Weird One - 'Burning' Smell - Page 2 - JeepForum.com
post #16 of 32 Old 02-19-2014, 05:22 AM
bessyboy
Was anyone else with similar problems running a cold air intake?
-2001 WJ Limited, 4.7L V8, Thrush Glasspack muffler dumped before axle(no tailpipe), Spectra CAI,
Rusty's 2" BB
bessyboy is offline
post #17 of 32 Old 02-19-2014, 07:19 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I have a stock intake with a wix air filter...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #18 of 32 Old 02-19-2014, 04:51 PM
bessyboy
Oh, I thought maybe it was from getting so much salty air in from the open cone
Rusty's 2" BB
bessyboy is offline
post #19 of 32 Old 03-05-2014, 09:34 AM
Laura_04WJ
I have 4.0 and gotten the same thing. Smelled like burning plastic/coolant to me. When my dad was checking it out, we discovered I have a weeping freeze plug at the front of the motor. Hoping that is the problem.
Laura_04WJ is offline
post #20 of 32 Old 03-05-2014, 09:49 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Interesting. I'll take a peak at that! That could explain why it *appears* I'm slowly losing coolant (though I haven't check the current level vs the mark I made a couple weeks ago).
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #21 of 32 Old 03-05-2014, 10:36 AM
Laura_04WJ
Mines been slowly disappearing too, so we weren't exactly sure where it was going. I believe its the first freeze plug on mine, it was difficult to see/get a flashlight in between the manifold tubes and block.
post #22 of 32 Old 03-05-2014, 10:47 AM
MadderThanMax
Got the "Blow up Mistress" working overtime have you Chris??
MadderThanMax is offline
post #23 of 32 Old 03-05-2014, 11:12 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Hahaha! Yup! Between the wife, baby, J-10, TJ, WJ, two jobs, and family vehicle maintenance, I barely even have time for the mistress!
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #24 of 32 Old 03-05-2014, 12:31 PM
MadderThanMax
Wj
post #25 of 32 Old 03-05-2014, 12:54 PM
Johnyre
Originally Posted by snoWJ View Post
Forgot one other thing...I hit the A/C button the other day by accident while the heat was on (and it was like -3 F), which let to a pretty gross coolant smell until I realized what I had done and turned it off.
Sometimes the ac turns it self on when you turn on the heat(sneaky little ish)
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #26 of 32 Old 03-05-2014, 01:34 PM
nhcd538
Just a thought, I had a Tahoe that had a bad rear axle seal and it caused gear oil from the axle to leak onto the brake rotor. When I drove it it caused the gear oil to burn and burning gear oil smells more like garbage than any automotive fluid I can think of.
If it comes back maybe check your rear axle seals or for gear oil leaks anywhere, really.
1999 TJ 2.5L AX5 NP231 D35/30 4.11's
*Disclaimer - I've probably had a few beers
nhcd538 is offline
post #27 of 32 Old 03-10-2014, 08:17 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Saturday, I noticed my radiator fan relay(s) are shot. In 04, they're located in the fuse box under the hood. I wonder if the smell was the relay(s) toasting themselves...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #28 of 32 Old 03-11-2014, 06:22 AM
Double E
Double E's Avatar
Add me to the coolant leak camp.
I'm thinking there's a leak that's only apparent when the system is pressurized. Small for now but could get big in a hurry. Can you do a radiator pressure test?
Sometimes a parts store will loan the equipment and it's no more complicated than clamping on a hand pump with a dial gauge to the radiator fill neck to see if it can hold air pressure for a given period of time.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #29 of 32 Old 03-11-2014, 07:28 AM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Next time I stop by O'Reillys, I'll see what they have on hand. If they have the proper tool, they'll probably let me borrow it for a bit. They know me too well...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #30 of 32 Old 03-25-2014, 02:21 PM
Laura_04WJ
Got my freeze plugs fixed last week and haven't smelled it since. (It got pretty bad near the tail end, was smelling the burning coolant for 10-15 minutes straight sometimes.)
