What did you do to your WJ today? - Page 1150 - JeepForum.com
 924Likes
post #17236 of 45346 Old 02-06-2013, 06:45 PM
XC_Jeeps
Originally Posted by mdrum93 View Post
Any rust problems? And is it good quality? (Is it like cheap plastic) I really like that look and that thing on ebay right now is $75...might be a hard deal for me to pass up.
Well mine is plastic, I don't think they sell mine anymore because with mine it only has one switch that turns on all the lights. Nonetheless, its held up well for the couple of months that I have had it on. Also, I get compliments all the time that it looks like it was made for the Jeep.
2002 Special Edition 4.7L V8 2"BB
XC_Jeeps is offline
post #17237 of 45346 Old 02-06-2013, 07:07 PM
roach68
Originally Posted by lvngtheJEEPlife
What paint did you use? Prep?
I removed them from the jeep, wet sanded with 320, washed then degreased with brake parts cleaner. Primed them white with Rust-Oleum primer, then top coated with Rust-Oleum Silver Metallic then put a couple coats of clear on.
FOR SALE.
PAC SWI-Jack Steering wheel control interface-$35 shipped
roach68 is offline
post #17238 of 45346 Old 02-06-2013, 08:09 PM
spud2388
Finally received my motor mounts from Kolak. Now hopefully I can get them changed out, find out if the manifold gasket is split and causing my whistling or if my manifold is cracked somewhere. Get that fixed and hopefully get rid of all the vibrations that I have when stopped in drive.
spud2388 is offline
post #17239 of 45346 Old 02-06-2013, 08:10 PM
mdrum93
Originally Posted by roach68
I painted mine over the past summer.
Hows the painting holding up? Any chipping?
Bumper Thread
mdrum93 is offline
post #17240 of 45346 Old 02-06-2013, 09:28 PM
Teflon916
So my transmission pan was leaking because of my poor rtv job. So I went under there and tried to tighten some of the bolts and ended up snapping one of the heads off.... Now it's leaking twice as bad. So I guess tomorrow I will be dropping the trans pan again.
Also took my front double rzeppa driveshaft out. Boot was ripped pretty good. Going to the junkyard to try and find another since I'm poor and can't afford to upgrade. All I have is a 2in bb so I should be ok.
Teflon916 is offline
post #17241 of 45346 Old 02-06-2013, 09:50 PM
GrandPuba
Sucks about the trans.... But you might be able to junk yard an upgrade front shaft....some came with "the good kind". I also read that a ZJ shaft can work...but I think you have to get both yokes. That's what I'm going to do, but my axle side is a u-joint, so I don't need to worry about swapping that thing.
If you can't google it, you really shouldn't be looking it up.
'04 Grand- OME HD blah blah
'65 Chevy C-10...things are happening...
'88 Comanche...dead and buried :(
GrandPuba is offline
post #17242 of 45346 Old 02-06-2013, 10:04 PM
compcrasher86
ZJ transfer case yoke will not mate with a WJ transfer case. Changing the Diff yoke I also heard from somewhere is more difficult because the torque spec is very... very important. OP if you can find a WJ with a double cardan front shaft snatch it up if you can... and then follow instructions for switching axle yoke very carefully.
Matt
compcrasher86 is offline
post #17243 of 45346 Old 02-06-2013, 10:41 PM
GrandPuba
Yes, I did also read you need a yoke off a 246 I think? I need to find that info again. I'm glad I don't have to deal with the axle.
post #17244 of 45346 Old 02-06-2013, 10:48 PM
Teflon916
Yea I'm not very confident that I could change change out the yokes my self. When I get enough money I will buy a new double u joint style shaft and pay a shop to put it in. Probly buy the shaft from the shop too just to make it easy.
post #17245 of 45346 Old 02-06-2013, 11:39 PM
99WJ539918
Originally Posted by gcjeeping View Post
Took it out to stretched its legs and parked next to a stalk WJ.
That's a great picture. They don't look anything like each other at all.
99WJ539918 is offline
post #17246 of 45346 Old 02-07-2013, 05:30 AM
ZB_WJ
Jeep on the right, now for sale or being traded in later this week lol
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #17247 of 45346 Old 02-07-2013, 06:06 AM
ZB_WJ
Or hopefully lifted
ZB_WJ is offline
post #17248 of 45346 Old 02-07-2013, 07:43 AM
roach68
Great so far, I have yet to use the roof rack for hauling so I can't speak for its durability
FOR SALE.
roach68 is offline
post #17249 of 45346 Old 02-07-2013, 08:43 AM
bendafinga
2015 WK
Replaced the tail lights with new aftermarket ones because I got tired of tinkering with the poor socket connections.
bendafinga is offline
post #17250 of 45346 Old 02-07-2013, 08:50 AM
skeet2000
Replaced the fan relay. Thank you to who ever owned it before me for cutting the access hole
skeet2000 is offline
wj
buns_1
