Weird engine problem (Kind feels like misfire) - JeepForum.com
post #1 of 11 Old 04-09-2012, 04:03 PM Thread Starter
01jeepGCL
Wj Weird engine problem (Kind feels like misfire)
I have been having a problem with my jeep (2001 4.0L automatic) for some time now and only seems to show it's ugly face when the weather is above 80*.
I start the Jeep, everything runs fine. I drive for a time frame of longer than 15 minutes (the jeep gets warmed up) and the temp gauge is right below the middle as it should. Say I stop and grab some food (5-10min stop). I get back in the Jeep and and crank her up. She starts up with no problem but the motor starts shaking and gets worse if I rev the engine a bit. I don't get an check engine lights or anything. I did notice that when this happens my temp gauge goes a little above the middle of the gauge. Then it starts to move back to a normal temp. condition. The shaking stops when the temp needle drops. I have never overheated before but this is the only time it happens. Could this just be a bad sensor? I'm not familiar with the wiring but on my Acura Integra the gauges was controlled by a single wire to a sensor and did not run to the computer at all. Does this gauge read from the ECT sensor? If anyone could help I would appreciate it.
Thanks,
Ryan
01jeepGCL is offline
post #2 of 11 Old 04-12-2012, 09:56 PM
ddtwdmb
2005 WK
Have you run the diagnostic procedure? See if it's getting any error codes, easy to do, read about it at http://www.wjjeeps.com/faultcodes.htm ..if it's a sensor it may show up, even without the check engine light coming on.
ddtwdmb is offline
post #3 of 11 Old 04-12-2012, 10:11 PM
pinky2252s
Same thing happened to me on my V8. I replaced the TPS (Throttle Position Sensor) and it solved it.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #4 of 11 Old 04-12-2012, 10:29 PM
ddtwdmb
2005 WK
Same here
ddtwdmb is offline
post #5 of 11 Old 04-12-2012, 10:44 PM
BWYoung85
Heat Soak causing a misfire on injector 3, TSB Link: http://www.wjjeeps.com/tsb/tsb_wj_1803103.pdf
I had this exact problem with my WJ when it started getting warmer outside. I used Reynolds Heavy Duty aluminum foil, and folder over until it was about 1/16 of an inch thick and wrapped injector 3 and 4 and secured it with zip ties. 3 and 4 are at the center of the motor and are exposed to the most heat once the engine is turned off. I also wrapped my fuel rail around this area as well. I know it sounds farfetched, but it worked for me. Before you go replacing sensors try this out. Let us know how it works for you.
- 2004 Freedom Edition -I6\SelecTrac
There is a learning curve to everything.
BWYoung85 is offline
post #6 of 11 Old 06-29-2012, 09:24 AM Thread Starter
01jeepGCL
I will give this a shot. It only happens on hot days 90* +. And more so when I run my a/c it seems. I will check to see if I have any codes on my lunch break. I was going to try to just turn the power on and see where the temp needles goes. Like I said it only happens when the needle goes passed halfway on the temp gauge. If I let the jeep run a minute the needle moves back to half way and the idle stablizes. Kinda of strange. I will give the foil a try and check the codes.
I will let you guys know how it goes. The heat index is in the 100's already so I should be able to get see the symtoms. I'll try to get a video as well.
post #7 of 11 Old 07-01-2012, 10:27 AM
n61870
If none of those things work, here's another $.02...My Jeep was doing something similar, I thought it was a heat problem but then it started doing it in the cold, I thought it was a throttle position sensor but both myself and a mech checked it and it was good. Anyway, I finally ran across a tech bulletin about the 4.0L exhaust valves sticking, causing the engine to run rough. The solution was to use the Mopar cumbustion chamber cleaner. I used the cleaner and followed the instructions, havent had the problem since. Do a search for that particular service bulletin because the instructions in the bulletin and the instructions on the can are different. I think the cleaner was around $10 at the dealer, I bought 2 just in case but one was enough so I ran the other through my old ford ranger and it actually improved the gas mileage.
n61870 is offline
post #8 of 11 Old 07-01-2012, 11:10 AM
ZB_WJ
What grade gas are you using? Ethanol free?
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #9 of 11 Old 07-02-2012, 10:01 AM Thread Starter
01jeepGCL
Im using 87 octane and I'm sure it's got some amount of Ethanol mixed in with the fuel. I didn't think the jeep needed higher octane fuel. I only run the higher octance (93) on high compression or forced induction.
I will look into the Mopar cleaner. I'm sure it wouldn't hurt. Either that or Sea Foam.
post #10 of 11 Old 07-02-2012, 10:12 AM
coloboardin
I'm glad this was posted, I'm having the exact same issues right now. It was 102* yesterday and had a very rough start. If the CEL isn't on will it still throw a code?
2002 WJ Laredo - 4.0L - Stock
coloboardin is offline
post #11 of 11 Old 07-02-2012, 10:15 AM
ZB_WJ
I've got 04 4.0 auto and mine did same last summer. Almost exactly. Would drive, stop at food place and then start it up. Would run rough and shake. I was so mad, id just bought it. I read about heat soak and it sounded like my problem. When I was using cheap gas is when it happened. I would just stomp on the gas a few times to clear out injectors, would be fine till I hit a stoplight. Then it would run rough again. I changed my gas station and only use ethanol free premium, hasn't done it once this year luckily with 106 temps. I haven't done anything else besides better gas. Just my experience.
ZB_WJ is offline
Engine random misfire after a service and tuneup! TeeJay00 WJ Grand Cherokee Forum 26 05-26-2015 02:58 AM
Check Engine Misfire Codes? brinoff WJ Grand Cherokee Forum 2 09-11-2011 01:25 PM
Rebuilt engine now has misfire at idle... rungesco WJ Grand Cherokee Forum 8 04-03-2011 08:07 AM
Check Engine Light - Cylinder #1 Misfire? MileHighJeep WJ Grand Cherokee Forum 5 09-08-2010 06:21 AM
Engine Misfire 2004 Grand Cherokee SSjmg2477 WJ Grand Cherokee Forum 1 03-03-2004 09:47 AM
