WET SAND YOUR HEADLIGHTS!! Before and After pics! - JeepForum.com
post #1 of 30 Old 08-26-2014, 08:32 PM Thread Starter
Migillicuty
So I was about to buy a pair of new headlights on ebay because my old ones had such thick yellow grime on them it was like there was no hope for them. I gave the wet sanding thing a try starting with 600 then 800, 1000, 1500 then buffed it with that blue magic headlight polish from autozone and WOW! Cost was around $15 total and took about an hour to do both lights.
Migillicuty is offline
post #2 of 30 Old 08-26-2014, 08:47 PM
braddf
There are plenty threads like this with guys showing their results like yourself but yours truly are amazing
Build thread: http://bit.ly/1puFzZm
Stock rims for sale: http://bit.ly/1kMw7k5
braddf is offline
post #3 of 30 Old 08-26-2014, 10:21 PM
03azwj
2003 WJ
You sure you didn't just buy new headlights. Haha great job
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #4 of 30 Old 08-27-2014, 12:41 AM
Hack
2003 WJ
I had to take mine down to 600 to clean them up too. Put some UV protectant on there since you took it down past the original coating. http://www.amazon.com/Blue-Magic-730...+uv+protectant
Hack is offline
post #5 of 30 Old 08-27-2014, 12:50 AM
HighOutput
2003 WJ
I used RainX, was very easy. Comes with 3 x sand pads with lubricant. Then polish and seal, all in one box but wasn't cheap.
Before RainX, I did try the 'toothpaste' method with stuff all results.
HighOutput is offline
post #6 of 30 Old 08-27-2014, 07:28 AM
ChrisHager
Administrator
ChrisHager's Avatar
Well done! When I have a little fog on my headlights, I grab my polisher and a little rubbing compound and have at 'em. That usually cleans them up nicely and takes about 15 minutes. Just something to keep in mind.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #7 of 30 Old 08-27-2014, 08:14 AM
jfaulk
Great job. I did the same thing to mine last summer with similar results. I used some Plastix(sp?) from Meguiars to help protect them a little. Now I usually hit them about every 6 months with the 1000,3000, and polishing compound to keep em looking good.
jfaulk is offline
post #8 of 30 Old 08-27-2014, 08:18 AM
Knoxes
Knoxes's Avatar
2011 WK
I don't get it. I've wet sanded, compounded, buffed, 3M'd, etc for hours and all I've ever done is make it worse.
Insanely frustrating.
Knoxes is offline
post #9 of 30 Old 08-27-2014, 08:38 AM
HighOutput
2003 WJ
Note the instructions I used, maybe you do the same?
post #10 of 30 Old 08-27-2014, 08:54 AM
steve_80
Keep us updated as to when it starts to fog back over please
steve_80 is offline
post #11 of 30 Old 08-27-2014, 09:22 AM
jfaulk
Don't mean to insult your intelligence but I've seen some lights that get pretty funky on the inside as well. Maybe your issue is with the inside?
jfaulk is offline
post #12 of 30 Old 08-27-2014, 10:05 AM
dcorn
Can't wait to do this, just need to find the time. I have this sylvania kit which apparently has good results. Comes with the UV sealant too.
http://www.amazon.com/Sylvania-38771...GCHCFB0FNAHRP8
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #13 of 30 Old 08-27-2014, 11:39 AM
Knoxes
Knoxes's Avatar
2011 WK
Not insulted at all.
Kinda feel like this is some big joke that everyone is in on, except for me.
Well, me and the store manager at the local Advance, who says he has the same problem and told me not to bother buying any more product.
Knoxes is offline
post #14 of 30 Old 08-27-2014, 11:46 AM
ace4usmc
The Sylvania
ace4usmc is offline
post #15 of 30 Old 08-27-2014, 11:59 AM
ace4usmc
As I was trying to say before I fat fingered the send button...The Sylvania kit is what I used about two years ago and it still looks pretty good. It's not crystal clear like they were when they first done but I has held up a lot better than I had expected. Definitely take your time and follow the directions for the best results. Also, I would highly recommend removing the head light assemblies. If they turn out to be stuck in three ball connectors PB Blaster is once again going to be your friend.
ace4usmc is offline
