Water Pump Replaced three times in 4 years - JeepForum.com
post #1 of 11 Old 03-16-2010, 05:37 PM Thread Starter
BucYouUp68
I know the 4.0 goes through water pumps, but this is getting out of hand. Looked at the obvious signs, Clutch Fan, Pully, etc...... What else could be the problem. The truck runs fine other than this. I have put on Quality water pumps, so i can see one going out, maybe two, but come on, THREE. Something is amiss here. Any Help would be appreciated.
Why is there a fish finder in your Jeep?
Not hard, if you have a socket wrench and the mental capacity of a ham sandwich.
BucYouUp68 is offline
post #2 of 11 Old 03-16-2010, 06:15 PM
Hutchman
I just changed mine a few weeks ago. This is the 3rd pump. I have a 00 GC.
Hutchman is offline
post #3 of 11 Old 03-16-2010, 06:44 PM
moonshinefuel
They are probably remanufactured pumps. Buy new, not rebuilt, if that is the case.
moonshinefuel is offline
post #4 of 11 Old 03-16-2010, 06:47 PM
bigbill888
What makes you think the pump is bad??
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #5 of 11 Old 03-16-2010, 06:49 PM
ajmorell
ajmorell's Avatar
Is that a WJ thing? I've never heard of them being problematic.
ajmorell is offline
post #6 of 11 Old 03-16-2010, 07:06 PM Thread Starter
BucYouUp68
1st one rebuilt, the other 2 new. So there goes that theory.
post #7 of 11 Old 03-16-2010, 07:11 PM
bigbill888
Check your belt routing. Maybe you are running it backwards.....?? I did that once for a month and couldn't really tell the difference.
All work well
post #8 of 11 Old 03-16-2010, 07:15 PM
moonshinefuel
Hmm. Well, I know they make an additive to add to the coolant to act as a lubricant for the waterpump bearing. Have you used that?
post #9 of 11 Old 03-16-2010, 07:15 PM Thread Starter
BucYouUp68
Thanks but NO, Checked, double checked, today triple checked. All good.
post #10 of 11 Old 03-16-2010, 07:17 PM Thread Starter
BucYouUp68
Are you being serious??????? Is that called Coolant.
post #11 of 11 Old 03-16-2010, 07:27 PM
moonshinefuel
Let me add this, I think there is an abundance of parts hitting the shelves everywhere that are sub-standard as far as quality, for the sake of a competitive price. It is very possible you are buying different water pumps with the same supplier for the bearing inside it. I would be tempted to go to a dealership and see about finding a factory original new waterpump if it really is becoming an issue for you, if that is, you have not tried that already. And, if the dealership does indeed have new factory original water pumps available, not sourced from an other than original supplier. I am using a factory original new one now, and it is holding up excellently.
replaced the fan relay 4 times.. babix0ashh ZJ Grand Cherokee Forum 8 03-03-2011 03:49 PM
cooling system problems , water pump and thermostat replaced . no heat. natesxj ZJ Grand Cherokee Forum 4 10-25-2009 09:49 AM
WJ Wheel Bearing Replaced 2 Times In Less Than A Year. JoeBrad ZJ Grand Cherokee Forum 13 07-12-2009 03:10 PM
Replaced water pump but still leaking flyboy14295 ZJ Grand Cherokee Forum 6 10-15-2008 07:03 PM
I've replaced the fan relay 3 times Knoxes ZJ Grand Cherokee Forum 12 07-22-2008 12:05 PM
