What did you do to your WJ today? - Page 1039 - JeepForum.com
 916Likes
post #15571 of 45335 Old 12-12-2012, 12:10 PM
buns_1
Found out I got hit when I was parked on the street this last weekend, so I drove to Wichita last night and picked up a bumper from a forum member.
04 WJ Overland, 3" IRO Lift, Yakima Rack, 255/75/17 BFG KM's, ARB bumper and custom rear bumper.
buns_1 is offline
post #15572 of 45335 Old 12-12-2012, 12:23 PM
JerzeyBoyWJ
2003 WJ
Did you paint you jeep too? Haha
Sent from my iPhone5 using JeepForum
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #15573 of 45335 Old 12-12-2012, 12:24 PM
Thomahawk
Just got my bid axcepted from seller on a Skiguard 850 skibox, Guy asked for 4000kr, got it for 2700kr, new around here they cost 7-9000kr.
The box is wide (88cm), slim height (31cm), and sitting tight/close to roof, cause cross bars goes thrue the box not under with box sitting ontop.
Its perfect for 4 snowboards, and/or some cargo.
Think i got a great steal, its dark Green metalic, maybe not a perfect color match, but Will look ok anyway
Buildthread
Thomahawk is offline
post #15574 of 45335 Old 12-12-2012, 01:23 PM
SKI_VT
Drive it to McDonalds and it stalled.
I only changed the spark plugs yesterday !
Do you guys really tighten the coil rail to 250ft/lbs?? ?
"You people make it sound like Claytons are made from gold and unicorn bones while everyone else uses PVC and spaghetti noodles."
"The Great Turtle Race! -> Iceland vs. Bushwhacker! -> Place your bets!"
SKI_VT is offline
post #15575 of 45335 Old 12-12-2012, 02:59 PM
bigredhawkeye
Walked past it on the way to class. (hardly drive it since I'm in college).
Can't wait for winter break to start in a couple days. Then all we need is some good snowfall and I'll be driving it everyday.
bigredhawkeye is offline
post #15576 of 45335 Old 12-12-2012, 05:37 PM
WiLieR
New thermostat for mine today. I was surprised how easy it was to swap on the 4.0. Less than a hour to swap it, let it heat up, top off the coolant and check for leaks.
Tossed onto the interwebs via iPhone
99 WJ Laredo - Mine once again!
WiLieR is offline
post #15577 of 45335 Old 12-12-2012, 05:45 PM
BLACK04WJ
Ordered IRO premium sliders and some quick air deflators
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
http://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #15578 of 45335 Old 12-12-2012, 05:52 PM
whooboy
2003 WJ
Originally Posted by PAJeep6 View Post
Wet sanded, buffed, and cleared the set of Laredo headlights I picked up. Lightly tinted the lower amber turn signals, but wet sanded moat of that off. Picked them up for $15 cause I new I could bring them back to life and make them look good. Can't wait to get back from FL Friday night and put them on. Let me know what you think.
Before (heavily oxidized and previous owner tried wet sanding 1)
After (lighting isn't the greatest)...
What kind of wet sandpaper did you use? Did you use a courser one to start and go to a finer and finer paper? Or what? I have a set I'd dearly love to bring back to life.
Thanks
whooboy is offline
post #15579 of 45335 Old 12-12-2012, 06:18 PM
heffercow
1992 XJ Cherokee
got my speedodrd in the mail, just in time for the temp to drop 30 degrees
92 xj, 8 inches w/ long arms, 36's locked rear, rattle can spray job, and countless other budget mods
99 wj limited, 4.7l, 2.5in. rustys springs, pro-comp es9000 shocks, black moabs, 255/70/17 hankook dynapro ATM RF10, still a work in progress
99wj laredo, 4.0l, previous work in progress, now just gathering dust in garage.
heffercow is offline
post #15580 of 45335 Old 12-12-2012, 06:41 PM
Bretthn
Got these in the mail.
2001 Patriot Blue WJ Build Thread
http://www.jeepforum.com/forum/f197/bretthn-wj-mild-build-1373741/
Bretthn is offline
post #15581 of 45335 Old 12-12-2012, 06:42 PM
Bluefish94
Added the Christmas tree mod., temporary but satisfying none the less.
Sent from my ECM
Bluefish94 is offline
post #15582 of 45335 Old 12-12-2012, 08:06 PM
LilLuKe
Found these on Craigslist for anyone who needs some.
http://greensboro.craigslist.org/pts/3458709656.html
LilLuKe is offline
post #15583 of 45335 Old 12-12-2012, 09:42 PM
PAJeep6
Thanks
Started with 800 grit wet sand paper. Did that til it felt smooth, then switched to 1000 grit wet sand paper. Smoothed it out nicely. I dried them, cleaned them with Stoners Invisible Glass, then sprayed 3 coats of clear. Haven't been home since, but will be Friday night. I'll probably just need to buff them out and install Saturday.
My HIDs should be there by the time I get home too, so I'll be havin fun Saturday installing new headlights and my HIDs. Can't wait!
02 WJ - 4.7 | Black Rocks | 33" Treadwright Guard Dogs | 3" exhaust | 6.5" LA lift...
PAJeep6 is offline
post #15584 of 45335 Old 12-12-2012, 09:44 PM
PAJeep6
Originally Posted by CruizinKev View Post
painted my limited headlights black
How did you paint them black? After I install my freshly restored Laredo headlights, I'll have my Limited headlights to play with. I'd be interested in doing the same to mine as you did.
PAJeep6 is offline
post #15585 of 45335 Old 12-13-2012, 04:23 AM
CruizinKev
Wj
I heatened the headlight in the oven (220F) for about 5min and opened them:
then started with 800 grit wet sand paper. sprayed two coats of high temp flat black and let it dry a day. then put it all back together and put the headlight back in the oven again for about 5mins. that way the glue will hold/stick the parts together. just make sure the glass is back in its position on the back-half. if needed just put some more silicon or something to seal the headlights.
will post some installed pics soon!
- Kevin -
2000 Jeep Grand Cherokee 4.7 Dailydriver
1979 Chevrolet Monte Carlo LS3 6.2 T56 Full Resto Project
CruizinKev is offline
wj
