What did you do to your WJ today? - Page 1184 - JeepForum.com
 1095Likes
post #17746 of 45730 Old 02-23-2013, 09:37 PM
doorjamm
Got my ENGO 40" bar on. Tested it with jumper cables, wiring will be done when I get some light tomorrow and it's not so cold.
doorjamm is offline
post #17747 of 45730 Old 02-23-2013, 09:50 PM
gcjeeping
gcjeeping's Avatar
Did the companies do anything for ya?
_____________
gcjeeping is offline
post #17748 of 45730 Old 02-23-2013, 09:59 PM
doorjamm
I got a reply from TruckAddons saying they'd contact me shortly with instructions and authorization to return it to Engo, and then I never got contacted shortly... Waited a month, got impatient, and threw it on. The marks aren't noticeable up there unless you're trying to really look for them I guess. Still disappointed that they shipped it like that, but for 380, I'm still satisfied and I LOVE the output.
doorjamm is offline
post #17749 of 45730 Old 02-24-2013, 12:29 AM
doorjamm
How are your lights wired? Where should I run them?
doorjamm is offline
post #17750 of 45730 Old 02-24-2013, 03:39 AM
1salem1
Gave my ride a temporary paint
1salem1 is offline
post #17751 of 45730 Old 02-24-2013, 03:41 AM
1salem1
This another picture
1salem1 is offline
post #17752 of 45730 Old 02-24-2013, 08:25 AM
MadMonk
I started hearing this hissing noise all of a sudden from under the dash. It seems that the brake booster started leaking. Sounded like an 18 wheeler's air brakes every time I stepped on the pedal.
I replaced the booster last night. It took about 3-4 hours because I was figuring it out as I went along, plus I figured out that I needed a 13mm deep well socket that I didn't already have to get the booster unbolted from the firewall. Man, that thing is wedged back in there. You have to remove the evap canister and solenoid, and I also ended up removing the air filter box so that I had room to pull the brake distribution block and master cylinder back as a unit to keep from kinking the lines. The master cylinder does have some flexible lines so you can finesse it a bit to get the booster out, but the little bit of extra room you get by pulling the air filter box out really helps.
Everything is back together now, but I ran into an issue where the new booster's brake pedal connector rod was about 1/4" shorter than the old one. This meant that whenever you let off of the brake pedal the brake pedal bar wouldn't go back far enough to engage the brake light switch. The switch is not adjustable and there's no way to adjust the length of the rod. After a few minutes of cussing, I just ended up slightly bending the bracket that holds the switch so that it makes contact with the pedal bar. I sent Cardone (who makes these rebuilt units) an email telling them about it too.
The under-hood work was pretty simple and easy, but working under the dash to unbolt and reinstall the booster was a pain in my back, especially so since I had to spend so much time trying to get the brake light problem fixed. I'm feeling it today. Ibuprofen is my friend.
'99 WJ Limited 4x4, 4.0L, Patriot Blue Metallic, IRO 3" springs, track bar, and rear sway bar links, Doetsch Tech 8000 shocks, Tenneco steering stabilizer, Carolina Driveline double-cardan front drive shaft.
MadMonk is offline
post #17753 of 45730 Old 02-24-2013, 09:56 AM
Justin_WJ
Took the boy to go play
2000 WJ Limited, 4inch RC X, 242 T-case swap, 33x12.50 STT's, 15x8 D window wheels with 3.75 BS, JKS ADJ. Tracbar, T-case armor, Custom front winch bumper, Smittybilt XRC 8, 4.56's Extended Rola Rack w/Harbor Freight 6" lights, and always muddy :)
Justin_WJ is offline
post #17754 of 45730 Old 02-24-2013, 11:40 AM
aleet25
2003 WJ
Got tired of always having to use Back To Black on all my plastics when I washed it, so I decided to bedline everything today instead. It worked a few months back on my lower cladding, so I thought why not the other stuff. Side view mirrors, door handles, and rear hatch trim.
aleet25 is offline
post #17755 of 45730 Old 02-24-2013, 11:55 AM
lvngtheJEEPlife
Spray on? That looks really good!
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #17756 of 45730 Old 02-24-2013, 12:03 PM
aleet25
2003 WJ
Yeah. It's the Rustoleum spray on.
aleet25 is offline
post #17757 of 45730 Old 02-24-2013, 12:28 PM
USMCBehrensDVLD
I've thought about doing that too. How easy is it to clean though? My concern is after you go 4 wheeling it seems like it be hard to get the dirt off since its a coarse layer
2004 Jeep WJ Freedom,4.5inch TerraFlex Coils, CLAYTON Front Long Arms, 2014 Rubicon Wheels on 33s AT
USMCBehrensDVLD is offline
post #17758 of 45730 Old 02-24-2013, 12:33 PM
sage39henry
Disconnected the front for the first time since putting the lift on
WHITE WJ LIMITED 4.7 242HD/ IRO arms w/ Rusty's 4.5in coils/Doetsch 5in Shocks/JKS Quicker Disco's/ D44a Spartan Locker/ Rigid Industries 10" light bar/ 33 12.50 15 Mickey Thompson MTZ/ V-5s
sage39henry is offline
post #17759 of 45730 Old 02-24-2013, 12:40 PM
aleet25
2003 WJ
It's not hard at all. I use a tire brush. It scrubs the dirt right off. I've left dirt and mud on for a few weeks and it scrubs off easy. I've found that dirt stains plastic parts if you don't get it off soon.
aleet25 is offline
post #17760 of 45730 Old 02-24-2013, 12:54 PM
zephyr80
I finally finished my rack and attached it this morning
Sent from?
zephyr80 is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
