want to add 2" bb to 4.5" lift asking for experiences/issues - JeepForum.com
post #1 of 25 Old 03-29-2010, 10:09 PM Thread Starter
ronsaun
2003 WJ
i am tossing around a 2'' bb on top of my 4.5" lift so i will have 6.5". i am asking for experiences and any issues. i sure wish i wouldnt have sold my bb! thanks, ron
aussie rear end, drilled and slotted rotors, ceramic brake pads, ironman adj.front upper/lower and rear lower control arms, teraflex 4" spring lift, fat bobs 2' bb, rusty's drop pitman arm, jks adjustable trackbar, moog tie rod ends/ball joints, rancho 9000 shocks, kor dual stabilizer, rough country front and rear bump stop extensions, homebrew front quick disconnects, rough country rear swaybar link drop kit, IRO a-arm spacer, transfer case drop kit, homebrew rocksliders, rola roof rack, speed bleeders, 2" wheel spacers, 4-treadwright guard dog mt 265/75/16, mud flaps, superchip, k&n cold air intake, straightpiped, chrome tailpipe tip, v-led hid headlights w/halo, v-led hid foglights w/halo, kidde fire extinguisher w/bracket, maglite w/mounting bracket, cobra cb, firestik antenna, white gauges gauge face overlays, viair compressor, blue led interior lighting upgrade, hi lift 48" jack, hi lift jack base, wind deflectors for: hood, moon roof and windows, sony stereo, garmin nuvi gps, recovery D ring, interior mount keyed battery switch, custom dash brackets for gps, cb, sat radio, cellphone, bumper mount halogen reverse lights, cobra radar detector, smittybilt gear seat covers and tailgate organizer, browning rooftop camo cargo bags, grille insert, washer fluid reservoir relocation, foldup cargo carrier, aluminum side steps, addco rear swaybar, deer whistles, mobile one synthetic oil, slick 50 high mileage oil additive, k&n oil filter
TO DO:
reece front hitch, warn winch, elocker or arb front selectable locker, bulldog remote start, hi lift essential parts kit, 2-hella driving lights, gerry can and bracket, stinger bar, wood dash kit, snorkel, washer fluid heater, rear swing tire carrier, finish the skid plates, fender flares, addco front swaybar
ronsaun is offline
post #2 of 25 Old 03-29-2010, 10:19 PM
flyboy14295
You're gonna need a new front DS, if you don't have one already.
WJ. 4.Slow I6. The Underdog
2" Teraflex BB, 265/70R16 BFGoodrich TA KO's, JKS Adjustable Track Bar, JKS HD Tie Rod, Rusty's Tow Hooks, Block Heater, CB
New York City EMS
Originally Posted by LoneJeeper View Post
I came into this world via broken rubber, i'm not going out the same way.
flyboy14295 is offline
post #3 of 25 Old 03-29-2010, 10:45 PM Thread Starter
ronsaun
2003 WJ
ok. i dont have one. can you explain why? what about rear control arms?
TO DO:
ronsaun is offline
post #4 of 25 Old 03-29-2010, 10:50 PM
lateralus3
1994 ZJ
do you have the ujoint style or the cv?
lateralus3 is offline
post #5 of 25 Old 03-29-2010, 10:57 PM
the88thpianoman
2003 WJ
You can probably get away with adjustable control arms in the rear, so you can remove your front lowers and put them in the rear. You're going to need long arms up front.
Your front drive shaft will need to be a single/double cardon u joint shaft if it is not already. Anything less than that will not work. If you currently have a cv joint drive shaft, it's probably already bad from your current lift.
You'll need 6.5" sway bar links. I've never heard of the sway bar link drop kit you have in your sig, but if it's anything like the track bar drop kits, it's not beefy enough for this kind of lift, anyways it'll be 2" too short. You'll also of course need 6.5" lift shocks and anything else that's required for a 6.5" kit. Not sure what all you're running right now.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #6 of 25 Old 03-29-2010, 11:02 PM
lateralus3
1994 ZJ
should have went with long arms ron
post #7 of 25 Old 03-29-2010, 11:05 PM
CLNinja
CLNinja's Avatar
i use a 2" BB on top of my 4.5" springs
not sure if i would get better performance/flex and whatnot with just 6.5" springs instead of using the 2" spacers though, tossin around the idea of gettin rid of the spacers and just goin all spring
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #8 of 25 Old 03-29-2010, 11:08 PM
the88thpianoman
2003 WJ
Seems like you probably would since the pucks take up a set amount of space, and if it was 2" extra of spring, it would have that much more flex and compression available. How much of a practical difference that actually makes I've no idea.
post #9 of 25 Old 03-30-2010, 07:38 AM Thread Starter
ronsaun
2003 WJ
it is ujoint. i thought i read w/ujoints i wouldnt have to change. is there any truth to that? ron
TO DO:
ronsaun is offline
post #10 of 25 Old 03-30-2010, 07:40 AM Thread Starter
ronsaun
2003 WJ
did you have to do anything additional. such as front drive shaft, trans drop kit, rear control arms, etc....? what about the shocks? ron
TO DO:
ronsaun is offline
post #11 of 25 Old 03-30-2010, 07:43 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Longer shocks are needed.
You'll be going through bushings a lot more frequently. You'll get lots of new noises (just a much harsher ride).
You won't know whether you need a new driveshaft until you lift it really. You need to look at spline engagement front and rear to ensure you have enough.
I had to install a SYE to rid myself of vibes in the rear.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #12 of 25 Old 03-30-2010, 07:44 AM
SplitNail
Yup you should be fine if you have ujoints in the front.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #13 of 25 Old 03-30-2010, 07:56 AM Thread Starter
ronsaun
2003 WJ
well, thats all kinda scary. it is a dd. i also make long trips back and forth to montana 3600 mile round trip! that might be tough. ultimately i am trying to keep it very drivable as well as tough for the trail. i am trying to find the right combination of mods to accomplish a close to stock ride and high trail useability. suggestions are accepted. thanks, ron
TO DO:
ronsaun is offline
post #14 of 25 Old 03-30-2010, 07:58 AM
the88thpianoman
2003 WJ
Long arms.
post #15 of 25 Old 03-30-2010, 08:16 AM
ArloGuthroJeep
Mr. Hyde!
Long arms.
So much more durable, so much smoother ride, so much more expensive
1995 Laredo Weird "bucking" issues while driving jrsquared ZJ Grand Cherokee Forum 3 07-12-2011 07:20 AM
got my 3.5" lift into my 5.9... now i have steering and alignment issues. cirame1 ZJ Grand Cherokee Forum 7 06-23-2009 02:39 PM
Rough Country 4" lift Issues For ZJ zjBRYCE ZJ Grand Cherokee Forum 4 02-23-2009 05:52 PM
issues with the lift,.."rubbing" coyote runner WK Grand Cherokee & XK Commander Forum 6 10-24-2007 06:28 PM
3" lift = driveshaft and steering issues? mtnjam ZJ Grand Cherokee Forum 5 09-30-2007 08:35 PM
