offline
post #21111 of 45184 Old 05-17-2013, 07:36 PM
99WJ539918
I once did a brake line on an old Mustang I had. I measured and at every junction I rounded up by one inch and to the next inch (4 and a half inches became 6 inches, 3 inches became 4 inches, etc.). By the time I routed everything the way the stock line was I had about eight extra inches so I just made two loops above my axle into the block because my double flare at the end of that line was so nice at that end I didn't want to re-do it.
99WJ539918 is offline
post #21112 of 45184 Old 05-17-2013, 08:28 PM
Mudder_Trucker
Originally Posted by pinky2252s
And another one bites the dust...
I never have to worry about that. Anymore. I have spline drive
Mudder_Trucker is offline
post #21113 of 45184 Old 05-17-2013, 08:45 PM
cykaaro
Originally Posted by 99WJ539918 View Post
Yeah, I know that harness connector is there, and I know that the side view auto dim reads off of the same sensor (so when the rear view auto dims the side view also dims). I want to know about upgrading to the auto dim side view mirror. Can anyone help out with that? And what about $45 for the side view, good deal? Thanks.
From what I read you will have to hardwire the wiring from the sideview mirror to the rearview mirror yourself. Pretty much all the self dimming mirrors I've seen are made by GEN-TEX and have basically the same type of output from the mirror. (I put one in my Camry and hardwired it which as well had the compass built into the mirror) You will need to find what exact model of mirror you have, and what all the pins are for. Once wired up, the rearview mirror will automatically trigger the side mirror. I just tinted my front windows so works about the same.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #21114 of 45184 Old 05-17-2013, 08:56 PM
cykaaro
Well, ball joints drivers side are in. Steering feels a bit better. Found though that the wheel bearing was fubar'd so had to replace that as well. RE upper control arms went in. It's now feeling a lot better to drive upto about 80km/h now. From there it starts getting vibes, getting bad around 100km/hr or above. Braking above 100km/hr is not good feeling like it has badly warped front if you brake on the hard side. I'm thinking this is due to the front LCA's needing to be changed as well, the driving side being badly worn. Those will be done next, which leaves for last, the bushings on the axle. Thinking I'm in need of a bailout to get this damn thing the way it should be. Do damn broke trying to get all this done. Worried about he tranny as well. No codes have come back. Seems to shift fine. Driving home today though was costing on the small highway as I was coming up to a light, and something weird happened. Nearest I can discribe it, it's like when you run over a sizeable animal, but I didn't run over anything. Something to do with the driveline as near as I can figure. But was ok the rest of the way home. Don't get it. Rear pinion seal is seeping a bit as well. Not sure what's up with that. Had the back checked out and new oil put in with having the axle bearing/seal done on the one side. No play at all that I can tell. Wondering if the recent issue where the ujoint in the rear of the back driveshaft has something to do with what's going on. Really hoping the tranny is ok, because if something is really wrong I'm so definitely screwed. No money to to deal with it at all. FML. I need to win the lottery!!
Oh yeah. Oil was changed as well. Got to keep the new engine running well without problems.
cykaaro is offline
post #21115 of 45184 Old 05-17-2013, 09:11 PM
99WJ539918
It's always something, man. As far as the vibrations, mine has a slight vibration on the highway at around a little over 80 mph. I've never noticed because I usually don't drive that fast. I'm thinking it's either a driveshaft out of balance or something in the D30 or D35 that's not completely true. If you figure your vibration out let us know. Good luck.
post #21116 of 45184 Old 05-17-2013, 09:24 PM
cykaaro
I know. Nothing a few thousand couldn't fix, but don't have. My mechanic so far seems really good and he's really good on what he charges me. Wheel bearing was not expected but made sense doing it while doing the ball joints for the extra $110.
What I think the vibe is, is when I'm at higher speeds it's noticed, is the LCA's. And when I'm braking harder than I typically do at lower speeds, being the bushings are worn, big time on the drivers side where I feel the vibes are, and the UCA's being the new rubicon express, I think it's causing the issues, as there is too much play with them being soft, as the new wheel bearing and ball joints wouldn't cause it. Kind of like the back end which improved a bit with the really bad LCA being replaced, but would dog-walk until we did the a-arm bushigns and balljoint. That though causes me to feel the problems in the front now really well. Hoping I can get a good sale price on the LCA's beginning of June. Then need to get them in. Just I've got myself pretty maxed out right now again with all I've had to do the last couple weeks (rear axle seal, today's work, ujoint and the parts) Under 80km it drives pretty good now. Just weird things with the tranny this week but still seems to shift and everything ok. Had the p1762/62 tuesday morning but so far haven't come back. Making sure I'm fully stopped when I shift gears. I can be bad at times not being fully stopped when going from reverse to drive. Not anymore!
cykaaro is offline
post #21117 of 45184 Old 05-17-2013, 09:39 PM
99WJ539918
The gov. pressure solenoid issue is always weird, comes ang goes frequently.
I'm glad I work on my own cars, I couldn't afford to take my Jeep anywhere.
post #21118 of 45184 Old 05-17-2013, 09:41 PM
ZB_WJ
Put halogens in. Garbage hids are no longer going in my housings. I'm tired of replacing them
Every 5-10 months.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #21119 of 45184 Old 05-17-2013, 09:53 PM
cykaaro
Under Mitchells the codes can be many different things but seems the most common is the solenoid.
I do what I can, but issue becomes, some things I can't do, and if I run into problems I could be stuck (aka screwed) so I do what I can myself. In the last month or two I've had to do one caliper, one control arm, a-arm bushings/ball joint, now working on the front getting the bad bushings replaced. Got the AC working again as well. Transmission just started doing stupid **** this week on top of everything else. Just hope it's a glitch and nothing more. Can't afford anything else to happen.
Front driveshaft I'm trying to keep going until I can afford to replace it, and thinking the tranny mount needs to be done as well.
cykaaro is offline
post #21120 of 45184 Old 05-17-2013, 09:54 PM
cykaaro
Every 5-10 months.
Proper retrofit and good quality HID's. Over a year and still going strong. Too many cheap garbage HID bulbs and ballasts out there.
cykaaro is offline
wj
