Vibration - TC or CV?? - JeepForum.com
post #1 of 11 Old 05-28-2013, 08:58 AM Thread Starter
thechainrule
Wj Vibration - TC or CV??
This weekend while driving my jeep on the highway it started vibrating horribly at the front end almost as if the front drive shaft wasn’t balanced or something, it got worse when on the throttle so I pulled over to have a look. There was smoke coming from the transfer case where the front axle meets the TC. Also, I noticed that the tears in my CV boots were much worse than I thought; I have been planning to swap them out this month thinking they would last a bit longer but could the CV axle cause this vibration too?
What’s weird is that I had to restart my jeep to get it out of the way and the majority of the issues went away. No more vibration or loud noise. However, I can definitely hear a humming/ slight grinding when its moving now especially while coasting off the throttle.
I have no idea where to start here. Obviously replace the cv axles, but as far as the vibration…swap the TC, rebuild, new chains????
Thanks
2000 wj, 4.0, 247 TC 180000 miles
thechainrule is offline
post #2 of 11 Old 05-28-2013, 09:54 AM
skain8
skain8's Avatar
Start easy first -- remove your front driveshaft and take her for a spin. If the vibration stops, you likely found the source of your problem. Report back the results.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #3 of 11 Old 05-29-2013, 07:08 AM Thread Starter
thechainrule
Is there a write up anywhere for that?
post #4 of 11 Old 05-29-2013, 09:37 AM
skain8
skain8's Avatar
Yes.
Step 1. Grab wrench and remove bolts.
Step 2. Remove driveshaft.
skain8 is offline
post #5 of 11 Old 05-29-2013, 10:51 AM
porrsher
1994 ZJ
Sounds like a gone TC.
Sent from my Raul iPhone using JeepForum
1994 Hunter Green ZJ 5.2L Quadratrac
228k Miles, 2" BB.
2002 Slate Grey Grand Cherokee Overland
161k Bone Stock
2008 Black JK Sahara Unlimited (Love it!)
porrsher is offline
post #6 of 11 Old 05-29-2013, 12:32 PM Thread Starter
thechainrule
Time to grab a new 247.
post #7 of 11 Old 05-29-2013, 01:23 PM
skain8
skain8's Avatar
I enjoy web-diagnosing issues just as much as the next guy, but did you consider troubleshooting a problem prior to replacement? Just a thought.
skain8 is offline
post #8 of 11 Old 05-29-2013, 01:27 PM
adavis39
Originally Posted by skain8 View Post
Yes.
terrible write-up.....i mean you didnt even mention where the bolts are located
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #9 of 11 Old 05-29-2013, 01:37 PM Thread Starter
thechainrule
I didn't realize how easy it was to remove the shaft as I have never done it before. I just took another look under the car this morning, the CV on the front drive shaft is definitely destroyed. I am going to take it off tomorrow before I go about buying another TC.
Is there anything wrong with taking the shaft off and leaving it off until i get the replacement CV?
post #10 of 11 Old 05-29-2013, 02:37 PM
skain8
skain8's Avatar
I'll try better next time.
skain8 is offline
post #11 of 11 Old 06-03-2013, 08:23 AM Thread Starter
thechainrule
I went under the jeep this weekend to try and get the drive shaft out but it seems like its seized on there. Im going to give it a nice coat of pb or wd-40 and give it ago again later tomorrow. Also, when I was taking the bolts out i did notice some water leaking out around the bolts and a bit of oil coming out at the diff side, is this normal?
