What did you do to your WJ today? - Page 1318 - JeepForum.com
 827Likes
post #19756 of 45025 Old 04-15-2013, 09:23 AM
TheSiltSurfer
2012 WK
Originally Posted by lvngtheJEEPlife
What's the difference between the critical path and just LAs
I believe they are the same thing, also you can get a high clearance long arm kit that requires welding.
Infinite Patience Produces Immediate Results
TheSiltSurfer is offline
post #19757 of 45025 Old 04-15-2013, 09:28 AM
wvracer821
wvracer821's Avatar
The high Clearance just requires you to cut off the lower control arm mount.. No welding
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #19758 of 45025 Old 04-15-2013, 09:29 AM
tj_nite
2014 MK Compass
my lift kit will be here today when i get home from work if anyone wants to come over tomorrow have a beer and help on the install shoot me a txt at 920-427-4979
*2014 compass sport FWD 5-speed manual no mods yet*
*SOLD 2001 wj laredo 4x4. will be missed *
tj_nite is offline
post #19759 of 45025 Old 04-15-2013, 09:31 AM
lance-tek
Originally Posted by WJ_allday04 View Post
wheeled it and found out that I wheeled with a bad cv joint :-(
does anyone know how much/how difficult it is to fix it???
if you're talking about the front axel CV, I just swapped out both of mine and it's not a big job, just needed a slide hammer puller for the HUB, a 36mm Socket, 12 point 10mm socket (I think it was). the rest was simple stuff. Remove wheel and brakes, then hub, then pull out CV half shaft. if you have the tools already (and air), you can do it all in 2-3 beers for both sides.
There's actually a complete write up for it either here or JU I forget which. Just search for it
-lance
-lance
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline
post #19760 of 45025 Old 04-15-2013, 09:37 AM
wvracer821
wvracer821's Avatar
It is a 13mm 12pt. Dont forget the 18mm for the brake caliper
Junk: 2000 WJ, 4.0L
Build Thread:
post #19761 of 45025 Old 04-15-2013, 09:42 AM
lance-tek
Thanks for the correction
It's been a bit and I forgot. the brake caliper I had. Everything else, I had to take the wife's minivan to go pick up since I didn't have it in the garage already (that's how I found the write up thread to begin with)
post #19762 of 45025 Old 04-15-2013, 09:51 AM
WJ_allday04
Attachment 608026
Attachment 608027
An update on this: i drove home today and just checked the lug nuts on the wheel for no reason and all 5 lugs were so loose that i could finger tighten them a turn and a half
2004 WJ 4.7 - 7in lift
Rustys Long Arms//Rustys f+r springs//Rustys crossmember
CSL RLCA//Poly D30 bushings//IRO A arm
Skyjacker Nitro's//JKS trackbar//242HD+IRO SYE
WJ_allday04 is offline
post #19763 of 45025 Old 04-15-2013, 10:05 AM
lvngtheJEEPlife
Eh nbd, just makes for easy removal. Lol
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #19764 of 45025 Old 04-15-2013, 10:11 AM
ZB_WJ
Got new rock chips in my wheels from the mud yesterday, and my plastidip didn't hold up either
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #19765 of 45025 Old 04-15-2013, 10:16 AM
jimmay
Yesterday I changed my trans fluid and filters and installed the trans go shift kit. No more lazy shifts!
2002 Grand Cherokee Laredo 4.7
jimmay is offline
post #19766 of 45025 Old 04-15-2013, 10:23 AM
WJ_allday04
Ya i guess haha. Hey do you like your BDS springs? I was on their website and saw that they sell 4in lift springs seperate and im looking into getting them. Are they really stiff? Ive heard they are but user input is more reliable.
post #19767 of 45025 Old 04-15-2013, 10:29 AM
FaaipdeOiad
-lance
-lance
-lance
-lance
Yeah, the 13mm 12 pt was my downfall. I had to drive to a different city to find it. None of the stores around here had one. They're becoming scarce. Most everything sold now is 6 pt. But its a fairly easy job. Good luck WJ_allday.
"If you pizza when you are suppose to french fry. You will have a bad time"
-BaseCamp
FaaipdeOiad is offline
post #19768 of 45025 Old 04-15-2013, 10:47 AM
lvngtheJEEPlife
They are stiffer than stock but not to stiff to impact ride poorly. I like the extra stiffness, helps with squatting and trails. Love them
post #19769 of 45025 Old 04-15-2013, 10:51 AM
TheSiltSurfer
2012 WK
Was just test fitting these bad boys 285/70/17 going to need to trim front bumper cover to not Rub
post #19770 of 45025 Old 04-15-2013, 10:58 AM
03azwj
2003 WJ
Just ordered my IRO adjustable Lower and Upper CA's.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
wj
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Grippy0
