What did you do to your WJ today? - Page 1251 - JeepForum.com
 554Likes
post #18751 of 43581 Old 03-22-2013, 03:37 PM
Jaketit
Was kinda looking for a small "I'm bored" project to do to day so I did the torque management elimination today. I ended up putting in a toggle switch in that I had laying around.
Jaketit is offline
post #18752 of 43581 Old 03-22-2013, 03:46 PM
03azwj
2003 WJ
Originally Posted by JimmydaGreek View Post
For sure, TRE's are the first thing to check then control arm bushings before you start with the ball joints and steering box.
Ok. What exactly am I looking for with the TREs?
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #18753 of 43581 Old 03-22-2013, 04:09 PM
shockracer
Found this, it should point you in the right direction.
https://www.youtube.com/watch?v=XLOB...e_gdata_player
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #18754 of 43581 Old 03-22-2013, 04:29 PM
JimmydaGreek
2015 JK Wrangler
Have someone get in the driver's seat and jerk the steering wheel left and right and see if everything is solid or if you have movement in the bushings. Sometime there's all clicking because the bushings are completely gone. Moog makes great TRE's avail from rockauto.com and if you're going to do it yourself, it's easier if you pick up the bar with the adjusting sleeves for pretty cheap.
Here's a 5% off coupon too, just enter it in the How did you hear about us field: 1387537610156846
2015 JK Unlimited Rubicon Loaded
2002 WJ Ltd 4x4 4.7L Upcountry/Selectrac
JimmydaGreek is offline
post #18755 of 43581 Old 03-22-2013, 04:40 PM
wvracer821
wvracer821's Avatar
Synergy HD ball joints going in as we speak
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #18756 of 43581 Old 03-22-2013, 04:40 PM
JimmydaGreek
2015 JK Wrangler
Putting them in yourself?
post #18757 of 43581 Old 03-22-2013, 04:44 PM
wjidaho
Originally Posted by FaaipdeOiad
85% of all fords made are still on the road today . . .
The other 15% made it home
Lol not that's funny
My build thread
wjidaho is offline
post #18758 of 43581 Old 03-22-2013, 04:48 PM
03azwj
2003 WJ
I was looking at replacing the CA's to adjustables from IRO. I'm almost at 4" of lift and was thinking it would be a good idea.
Definitely helped. Thanks, that's part of my problem.
I looked on rockauto.com at the Moog ones. I'm a little confused between the different ones there. I know I need the outers, but there's one from the pitman arm to the steering arm and one from steering arm to steering arm.
03azwj is offline
post #18759 of 43581 Old 03-22-2013, 04:54 PM
JimmydaGreek
2015 JK Wrangler
There are 4 all together and I posted the part numbers either in this thread earlier this week or another one if you do a seach. I also just bought and received the IRO front upper and lower adj CA's and will install them soon. Don't forget to order the 2 upper arm to chassis bushings that are not on the arms. You can get Crown replacements from Kolak for $15 each + shipping.
post #18760 of 43581 Old 03-22-2013, 05:06 PM
03azwj
2003 WJ
Awesome. Thanks a lot. Time to start ordering.
03azwj is offline
post #18761 of 43581 Old 03-22-2013, 05:38 PM
ARFuniN
Replaced my heater core, evaporator and the manual control version of blend doors...18 hours over 3 days!
Thanks to:
1) http://www.wjjeeps.com/hvac_ip_remove.htm for step by step instructions
2) https://www.youtube.com/watch?v=JM_oGK1DVXw for step by step direction
3) http://www.oreillyauto.com/site/fi/s...s/85737/25.oap for the evaporator and heater core
4) http://www.justforjeeps.com/ for the manual version of the blend doors
One Nation,under God, indivisible, with Liberty and Justice for ALL.
ARFuniN is offline
post #18762 of 43581 Old 03-22-2013, 05:39 PM
fast540
Prepped for the jeep forum NorCal trail run at Hollister hills tomorrow am
fast540 is offline
post #18763 of 43581 Old 03-22-2013, 05:49 PM
njjeep12
Thank you Kolak
njjeep12 is offline
post #18764 of 43581 Old 03-22-2013, 06:03 PM
platinum5.9
2003 WJ
More details?
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #18765 of 43581 Old 03-22-2013, 06:25 PM
Svensson
Started on the Bushwackers today.. 4" lift coming on when loqal authority's have approved the broadening of the jeep. doing the three other corners tomorrow!
2004 WJ 2,7 CRD.
2" OME lift, rear addco swaybar, 17" Ion Alloy 171 w/33/12,5x17 Baja MTZ's, 2 din bezel, 30" led lightbar, JKS adjustable trackbar, Rancho SS, Bullbar, Projector Headlights, front Carolina Drivline. Bilstein shocks for 4" lift, 2"BB, IRO front UCA.
Build Thread's:
Norwegian site:
Jeepforum Picture/Buildthread:
Svensson is offline
thecause17
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
