welding near gas tank? - JeepForum.com
post #1 of 11 Old 02-07-2013, 10:04 PM Thread Starter
tommyooooooh
My rear upper bump stop broke on the driver side and my plan is to weld pipe in its place to fix it. After I started really looking the gas tank seems pretty close.
Do you guys think it is safe to weld that close to the gas tank?
Wet towel enough?
suggestions?
tommyooooooh is offline
post #2 of 11 Old 02-07-2013, 10:52 PM
Schlotzky
2007 XK Commander
You'll definitely need a heat shield. If you have a piece of thin sheet metal, that would be ideal. I welded sub-frame connectors on my Camaro not realizing the fuel lines ran inches from where I was welding. The flames weren't bright enough to be seen through the welding helmet so I had no idea why my buddy started yelling and then rushed out of the garage. I went back to welding until I heard him come back in and start soaking me and the area around me with the fire extinguisher!
Schlotzky is offline
post #3 of 11 Old 02-08-2013, 09:12 AM
bradywgn71
bradywgn71's Avatar
I agree with Schlotzky although I'd call it a spark shield instead of a heat shield. Heat won't be an issue that far away from the tank. You just don't want a spark to find that leaky o-ring on top of the tank letting the fumes out. If you don't have a piece of sheet metal to use as a shield, you can use a wet towel or canvas tarp and make a curtain between the weld and the tank. I worked in a welding shop where we made custom trailer hitches for motor homes and I've welded within an inch of gas tanks (barely enough room to get the stinger in there). The first time makes ya really nervous. After that, you get used to it. Just take proper precautions. If you smell any gas fumes, don't spark up.
Oh, and, have a fire extinguisher or at the very least a garden hose near-by.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #4 of 11 Old 02-08-2013, 09:20 AM
ChrisHager
Administrator
ChrisHager's Avatar
A garden hose is better than nothing but have you ever poured water on a bucket of burning gasoline? Let me tell ya, water doesn't put it out - it only splashes the gasoline causing the fire to rain everywhere. Hmmm... I wonder if that's what "Set Fire to the Rain" means...*
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #5 of 11 Old 02-08-2013, 10:37 AM
Apollo21
I welded on my bumper and only used one of those fire blankets as a shield to keep sparks from reaching the tank.
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #6 of 11 Old 02-08-2013, 10:44 AM Thread Starter
tommyooooooh
Good to know. I didn't even think of not being able to see flames because of the welding helmet. That would be a bad situation to start a fire especially if you would have been alone. I think ill put a wet towel over the gas tank and then try to put some scrap pieces of steel plate in front of it as a shield. But ChrisHager makes me want to poor water on a burning bucket of gasoline now just out of curiosity.
post #7 of 11 Old 02-08-2013, 10:50 AM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by tommyooooooh View Post
[snip]
*Disclaimer: Do not try this at home.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #8 of 11 Old 02-08-2013, 10:52 AM
ChrisHager
Administrator
ChrisHager's Avatar
Oh, and.....
Mine!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #9 of 11 Old 02-08-2013, 10:52 AM
bradywgn71
bradywgn71's Avatar
*Disclaimer: Do not try this anywhere.
FIFY
Years ago, I did have a co-worker who flicked his cigarette quickly into a 5 gallon bucket of paint thinner to prove a point to our supervisor. The supervisor was complaining about my co-worker smoking near him while he was using the paint thinner. The cigarette was put out just like dropping it in water. It's not the liquid that burns, its the vapors. I think my supervisor needed to go clean out his shorts after that though.
post #10 of 11 Old 02-08-2013, 10:53 AM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by bradywgn71 View Post
FIFY
Good call!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #11 of 11 Old 02-08-2013, 10:53 AM Thread Starter
tommyooooooh
Haha It sounds like a fun experiment but unfortunately I can't even afford a full tank of gas in the jeep and if I had some to burn I don't think id literally burn it.
