-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Weird issue I cant figure out (http://www.jeepforum.com/forum/f310/weird-issue-i-cant-figure-out-1771833/)
strawberryjam 11-08-2013 03:04 PM
Its a 2000 jeep Grand Cherokee limited everything turns on and works as far as the radio, lights, ect.. the starter works had it tested 3 times at auto zone but the engine wont turn over or click no noise at all. Alternator is new. Has to be something electrical right?
Jackal01 11-08-2013 03:14 PM
The correct forum would help (not in the WK2 section). Moved.
michiganmaveric 11-08-2013 04:59 PM
Check fuses #6 and #8 in the PDC under the hood and fuse #31 in the junction block drivers side under dash. If they are good swap the engine starter relay with another relay in the PDC under the hood.
ezflip 11-08-2013 06:39 PM
Rule number one with WJs, CLEAN YOUR BATTERY TERMINALS. Then clean them two more times and make sure they are tight.
Highschool_WJ 11-09-2013 04:12 PM
And then once you get it running go have new ends put on the cables and pick up a new battery, should solve your problems for good!
The time now is 01:54 PM.
