Weird issue I cant figure out - JeepForum.com
post #1 of 5 Old 11-08-2013, 03:04 PM Thread Starter
strawberryjam
Its a 2000 jeep Grand Cherokee limited everything turns on and works as far as the radio, lights, ect.. the starter works had it tested 3 times at auto zone but the engine wont turn over or click no noise at all. Alternator is new. Has to be something electrical right?
strawberryjam is offline
post #2 of 5 Old 11-08-2013, 03:14 PM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
The correct forum would help (not in the WK2 section). Moved.
2011 Billet JKUS
Jackal01 is offline
post #3 of 5 Old 11-08-2013, 04:59 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Check fuses #6 and #8 in the PDC under the hood and fuse #31 in the junction block drivers side under dash. If they are good swap the engine starter relay with another relay in the PDC under the hood.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #4 of 5 Old 11-08-2013, 06:39 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Rule number one with WJs, CLEAN YOUR BATTERY TERMINALS. Then clean them two more times and make sure they are tight.
~James
ezflip is offline
post #5 of 5 Old 11-09-2013, 04:12 PM
Highschool_WJ
And then once you get it running go have new ends put on the cables and pick up a new battery, should solve your problems for good!
,,,soooo I graduated in 2013...
Highschool_WJ is offline
