What did you do to your WJ today? - Page 1060 - JeepForum.com
 738Likes
post #15886 of 44511 Old 12-25-2012, 06:28 PM
shockracer
Originally Posted by PhantomWJ View Post
Nada. They were used in the same ol' block...same ol' mileage.
Same block but many many things changed over the years, the 95 had a more aggressive factory cam and better 5 hole injectors. 96-99 they turned the cam down and went with 4 hole injectors, these are vary popular swaps for the 1g SOHC engines. I have thousands of neon parts in my garage but only one set of 95 injectors and cam and they are on my 95.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #15887 of 44511 Old 12-25-2012, 06:50 PM
WJlover
tomorrows plan of action.
some custom work.
starting with ideas for a gun rack for my SKS, some more lights, and looking for a tire shop that sipes.
might find some cheapo lights to use for back up lights too...
WJlover is offline
post #15888 of 44511 Old 12-25-2012, 10:28 PM
itsparadoxical
Changed out PCV as a quick getaway from the holiday chaos and also removed the center console to prepare for the shifter swap to complete my 247-242 transition.
itsparadoxical is offline
post #15889 of 44511 Old 12-26-2012, 12:54 AM
BigWheel7
Originally Posted by thestig_wj View Post
i did the dodge neon fuel injector upgrade, and on my 12ishmi test drive my mpg went from 11.9 to 14.1 about 50mph with a few stop lights NOTE those numbers are from overhead display so not accurate but still an increase and ill take it,
i painted the hood
and started cutting
Whats this dodge neon fuel injector mod you speak of?
BigWheel7 is offline
post #15890 of 44511 Old 12-26-2012, 06:01 AM
wvracer821
wvracer821's Avatar
http://www.jeepforum.com/forum/f13/d...56/index9.html
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #15891 of 44511 Old 12-26-2012, 09:08 AM
ARdirty
Yesterday installed some back up lights on my custom roofrack. Today I get to put on my 4.5 rustys springs! Up from saggy 3" (originally rough country 4")
1999 WJ 5" lift 33"s-SOLD
1995 YJ 5" lift 33"s- Sold
2001 WJ Quadra Drive BB-CURRENT
ARdirty is offline
post #15892 of 44511 Old 12-26-2012, 09:28 AM
K10roc
finished modding my headlights... HID is in and all leds are replaced with Hyperwhite
HID on
hyper white halo's and leds
took some time to pull off but was well worth it
Joe K.
"if you can buy it, you can build it BETTER"!
2000 Jeep grand WJ limited, 245/75/16, Thrust 2 chamber muffler, 2in bb, rough country shocks, slotted and drilled rotors, Torqflo trans cooler, powder coated calipers, custom made CAI, K&N cone filter, ported and polished throttle body, Chip, Torqflo trans cooler, 6000k HID, PIAA fog, lots of powder coating and blacked out parts
K10roc is offline
post #15893 of 44511 Old 12-26-2012, 11:06 AM
JerzeyBoyWJ
2003 WJ
HID on
What Size LEDs did you use on the halos
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #15894 of 44511 Old 12-26-2012, 11:08 AM
K10roc
5mm 2 per halo and 1 resister
Joe K.
K10roc is offline
post #15895 of 44511 Old 12-26-2012, 11:16 AM
2001WJv8
2015 WK
put 9005's in my fog lights .... $18 for both and now my fogs are actually useful for the first time in 12 years
'15 WK2 Diesel 4x4 ORII, Nitto TG2 275/65r18, BORA 1"f/1.25"r spacers, RRO super sliders
2001WJv8 is offline
post #15896 of 44511 Old 12-26-2012, 11:25 AM
JerzeyBoyWJ
2003 WJ
Are they brighter than the LEDs that used to be in there??
post #15897 of 44511 Old 12-26-2012, 11:42 AM
K10roc
i used hyper white, they are way way brighter than stock, and i hated the stock blue in there. was horrible
Joe K.
K10roc is offline
post #15898 of 44511 Old 12-26-2012, 12:54 PM
STORM_JK
Organised all my tools and gear in the back and replaced a burnt headlight with silverstars, lets see how long they last
'13 JK 6-spd | 3.5" RK | 35" MTR/K | Lots Of Welding
STORM_JK is offline
post #15899 of 44511 Old 12-26-2012, 01:13 PM
lvngtheJEEPlife
Just pick those up at a local auto parts store? Work that well eh? My stock bulbs dont do s@#%
lvngtheJEEPlife is offline
post #15900 of 44511 Old 12-26-2012, 01:36 PM
2001WJv8
2015 WK
walmart - basic sylvania's for < $9 each
I bet in 12 years of owning my jeep i've used the stock fog lights less than 6 total hours because they were totally useless imo ... so I'd use them sometimes at dawn/dusk just as marker lights
I read some other posts on upgrading to the 9005's and so i finally did it and it really is night/day ... totally worth it, and they fit stock without any modifications. Throws the light out front but also wide, which out here in the desert is nice to be able to see an additional 30-40* either side into the ditches. When you put the bulbs in, re-aim the fog lights so they are just under your low beams - the other thread suggested the need to do this because the focal point for the brighter lights is in a slightly different place so they'll be too low if you don't readjust them (easy with a torx bit)
2001WJv8 is offline
wj
bjh0616 , Redjeepwj
