What did you do to your WJ today? - Page 1017 - JeepForum.com
 876Likes
post #15241 of 45197 Old 11-29-2012, 12:01 PM
tuglife
Helped my dad put up a new chimney. The lift is about 3500lb and the HO towed like a champ. Here's a birds eye view of the WJ you don't see that often. Also the cutting wheel finger mod, don't recommend it.
image-804307143.jpg   image-134658496.jpg   image-2865753069.jpg   image-3832660195.jpg   image-2312552820.jpg
,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,2004 WJ Overland ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
4.7 HO V8, K&N FIPK, Old Man Emu HD Springs, Bilstien 5100, 31" 255/70/17 Bridgestone Dueler A/T Revo 2, Black JK Moabs, Overland Rock Sliders, Tow Hooks, Westin Brush Guard, GTP Hood Vents, Mopar iPod Integration Kit
tuglife is offline
post #15242 of 45197 Old 11-29-2012, 01:43 PM
99Limited
Originally Posted by compcrasher86
Were you able to snag a yoke from a WJ? The tcase yokes for WJ and ZJ are not interchangeable unfortunately
Unfortunately not. I was just going to get I from IRO. What year WJ yoke will will work?
99Limited is offline
post #15243 of 45197 Old 11-29-2012, 05:16 PM
buns_1
Found a great use for the tissue holder!
04 WJ Overland, 3" IRO Lift, Yakima Rack, 255/75/17 BFG KM's, ARB bumper and custom rear bumper.
buns_1 is offline
post #15244 of 45197 Old 11-29-2012, 05:45 PM
LilLuKe
I never even noticed it had a tissue holder lol
LilLuKe is offline
post #15245 of 45197 Old 11-29-2012, 06:35 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
There's a little pen holder up there too.
In the garage: M1 4bbl
McCloudsZJ is offline
post #15246 of 45197 Old 11-29-2012, 06:52 PM
MrKeebler26
1994 ZJ
So after all of the screwing around trying to solve the front driveshaft vibration issues I have solved the problem. Last night I took the front driveshaft off. the ride into work was smooth. This triggered the concern that I had smoked the pinion bearing so I took off the diff cover. No metal shavings so that is not the problem. The pinion angle is good and I was confident about that. Turned out to be the front u-joint had barely begun to get grooves worn into the inner surface. Replaced the $25 joint and am good to go. Feeling lucky tonight!
Ben- aka Mr Keebler
MrKeebler26 is offline
post #15247 of 45197 Old 11-29-2012, 06:53 PM
MrKeebler26
1994 ZJ
Nice! Is that a 380
Ben- aka Mr Keebler
post #15248 of 45197 Old 11-29-2012, 06:56 PM
MrKeebler26
1994 ZJ
Depends on what t-case you have. I just picked up a 242 to replace my 247. The 242 is a HD and has the 32 spline output shaft. The 247 is the 27 spline. IRO has both styles available.
Ben- aka Mr Keebler
post #15249 of 45197 Old 11-29-2012, 07:18 PM
teckman02
i got the light bar installed today
it fits good but i need to come up with something to do about the ends it sticks up a little on the ends
i will do a write up later
i also want to thank Dave gcjeeping for his help and use of his warm shop
teckman02 is offline
post #15250 of 45197 Old 11-29-2012, 09:43 PM
Harriedtwo
2011 JK Wrangler
You might try heating the left side, then bend it till it fits. I do this often when installing PVC pipe and it won't make the bend I need. I heat it with a torch or heat gun till it starts to droop, then I put it in place, form it with my gloved hands and I'm good to go! Try it on some excess material so you will get an idea of how much heat to apply; oh, make sure you don't hold the heat device in one place or you'll melt the plastic.
Harriedtwo is offline
post #15251 of 45197 Old 11-29-2012, 10:12 PM
shineybritelite
Sweet deal bun_1. I am so going to try this with my pf9 tomorrow.
shineybritelite is offline
post #15252 of 45197 Old 11-29-2012, 10:38 PM
03azwj
2003 WJ
Actually took it wheeling today for the first time since the lift was installed. I don't have any pics but it did way better than I thought it would. Definitely underestimated the Jeep.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #15253 of 45197 Old 11-29-2012, 10:58 PM
ZB_WJ
Map pocket converted into gun holster. Doesn't get any better than that.
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #15254 of 45197 Old 11-29-2012, 10:59 PM
ZB_WJ
Tire gauge unless you have a monster pen
ZB_WJ is offline
post #15255 of 45197 Old 11-29-2012, 11:50 PM
LilLuKe
What other "secrets" don't I know about lol
LilLuKe is offline
wj
