Wacky Engine - JeepForum.com
post #1 of 10 Old 01-11-2017, 01:09 PM Thread Starter
nurse3025
Wacky Engine
My son has a 2001 jeep grand Cherokee 4.7 and he had to replace the timing belt, guides and tensioners...things went good. the passenger tensioner malfunctioned causing a lot of chain slack and blew apart the left tensioner and broke a guide. We had to replace both tensioners and a guide, everything is back together and it started right up, ran great stalled when he tried to accel and now it wont start. It has spark and gas but will not start...any ideas? New starter, fully charged battery and new cam/crank sensors....PLEASE HELP
nurse3025 is offline
post #2 of 10 Old 01-11-2017, 01:20 PM
weaselsmopar
Did you verify that it did not jump timing and possibly kill a valve when this happened I would run a compression test and verify that it did not jump a tooth or more of timing.
weaselsmopar is offline
post #3 of 10 Old 01-11-2017, 01:27 PM Thread Starter
nurse3025
all valves are good, timing is still set perfect
post #4 of 10 Old 01-12-2017, 01:12 AM
Relax_Jimmy24
Any check engine light codes? By the post i am assuming it cranks but does not start. Did you double check all the connections to sensors and coils?
Relax_Jimmy24 is offline
post #5 of 10 Old 01-12-2017, 06:45 AM Thread Starter
nurse3025
yes, has full spark and just replaced the cam and crank sensor thinking that was the problem...it didn't stay running long enough to code anything and no engine light
post #6 of 10 Old 01-12-2017, 06:46 AM Thread Starter
nurse3025
It started right up first try and ran smooth but only until my son hit the gas peddle then died and now cranks but no start
post #7 of 10 Old 01-12-2017, 11:32 AM
Relax_Jimmy24
Did you check the throttle body? I am just thinking of parts that moved when he hit the pedal
post #8 of 10 Old 01-12-2017, 12:45 PM
weaselsmopar
How about fuel pressure to the motor maybe a fuel pump went bad or maybe they fuse.
post #9 of 10 Old 01-13-2017, 08:38 AM Thread Starter
nurse3025
found the problem, I had my son check timing one more time just for giggles. the driver cam gear bolt came loose and broke off the sheering pin .New cam on order
post #10 of 10 Old 01-13-2017, 08:40 AM
weaselsmopar
Well atleast ya'll found it.
