welded nut? - JeepForum.com
post #1 of 8 Old 10-11-2013, 08:57 AM Thread Starter
ZJPunk98
welded nut?
does anyone know if the nut on the steering stabilizer bracket for the axel mount is welded on?
I can not get it to move and stripped it. Then i proceeded to cut to off with a cutting wheel. With only a few thread left, I decided to attempt backing out the bolt, and it cam out effortlessly.
looking at the nut carefully, i looks as though it may be welded in place.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #2 of 8 Old 10-11-2013, 09:01 AM
ChrisHager
Administrator
ChrisHager's Avatar
It is permanent. You can see it in these two pictures:
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 8 Old 10-11-2013, 10:14 AM Thread Starter
ZJPunk98
well i f'd that thing up
Erik
ZJPunk98 is offline
post #4 of 8 Old 10-11-2013, 10:19 AM
ChrisHager
Administrator
ChrisHager's Avatar
Cut off the welded nut and run a bolt/nut through the bracket. Either that or mount yours like I did mine.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 8 Old 10-11-2013, 10:25 AM Thread Starter
ZJPunk98
you do not get any binding mounting it to the tb? i will cut the remainder off and through bolt it most likely.
Erik
ZJPunk98 is offline
post #6 of 8 Old 10-11-2013, 10:29 AM
ChrisHager
Administrator
ChrisHager's Avatar
Nope - mine works great mounted there. In fact, there is basically one spot where the brackets fit when mounted in this way. That location puts the shock right at middle travel.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #7 of 8 Old 10-11-2013, 05:54 PM
gtg413i
2003 WJ
What parts did you use to mount it to the tb like that?
Brian's Black Betty Build:
gtg413i is offline
post #8 of 8 Old 10-12-2013, 04:34 AM
ChrisHager
Administrator
ChrisHager's Avatar
I just used a left over clamp from my old tie rod...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
