Want a supercharger or some kind of mod for 4.7 - JeepForum.com
post #1 of 16 Old 10-21-2013, 07:02 PM Thread Starter
kyminer
I have an 04 limited with 4.7 non h.o. I want to do a performance upgrade. Need suggestions. Would really like to do a supercharger.
kyminer is offline
post #2 of 16 Old 10-22-2013, 03:18 AM
texlurch
Scour want adds for used S/C as no one makes anything for them
Or get creative with something like this with some DIY and JY parts
Turbos and FI are actually fairly simple, but I would probably do a single, in a rear mount.
Not much room under the hood on a WJ, not to mention they don't need anymore underhood heat.
Properly sized at 5-7 pis you'll see an extra 100 hp easy, and more torque than that.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #3 of 16 Old 10-22-2013, 08:20 AM
VBJeepWJ
2003 WJ
How many miles are on it?
VBJeepWJ is offline
post #4 of 16 Old 10-22-2013, 08:55 AM
cubalz
Sounds like a recipe to rocket a 4.7L to an early demise.
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
post #5 of 16 Old 10-22-2013, 09:19 AM
MattJeep
2003 WJ
I'm sure it could be done, even safely with small amount of boost. But that's a good point, the Wj is too small. Theres no under hood room and probably no room for an intercooler. Plus the extra heat? You would probably need a custom raised hood. Easiest thing to do is go grab a Overland with the H.O.
MattJeep is offline
post #6 of 16 Old 10-22-2013, 09:36 AM
texlurch
Thats why I say rear mount
Google STS or Squires Turbo System.
texlurch is offline
post #7 of 16 Old 10-22-2013, 11:53 AM
FailWheelDrive
The hardest part would be tuning for the boost.
I'm not sure if any software that allows for full control of the stock ECU's fuel/timing maps is available.
Best way would probably be to swap in a stand alone fuel management system with a 2 bar MAP or MAF sensor setup.
FailWheelDrive is offline
post #8 of 16 Old 10-22-2013, 12:42 PM
cykaaro
There are eaton and ken belle superchargers that will work with the 4.7. Getting one might be a whole different issue, but there is information out there. Just search. Other option is turbo it.
I know someone with a gen3 camry. He's now pushing 1000WHP. But then, a lot of custom work and he knows what he's doing. Thing is, it is possible to get more out of it. Just depends on what you're willing to do and spend, and if you have someone who really knows what they're doing to do it.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #9 of 16 Old 10-22-2013, 02:12 PM
texlurch
At low boost you can usually get away with a boost referenced regulator.
No knock sensor on the 4.7 might be an issue, but a simple A/F gauge to monitor the exhaust and tune from there.
texlurch is offline
post #10 of 16 Old 10-22-2013, 04:21 PM
alfaitalia
You could make an intercooler fit (dont know about the rest) as they made an front mounted intercooled WJ model ....the CRD.... and my straight five is longer than the V8 so you should easily be able to sqeeze one in.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #11 of 16 Old 10-22-2013, 06:02 PM
FailWheelDrive
Yeah an adjustable rising rate fuel pressure regulator could be made to work with the use of a wideband for A/F reference.
Still wouldn't have any control over timing though which would kinda suck.
I wish something like EFIlive or HPtuners was available for our WJ's.
BTW: This thread sparked my interest because I was just talking with a buddy the other day about how a rear mounted turbo on a gutted WJ with the 4.7 & QD would make for a demon at the drag strip. Would be such a fun project.
post #12 of 16 Old 10-22-2013, 06:38 PM
99gcl532
Mega squirt, alot of wiring
99gcl532 is offline
post #13 of 16 Old 10-22-2013, 06:54 PM
narnwv
narnwv's Avatar
Start here:
http://www.airram.com/custompage.php?page=18
~Aaron
narnwv is offline
post #14 of 16 Old 10-23-2013, 04:35 AM
MWF
Another option to the AFR would be a ninth injector running off a MAP sensor, then you'd be able to create an additional fuel profile mapped against boost pressure and maybe rpm too.
I used to have a turbo converted v-formation engine with a massive intercooler, it's remarkable what you can cram into the confines of an engine bay.
The ignition side has me stumped though, you need an overboost cutoff at least really.
MWF is offline
post #15 of 16 Old 10-23-2013, 04:41 AM
texlurch
You could run an MSD with boost reference and limiter chip for better spark and over rev safety.
It will retard based on boost and your settings
1 to 1 fuel regulator will raise fuel pressure in relation to boost, and "fool" the engine into thinking it has bigger injectors under boost.
texlurch is offline
