What did you do to your WJ today? - Page 1095 - JeepForum.com
 559Likes
post #16411 of 43595 Old 01-10-2013, 02:54 PM
ZB_WJ
Conventional green antifreeze formulations usually contain a number of inorganic corrosion inhibitors that provide immediate corrosion protection because they maintain the pH of the solution (buffer it), but are consumed or transformed chemically as they perform their functions. As the coolant is heated and cooled, and exposed to air, the components of the conventional antifreeze additive package are depleted over time. This causes the pH to drop, and is why the coolant should be changed out every two years or 24,000 miles.
Dexcool-type extended life coolants use organic acid technology to inhibit corrosion, and are referred to as OAT based coolants. OAT antifreezes are touted as having longer potential service life than conventional antifreezes because of the fact that the components in the additive package are not chemically consumed as they perform their function of inhibiting corrosion. The chemicals used in the OAT type formulas protect metals from corrosion by forming a thin, molecular coating on them, and because of this, are not as fast acting as conventional inorganic formulas. However, as long as the cooling system is kept sufficiently full and coolant is not lost due to leakage nor diluted by top-off with water or conventional antifreeze, it will continue to function properly. Unfortunately, if the cooling system is not properly maintained, a “red muck” is likely to form and could cause serious cooling system problems.
The third type of antifreeze on the market today is the hybrid OAT, known as HOAT (or G O-5). One of the primary problems with OAT formulations is that they are not compatible with conventional antifreezes. The chemicals used in OAT antifreeze react to some extent with some of the inorganic salts and other components in conventional antifreeze. The result of this interaction is the generation of cloudiness and precipitates. HOAT formulations are called hybrid because the additive package contains ingredients from both OAT and conventional formulas and is compatible with both.
Hybrid OAT antifreezes provide both fast acting and extended life corrosion protection, eliminate the problem of anti- freeze compatibility, and therefore are compatible with all types and colors of antifreeze.
Unfortunately, many automotive professionals consider all extended life antifreeze to be “Dexcool” and associate all the problems related to “Dexcool” with both OAT and HOAT formulas. The result of this misconception is often replacing the extended life coolant with conventional green. Industry experts say that this can be done safely if all of the green antifreeze is removed from the system. However, auto manufacturers recommend specific formulations and replacing the factory fill coolant with a different type that doesn’t meet the manufacturer’s specifications could cause liability issues down the road. A much safer solution is to replace OAT systems with HOAT coolant which meets OAT specificationsFrom recycool
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #16412 of 43595 Old 01-10-2013, 02:54 PM
ZB_WJ
OAT is not HOAT
ZB_WJ is offline
post #16413 of 43595 Old 01-10-2013, 03:00 PM
lvngtheJEEPlife
So im guessing he put the OAT stuff in there.. I leave for college in two days so this really needs to be straightened out.
EDIT: Well walked out there expecting orange dexcool. Not even. Its green.
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #16414 of 43595 Old 01-10-2013, 08:19 PM
jrmilks
Just got it back after 4 days because it was in the shop getting the transmission rebuilt. First thing my 4-year-old daughter did when I got home with it was insist that I put her car seat back in. How insistent was she? She got my keys and was going to do it herself if I didn't. Man, I'm going to be in trouble in a few years....
jrmilks is offline
post #16415 of 43595 Old 01-10-2013, 08:37 PM
cbailey_21
Changed my instrument panel and hvac to cool white LED bulbs
Before
After
Originally Posted by smuggler View Post
Ah yes that is a common Jeep thing, weird noises after wheelin'. This is how you fix it. You have to go wheelin' again, but in reverse. Once you get done the clunk should be gone.
MODS: BDS 2" coils, Bilstein 5100 struts, 17"Moab takeoffs, 245/65/17 Hankook Dynapro ATMs, Addco 1" Rear Swaybar, Energy Suspension greasable swaybar bushings, westin tail light guards, Rancho HD Steering stabilizer, Freedom Edition running boards, Spyder Halo Foglights, Rola Vortex roof rack.
cbailey_21 is offline
post #16416 of 43595 Old 01-10-2013, 08:38 PM
heffercow
1992 XJ Cherokee
Originally Posted by yjryder View Post
ordered spring isolators from kolak. cant wait to put them on.
I know the feeling, but all my my stuff finally came in... sounds great though. which muffler you get?
92 xj, 8 inches w/ long arms, 36's locked rear, rattle can spray job, and countless other budget mods
99 wj limited, 4.7l, 2.5in. rustys springs, pro-comp es9000 shocks, black moabs, 255/70/17 hankook dynapro ATM RF10, still a work in progress
99wj laredo, 4.0l, previous work in progress, now just gathering dust in garage.
heffercow is offline
post #16417 of 43595 Old 01-10-2013, 08:40 PM
jeepster250
Week 2 without my wj I am slowly dieing.
jeepster250 is offline
post #16418 of 43595 Old 01-10-2013, 08:42 PM
shockracer
Before
After
Do they dim too?
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #16419 of 43595 Old 01-10-2013, 08:42 PM
adavis39
Before
Attachment 541143
After
Attachment 541144
Attachment 541145
very nice man....wish I could find a way to keep my limited white face gauges but have them look like this at night
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #16420 of 43595 Old 01-10-2013, 08:48 PM
LilLuKe
Sold it ):
LilLuKe is offline
post #16421 of 43595 Old 01-10-2013, 08:52 PM
jeepster250
Before
After
Nic
post #16422 of 43595 Old 01-10-2013, 08:53 PM
jeepster250
Originally Posted by LilLuKe View Post
Sold it ):
Whyyyyyy
post #16423 of 43595 Old 01-10-2013, 09:03 PM
LilLuKe
I'm starting school back and need something a little more highway friendly and wallet friendly sadly. Ill be back in the game before long though. Ill probly still hang out here a little bit and keep trying to help people out.
LilLuKe is offline
post #16424 of 43595 Old 01-10-2013, 09:35 PM
yjryder
2003 WJ
Umm....... I didn't get a muffler
yjryder is offline
post #16425 of 43595 Old 01-10-2013, 09:54 PM
Timbo24
Did you sell to mrJ?
Timbo24 is offline
keekee1
Just got my xenon on today ! unbelivable ! gaignstar WJ Grand Cherokee Forum 10 11-19-2016 08:04 AM
Tried to do Spark Plugs today in the 4.7--Didn't happend Astorm WJ Grand Cherokee Forum 43 03-24-2014 09:35 PM
Died today... jimbo141 WJ Grand Cherokee Forum 28 05-09-2011 09:20 PM
I want to order some brakes today matrix849 WJ Grand Cherokee Forum 30 07-25-2010 02:01 AM
found an ad today KI4KWF WJ Grand Cherokee Forum 3 07-30-2007 01:27 AM
