What did you do to your WJ today? - Page 1112 - JeepForum.com
 1102Likes
post #16666 of 45739 Old 01-19-2013, 05:43 PM
CoastieShep
Jacked it up, used a pressure washer to blow out the mud from the last couple trips that I couldn't get with the regular hose.
CoastieShep is offline
post #16667 of 45739 Old 01-19-2013, 08:48 PM
TJSWJ
Dismounted a set of 37's for a friend of mine for trade on a set of superior outer tube seals. Ill be replacing the inner seals on my d30 here soon, so figured nows the time to add these.
TJSWJ is offline
post #16668 of 45739 Old 01-19-2013, 09:28 PM
JerzeyBoyWJ
2003 WJ
tried them on my dana30 and they hit the cv shafts so they wont work ..
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #16669 of 45739 Old 01-19-2013, 09:31 PM
jbruse
Originally Posted by djpeters
E-mailed Kolak asking for tracking numbers for my 3" exhaust,..... no response, grrrrr, I'm impatient!
Don't worry he is swamped right now. I've been in conversation with him several times this week.
jbruse is offline
post #16670 of 45739 Old 01-19-2013, 09:48 PM
TJSWJ
well that sucks! wonder why they say they fit WJ on the box then?
TJSWJ is offline
post #16671 of 45739 Old 01-19-2013, 10:34 PM
Jeeples
Jeeples's Avatar
Originally Posted by 04Overland47 View Post
Installed a set of Bilstein shocks, thanks Kolak!! Jeep rides and handles so much better and feels extremely solid over bumps. Definitely recommended!
Nice! That's what I have lined up for tomorrow.
Big shout out to Kolak!
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #16672 of 45739 Old 01-19-2013, 11:23 PM
gtg413i
2003 WJ
Originally Posted by jahcure
Most importantly how you put them on without breaking them
Carefully remove the top left corner first by prying the clip with a small flathead. Then top right, then the others. I figured that out too late.
Brian's Black Betty Build:
gtg413i is offline
post #16673 of 45739 Old 01-20-2013, 07:33 AM
Thomahawk
2006 XK Commander
From this to this>>>
image-1905087729.jpg   image-2726294041.jpg   image-3847827653.jpg   image-362985011.jpg
Buildthread
Thomahawk is offline
post #16674 of 45739 Old 01-20-2013, 07:34 AM
Thomahawk
2006 XK Commander
And this to this
Buildthread
post #16675 of 45739 Old 01-20-2013, 08:14 AM
Prickett10
I went out and got me some Goodyear wrangler m/t 245/75/16! They rub a little at full lock and when flexing *as much as a stock suspension will flex. But these babies look much better than the 225/70/16's that were on it.
Prickett10 is offline
post #16676 of 45739 Old 01-20-2013, 08:29 AM
Son-of-Beast
2010 JK Wrangler
Replaced transmission input and output speed sensors in vain attempt to fix a transmission issue that came on without warning. Added an Actron CP9125 Scanner to the toolbox. Really disappointed this came up like this. Was planning on getting a Bluetooth OBDII scanner and the TORQUE App for my phone and tablet but this took that budget plus ate into my planned Spring and Bushwacker budget, and I still don't have a fix - good thing I have an overseas trip and overtime coming up - these things have a way of taking care of themselves.
2010 JKU Rubi, 6-spd, AEV Frt, Warn 9.5, SRC Side Armor, Rancho Rr Carrier, 730RER, BFG M-T KM's
Son-of-Beast is offline
post #16677 of 45739 Old 01-20-2013, 11:40 AM
dsodko
Wj Dash top cover squeak
Finally fixed a squeak in the dash. The top cover (cover for speaker next to windshield). was not tight in the middle between the defrost vents.
The center plastic support had bowed up due to the heat here in Atlanta. I screwed it down to the original position with a black trim screw.
Simple fix. Squeak gone !
dsodko is offline
post #16678 of 45739 Old 01-20-2013, 12:45 PM
fosterjd79
Replaced the radiator and stopped that leak but then found a valve cover leak. Something to look forward to. Hey, if the WJ isn't seeping fluid from somewhere it isn't happy.
fosterjd79 is offline
post #16679 of 45739 Old 01-20-2013, 01:58 PM
wheelhead
Put a new water pump in it. No more moving, squeaky bearing. Also went though the car wash too.
wheelhead is offline
post #16680 of 45739 Old 01-20-2013, 02:05 PM
Son-of-Beast
2010 JK Wrangler
Replaced TPS as part of troubleshooting a transmission issue - turns out it wasn't the TPS but probably due at 11-12 yrs and ~164K miles. Kept the part just in case and new one came with lifetime warranty.
wj
99WJ01TJ
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 34 09-11-2017 08:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 8 09-01-2017 01:58 PM
