What did you do to your WJ today? - Page 1141 - JeepForum.com
 1106Likes
post #17101 of 45746 Old 02-03-2013, 02:53 PM
PAJeep6
Installed a new CD player in my WJ today. Completed the install, but didn't buy an antenna adapter, so I had to run back to the stereo shop. All good now. Next weekend maybe I can finally install my sub and amp.
02 WJ - 4.7 | Black Rocks | 33" Treadwright Guard Dogs | 3" exhaust | 6.5" LA lift...
PAJeep6 is offline
post #17102 of 45746 Old 02-03-2013, 03:01 PM
ZB_WJ
Carbon Fibered the dash. Still debating if I want to do the HVAC or not.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #17103 of 45746 Old 02-03-2013, 04:03 PM
Thomahawk
2006 XK Commander
Looks good, you Will need to do that piece to,,,
Buildthread
Thomahawk is offline
post #17104 of 45746 Old 02-03-2013, 04:18 PM
XC_Jeeps
Picked up some overland rock rails today for $70... one of them was completely rusted over, the other one had been sand blasted. So I set to work with the belt sander and dremel to get the rusty one ready for paint.
Went from this
And this...
To this
Sorry for the bad low light phone picture
2002 Special Edition 4.7L V8 2"BB
XC_Jeeps is offline
post #17105 of 45746 Old 02-03-2013, 05:08 PM
tj_nite
2014 MK Compass
washed it after our big snow storms and filled my coolant bottle i dont know why it keeps going low. before and after pics
*2014 compass sport FWD 5-speed manual no mods yet*
*SOLD 2001 wj laredo 4x4. will be missed *
tj_nite is offline
post #17106 of 45746 Old 02-03-2013, 05:09 PM
doorjamm
Have the same coolant problem and can't find the leak.
doorjamm is offline
post #17107 of 45746 Old 02-03-2013, 05:13 PM
XC_Jeeps
Have you checked the passenger floor?
XC_Jeeps is offline
post #17108 of 45746 Old 02-03-2013, 05:27 PM
CantFocus
2003 WJ
Hey TJ do you have a lift at all? I just found a set of black moabs on craigs for pretty cheap and you have the same color/model as me, so your pics are giving me an idea of how it would look.
Zombie Outbreak Response Unit #338
2003 WJ Laredo 4.7 Loaded including Upcountry Package - 2" BB - Rola rack - V3 Black Projectors - 55W 5000k HIDs - Yellow 9005 fogs - JKS Discos.... More to come
CantFocus is offline
post #17109 of 45746 Old 02-03-2013, 05:59 PM
rickcricket
Get a pressure test if its not on your passenger floor.
rickcricket is offline
post #17110 of 45746 Old 02-03-2013, 06:02 PM
tj_nite
2014 MK Compass
i do not have any lift had to do allot of trimming to make these fit without rubbing but i am going to be putting a 3" lift on as soon as i have money. the back only rubs if i flex pretty good doesnt hit anything on the other side of the tire or the front of the tire only the rear of the tire if you can tell from the pic.
and on the front tire had to trim a little of the front bumper and in the wheel well. im very happy with them even with out a lift cant wait till spring hits and its warm out to work on my jeep again. if i was you i would get them
tj_nite is offline
post #17111 of 45746 Old 02-03-2013, 06:03 PM
tj_nite
2014 MK Compass
yeah its not on my passanger floor so i will
tj_nite is offline
post #17112 of 45746 Old 02-03-2013, 06:07 PM
USMCBehrensDVLD
Check your water pump, mine was leaking through the weep hole. Pretty easy fix too
2004 Jeep WJ Freedom,4.5inch TerraFlex Coils, CLAYTON Front Long Arms, 2014 Rubicon Wheels on 33s AT
USMCBehrensDVLD is offline
post #17113 of 45746 Old 02-03-2013, 06:33 PM
gcjeeping
gcjeeping's Avatar
Just do it.
_____________
gcjeeping is offline
post #17114 of 45746 Old 02-03-2013, 06:44 PM
Harriedtwo
2011 JK Wrangler
Wj What I've done since October
What have I done. I bought the Jeep WJ with just under 168,351 miles in mid October, 2012. I had no record of maintenance, I decided to fix the critical items and do the needed maintenance. My work so far: replaced front tie rods with Moog; replaced upper rear control arm and rear ball joint, replaced rear door actuator, replaced all six struts, bought anti-sway bar replacement rubber (I'll change this week), replaced tires with correct size (old tires were too big and didn't match in depth), aligned front and rear, replaced fluids in front and rear axles as well as transfer case. Changed oil, replaced power steering hoses and fluid, replaced all four O2 sensors (one had broken plug which triggered code). Still to do: change transmission fluid and filters (scheduled for this week), replace seal where driveshaft enters transfer case since its leaking. Sometime next month I'll change get the radiator flushed and new anti-freeze installed. Then, if the weather cooperates, I'll wash the Jeep and paste wax it.
Harried Harry
2011 Jeep Wrangler Unlimited Rubicon.
Wife: 2014 Grand Cherokee Limited
Harriedtwo is offline
post #17115 of 45746 Old 02-03-2013, 06:56 PM
shockracer
I had this same problem just before my shaft seal on the water pump had blown.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
wj
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
