want to add 2" bb to 4.5" lift asking for experiences/issues - Page 2 - JeepForum.com
post #16 of 25 Old 03-30-2010, 10:20 AM
CLNinja
CLNinja's Avatar
yeap, definatley need long arms and new shocks
hey Ryan, did you notice any difference when you ditched your springs and spacers for full springs?
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #17 of 25 Old 03-30-2010, 11:11 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I never did the spring + spacer combo (aside from when I was on a BB).
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #18 of 25 Old 03-30-2010, 12:20 PM
NorCOWJ
im guessing you might have to do some work on your brake lines. mine seem a little tight after the 4" lift. so maybe some brake line extension
2004 WJ Laredo 4.7 K&N/AMSOIL CAI, Flowmaster44, jks goodies, Bilstein's, AMSOIL fluids,
Clayton LA's, 33" TW Guard dogs, Custom Rear Bumper with swing away
Building a rear JK Rubi 44
NorCOWJ is offline
post #19 of 25 Old 03-30-2010, 01:00 PM
ArloGuthroJeep
Mr. Hyde!
Mine are taunt...only because I pushed my axles forward/backward.
post #20 of 25 Old 03-30-2010, 01:32 PM Thread Starter
ronsaun
2003 WJ
Originally Posted by ArloGuthroJeep View Post
Long arms.
So much more durable, so much smoother ride, so much more expensive
long arm eh. can you expound on the "so much smoother ride" and what else is necessary if i go that route? i am still having trouble with what i qualify as bad sway even though i bought a kor hd stabilizer and tightened my steering a little. will long arms help with that? thank you for your interest. ron
aussie rear end, drilled and slotted rotors, ceramic brake pads, ironman adj.front upper/lower and rear lower control arms, teraflex 4" spring lift, fat bobs 2' bb, rusty's drop pitman arm, jks adjustable trackbar, moog tie rod ends/ball joints, rancho 9000 shocks, kor dual stabilizer, rough country front and rear bump stop extensions, homebrew front quick disconnects, rough country rear swaybar link drop kit, IRO a-arm spacer, transfer case drop kit, homebrew rocksliders, rola roof rack, speed bleeders, 2" wheel spacers, 4-treadwright guard dog mt 265/75/16, mud flaps, superchip, k&n cold air intake, straightpiped, chrome tailpipe tip, v-led hid headlights w/halo, v-led hid foglights w/halo, kidde fire extinguisher w/bracket, maglite w/mounting bracket, cobra cb, firestik antenna, white gauges gauge face overlays, viair compressor, blue led interior lighting upgrade, hi lift 48" jack, hi lift jack base, wind deflectors for: hood, moon roof and windows, sony stereo, garmin nuvi gps, recovery D ring, interior mount keyed battery switch, custom dash brackets for gps, cb, sat radio, cellphone, bumper mount halogen reverse lights, cobra radar detector, smittybilt gear seat covers and tailgate organizer, browning rooftop camo cargo bags, grille insert, washer fluid reservoir relocation, foldup cargo carrier, aluminum side steps, addco rear swaybar, deer whistles, mobile one synthetic oil, slick 50 high mileage oil additive, k&n oil filter
TO DO:
reece front hitch, warn winch, elocker or arb front selectable locker, bulldog remote start, hi lift essential parts kit, 2-hella driving lights, gerry can and bracket, stinger bar, wood dash kit, snorkel, washer fluid heater, rear swing tire carrier, finish the skid plates, fender flares, addco front swaybar
ronsaun is offline
post #21 of 25 Old 03-30-2010, 03:54 PM
rustynail
Keeping in mind that I don't know much about wj's..... If you really want more height without spending the dough required for front long arms, shocks, brake lines, wider wheels, etc, you could pull out your isolators and put in 1.75" spacers bringing you up to about 5.5 inches.
That's about where I'm at and it really is a bit too high for short arms. With 285's and 1.25" wheel spacers it feels a bit tippy at times. I'm considering buying wider wheels and trimming my fenders before I put my new tires on. The ride is stiff and I wouldn't even consider going off road without airing down to 17psi.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #22 of 25 Old 03-30-2010, 04:29 PM
CLNinja
CLNinja's Avatar
oh for some reason i thought you did
Matt
CLNinja is offline
post #23 of 25 Old 03-30-2010, 04:42 PM
lateralus3
1994 ZJ
im at 6.5 on shortarms in the front and the ride is horrible
lateralus3 is offline
post #24 of 25 Old 03-30-2010, 05:41 PM
Eshindi
'15 JK Stock | 4k Miles | Bone Stock
SOLD '99 WJ I6 | Claytons LA | 6.5" | HP D44 | F9" | 35's
Eshindi is offline
post #25 of 25 Old 03-30-2010, 07:43 PM Thread Starter
ronsaun
2003 WJ
Originally Posted by Eshindi View Post
based on that table i think ill stay where i am at. thanks to all. ron
TO DO:
ronsaun is offline
1995 Laredo Weird "bucking" issues while driving jrsquared ZJ Grand Cherokee Forum 3 07-12-2011 07:20 AM
got my 3.5" lift into my 5.9... now i have steering and alignment issues. cirame1 ZJ Grand Cherokee Forum 7 06-23-2009 02:39 PM
Rough Country 4" lift Issues For ZJ zjBRYCE ZJ Grand Cherokee Forum 4 02-23-2009 05:52 PM
issues with the lift,.."rubbing" coyote runner WK Grand Cherokee & XK Commander Forum 6 10-24-2007 06:28 PM
3" lift = driveshaft and steering issues? mtnjam ZJ Grand Cherokee Forum 5 09-30-2007 08:35 PM
